#127 (permalink) |
It took a week or two to get used to it. Surprisingly going back and forth between that and a standard 5 speed never confused me after that. I just got rid of that 5sp though, and my other DD is a slushbox now. I expect having the 13 as my only stick shift will screw me up after a while when I jump into another 5sp!
If you re-label that Spicer's 1 to L, it's an identical pattern...
Michael Maskalans Codriver, Game Day Racing #571 07.5 C&C Ram 3500; G56, 245 19.5s, 4x2, ARB 98 Dakota on 42s; then | now | build PARTING: 97 Ram 3500 - 24v, 13sp 87 AMC Eagle Wagon - 258/auto, mostly stock Fingerlakes 4x4 | M4wd & Fabrication | Right Coast 4x4 | Rock Modified | Rok-Freekz |
#128 (permalink) |
Member # 12790
@ 4:20, (huh?
) it starts to whine...sounds a lot like an SM420 I had in an old Fj40 once when in 4th, is that direct drive you shifted into?
Kyle 84 SR5 Longbed Trail Rig in progress. 22r, 5spd, duals with D300 rear case 97 Ram 3500 4wd dually. Turned up 12v, 5spd, 4.10s and 19.5s. 02 Civic 4door 5spd for DD 85 Tercel SR5 4WD Wagon, 6spd, For Sale. 77 Ford F250 2wd, 400/C6, very little rust, 100% original grandpa truck. For Sale. Last edited by 72rockcruiser; 02-22-2012 at 02:39 PM. |
#129 (permalink) |
that's the wonderful whine of overdrive.
#130 (permalink) |
Member # 192237
I could see that (the wierd shift pattern) being so they wouldn't have to dink around with the mainshaft config to get overdrive out of a trans designed without an overdrive top gear.
You have 1 and 2 which are underdrive gears, then 3 which is direct, then 4 which is over, whereas a direct or single-over trans would have 1-3 as underdrive and 4th as direct. Swap the 3rd gear tooth counts around to make it overdrive, and you don't have to mess with the direct dog clutch. Last edited by [486]; 02-22-2012 at 06:51 PM. |
#131 (permalink) |
Member # 143867
i also run about 1900-2000 rpms at 75mph. so far i have probably about 40,000 miles on mine though i don't know for sure as it took awhile for me to get a speedometer and i've had several issues with the rear driveline that has forced me to use front wheel drive. i have driven it to texas and back without issue though.
edit: i am running a ceramic clutch which is may be adding to the clutch control issue. my truck was an automatic plus i'm not sure how well the stock components would hold up to the excessive stiffness if i were to use a stock clutch pedal assembly
F-350 cclb dually, 6bta, rtoo9513, divorced twin stick np205, arb 10.25 rear with 2nd gen gears, KMA front bumper, warn m15000 hydraulic winch, connex 4800, wilson 5000 antenna, wilson cell phone amp, lowrance baja 540c gps, scanner, premier power welder, onboard shower, 235/85/r16 BFG MT's Last edited by chrisevans2645; 02-23-2012 at 02:28 PM. |
#132 (permalink) |
Member # 84464
EDIT* I WAS WRONG!
i acquired an RTOO9513 from 1972 and its got the SAME SHIFT PATTERN as mr mindless. 8th is forward right corner, 7th is rearward right corner. sorry for the error.
God Bless America Last edited by mike_belben; 02-24-2012 at 06:20 AM. |
#133 (permalink) |
Member # 143867
no, i have the eaton fuller manual for the rt9513 series and it shows the rt and rto with the up and down the street shift pattern and the rtoo with the around the block shift pattern. not sure why yours is differnt
F-350 cclb dually, 6bta, rtoo9513, divorced twin stick np205, arb 10.25 rear with 2nd gen gears, KMA front bumper, warn m15000 hydraulic winch, connex 4800, wilson 5000 antenna, wilson cell phone amp, lowrance baja 540c gps, scanner, premier power welder, onboard shower, 235/85/r16 BFG MT's |
#134 (permalink) |
TANK
Member # 131367
you guys with the big trans been able to get any mpg averages figured out yet?
