95 dodge cummins not running on #1 cylinder? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-05-2010, 12:25 AM   #1 (permalink)
Member # 113376
after some minor investigation it seems as if the fuel out of the #1 delivery valve is weak compared to the others.
can delivery valves go bad?
truck is definately only running on 5 cylinders. it reacts to cracking the line on the other 5 cylinders.
EGTs are down,boost is still the same. no white smoke,but less black smoke. lift pump pressure 25psi at idle,40 under load.
this happened suddenly. fine one night running on 5 cylinders the next morning.
ideas?
co84rc is offline   Reply With Quote
Old 09-05-2010, 06:14 AM   #2 (permalink)
jedrattle's Avatar
Member # 21750
delivery valves
Are you talking about the injector?
Team RattleKann
**ROCKBRAWLERS**
jedrattle is offline   Reply With Quote
Old 09-05-2010, 07:08 AM   #3 (permalink)
Member # 113376
no the actual delivery valve on the pump. i had the injector out and apart. the nozzle was clear.
when you have the line disconnected from the pump and crank the motor you can see the number 1 out put port is weaker than the others.
Old 09-05-2010, 09:07 PM   #4 (permalink)
Newbie
yozsi's Avatar
Member # 91857
Send a message via AIM to yozsi
Yes.
92 Nissan Pathfinder- Front 3 link, EB d44 with full chromos and OX, rear 4 link h233b with full detroit.
02 Dodge 2500 QC LB 4x4, CTD, nv241dhd, 500 hp daily.
89 Dodge D250 CTD - New Project Truck
72 Datsun 240z Race Car.
Foreign Car Center
Vallejo, CA
yozsi is online now   Reply With Quote
Old 09-06-2010, 06:37 PM   #5 (permalink)
Robert's Avatar
Member # 1050
Send a message via Yahoo to Robert
Yes.
The camshaft inside the fuel pump can also fail, causing low output volume.
Time for a new pump.
Ask me anything about a Cummins, I stayed at a Holiday Inn last night.
Robert is offline   Reply With Quote
Old 09-07-2010, 08:49 PM   #6 (permalink)
Member # 113376
Originally Posted by Robert View Post
Yes.
i believe that is what happened to mine. flat lobe on the #1 out put.
found a pump,being installed this week.
thanks for input.
