6.5 tb overboosting? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 08-16-2010, 03:03 PM   #1 (permalink)
Member # 111410
just got a 99 6.5tb a week back,
seems to be hitting 15 psi on steep climbs towing car trailer with total 6000lbs, this cant be stock, how can i adjust the waste gate for more modest boost pressure say 10 psi or lower, not sure if its related but on the steeper longer climbs temperature hit 230 F once, exhaust gas tempurature is 8-900 degrees, seems kinda hot to me, and the trans hits like 190 -195 max all normal?
89 yj 102wb, 4.7-1t-case, 4.37s toy diff front and rear, 30 spline longfields, on 36 iroks
yotajeep is offline   Reply With Quote
Old 08-16-2010, 04:19 PM   #2 (permalink)
Gettin there!
rockbuggy84's Avatar
Member # 45202
Check to see if the boost line fitting is aftermarket. The fitting will have a tiny pin hole in it instead of the factory wide open fitting. Also not sure about the chevy but my cummins will hit 1100 townig up a hill trying to run 65mph and thats not max. My egt sensor fitting is tapped right at the manifold prior to the turbo. If yours is the same i've gotta imagine thats not horrible cause cylinder temp is not too bad. I would reccomend electric fans if the speed is dropping too low while pulling a hill. But like i said im a cummins guy and your truck might have lower egt maxes?
Wheeling before all the dbags made it "trendy"
rockbuggy84 is offline   Reply With Quote
Old 08-16-2010, 04:49 PM   #3 (permalink)
Poor White Trash
Norm's Avatar
Member # 4387
http://www.kennedydiesel.com/detail.cfm?ID=44
"For non-Intercooled vehicles, a 9-12 psi peak is the maximum recommended.
More boost can be used on Intercooled applications.
Proceed with caution."
I used to know a guy that was running 18 PSI on a 6.2, not sure how long that lasted
"My Border Collie is smarter than our president"
Norm is offline   Reply With Quote
Old 08-16-2010, 05:38 PM   #4 (permalink)
Member # 72000
prolly not long,unless hes spent an absurd amt of $$ rebuilding it to take it!
scotty
85 grand waggoneer(what's left of it)
77 scout II truggy
84 chevy home made crewcab
Delightfully Tacky,Yet Unrefined
nightcrawlers is offline   Reply With Quote
Old 08-16-2010, 09:13 PM   #5 (permalink)
Newbie
yozsi's Avatar
Member # 91857
Send a message via AIM to yozsi
I used to hit 1200-1300 sustained on my turbo'ed 6.2 running about 13-15 psi. i think you are okay. Mine lasted quite a long time until i over speed it and the crank broke in 2.
92 Nissan Pathfinder- Front 3 link, EB d44 with full chromos and OX, rear 4 link h233b with full detroit.
02 Dodge 2500 QC LB 4x4, CTD, nv241dhd, 500 hp daily.
89 Dodge D250 CTD - New Project Truck
72 Datsun 240z Race Car.
Foreign Car Center
Vallejo, CA
yozsi is online now   Reply With Quote
Old 08-17-2010, 11:17 PM   #6 (permalink)
Member # 111410
well the egt gauge was mounted after the turbo on the exhaust so its probably reading lower then it should be. Seems to me that my clutch fan isnt kicking in at the right time, or at all, which i believe to be the problem with the overheating