Originally Posted by GONRACIN it's far better to have more truck then you need, than to need more truck then you have.... |
#135 (permalink) |
IDIot!
Member # 44480
My UHaul/IDI went from 6.5 completely loaded to 7.7, going from a 5-speed with a straight-through 5th gear to a 7-speed with a 0.73 o/d.
Motive Gear Land Use Team http://www.tenfactory.com http://www.motivegear.com http://www.nationaldrivetrain.com http://www.davezoffroadperformance.com http://www.mastercraftsafety.com FToy 086 - UHaul Toterhome |
#137 (permalink) |
I think the extra weight and rotating mass mostly made up for my RPM gains. I picked up noticeable milage (15%ish) going to Ford outers with unlocked lockouts.
Looking at my numbers, the first 23k I had the truck with the 5 speeds, I got 11.5mpg In the 28k since the swap, if I take out the broken injection line tanks, I've gotten 11.8mpg. Probably have done more towing miles since the swap than before. I haven't put data in the sheet in a while so I don't know how much of a difference my cam swap made, nor the overall average the lockouts made. I also really exchanged high RPM engine noise for the whine of straight cut gears and overdrive split howl, so I only really improved durability...
#138 (permalink) |
Member # 112455
That overdrive split howl is something I'm not used to. I've only driven normal .7X OD 13's and didn't remember any noise from them. Of course that was in a Kenworth W9 whose cab sat a couple feet above the trans and then had some pretty amazing sound deadening.
The noise kind of reminds me of a Mack I drove with a 7 speed (5 speed with double low). If you hit the range selector in anything but 1st or 2nd, it would make that same horrible high pitched whine. |
#140 (permalink) |
75% towing I'd say. And half of the rest is "city"
It's not one of the magic 25mpg Cummins trucks to say the least. It's never broken 20 since I've owned it. Best tank ever is 19.9. I've gotten 12.5+ towing a few tanks lately though since the lockouts.
#143 (permalink) |
22-24 most of the time I'd guess. 36' low deck goose open center.
#144 (permalink) |
Member # 84464
whats your impression of the 19.5s and what rubber you got on them?
were they a big change in road feel over the 16s? ive got the identical truck
God Bless America |
#145 (permalink) |
Good upgrade. The tall tread blocks wander a bit on brand new tires, that lasted about 2-3k.
Running traction recap drives on Khumo carcasses. 40k on them and at 3-40% now. I had Continental HDRs on the steers, one flat spotted and I had to swap it. The remaining one is about done. I'll probably put 2-4k more on it and swap it to the matching rib tire to what I put on the other side. Probably do a full set of 6 Treadright remold tires this fall. They're cheaper than I can get caps...
#147 (permalink) |
It's possible... It was on its way from Rochester to the coast of CT for some work. It'll be coming back sometime this spring/summer.
#148 (permalink) | |
Old Skool
The way that you wander is the way that you choose. |
#149 (permalink) |
I'll keep an eye out for your J Truck, didn't know you were that close. I was wondering where in NY "the other side of the hill" was, I was figuring Adirondacks.
I hadn't followed your Amerigo thing, just started reading that thread. For a while I really wanted one of those to drop on the front of my gooseneck, but I keep using the hell out of all it's deck space as you can see, so that's a lot less appealing than it was for a while. What you found in there reminds me of the trailer I used to have - and the house I replaced it with... Major reconstruction needed from water damage in both of them, most or all of it hidden from view.
#150 (permalink) |
Member # 84464
i just dragged an RTOO home this week and verified its salvageable last night. northeast roadranger owners group apparently. i think mines earmarked for an MDT tho. i cant justify adding clutch pedal and cutting the floor with only 2 door cab.
God Bless America |
