Rewired trailer now lights are wonky... - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 09-13-2010, 07:48 PM   #1 (permalink)
International Dan
binderbound's Avatar
Member # 18592
Send a message via AIM to binderbound
Completely rewired my 14 foot flatbed. switched all the the lights to the basic 60 series grote/trucklite. Turn signals work great and are super bright. Brake lights also are bright and good. Running lights are bright and all work. Problem is when the lights are on and I turn on the turn signal, all the lights flash, dimly. Even the LED on my voyager blinks. Every light is individually grounded and all the grounds are run together. ground on the truck is good too. When I did the light test, I just plugged it into the truck but did not attach the hitch or anything. I'm sure there is a super simple solution I'm just missing. What should I do?
Thanks!
#4666 build /forum/general-4x4-discussion/1048195-koh-ih-binder-speed.html
facebook.com/hardenedways
Huge thanks to Ruffstuff specialties, str8rbill, Scouty, Uglyscout, Ben W, jeepdude jay, Trans-fix, hellfire fabworks, international harvester, and viewers like you.
binderbound is offline   Reply With Quote
Old 09-13-2010, 08:04 PM   #2 (permalink)
bigun's Avatar
Member # 29037
Did you ground just to the frame of the trailer or did you ground through the plug? Hitch to the truck I'll bet it works since it sounds like you need it for a ground connection
“I will not be wronged, I will not be insulted and I will not be laid a hand on. John Wayne “The Shootist.”
bigun is offline   Reply With Quote
Old 09-13-2010, 08:12 PM   #3 (permalink)
108" Smurfmobile
YellowSub1962's Avatar
Member # 1494
yeah, sounds like a bad ground...
Peter S. Di Primo
PSD Enterprises, LLC - Waterjet, laser, metal forming, CNC work, Fiberglass and Carbon work, patterns and molds. No job too small.
Prototyping and small production is our specialty, but we have the network to handle large jobs as well.
Email me if you need something cut, bent, formed, milled, machined, etc.
Founding Member - VCAS4WDC www.axlesnappers.org
Help Fight Global Warming- turn your A/C on high and open all your windows.
Alcohol, Tobacco, and Firearms should be a convenience store - NOT a government agency!!!!
YellowSub1962 is offline   Reply With Quote
Old 09-13-2010, 08:17 PM   #4 (permalink)
International Dan
Member # 18592
It is grounded through the plug too. That's what's so weird.
#4666 build http://www.pirate4x4.com/forum/showthread.php?t=1048195
Old 09-13-2010, 08:25 PM   #5 (permalink)
Member # 132500
I had a very similar problem once and it was APPARENTLY because the ground wire in the trailer plug had broken inside the wire loom, so it was only grounding through the hitch - but it still doesn't make sense to me why it would do that, and obviously that's not your problem. Maybe it's because the ground is weak for some reason - see if it gets better when you hitch the trailer up.
Machinos is offline   Reply With Quote
Old 09-13-2010, 08:29 PM   #6 (permalink)
International Dan
Member # 18592
I wrapped the drag chains around the hitch. No change. Btw, its raining now so grounds should be better, right?
Old 09-14-2010, 02:35 PM   #7 (permalink)
Member # 78077
I installed a set of cheapo lights for a guy, Even with a ground wire for each light the other lights would dim when the turn signal flashed. It was just a cheap harness.
Don't blame me, I voted against him.
#rawkon is online now   Reply With Quote
Old 09-14-2010, 03:14 PM   #8 (permalink)
mondtster's Avatar
Member # 25349
Send a message via AIM to mondtster
Hook it to a different vehicle and see if the problem follows the car or the trailer.
Sounds like a ground issue to me.
mondtster is offline   Reply With Quote
