5th Wheel Hitch Placement - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-27-2010, 03:39 PM   #1 (permalink)
coyote's Avatar
Member # 170
Thinking of going medium duty with a flatbed, but my question is that I want to use the flatbed to hold my crawler but still pull a 5th wheel hitch but mount it behind the axle...any issues with this? I've heard that I might have issues.....
Red Racer I
Toyota FJ62
coyote is offline   Reply With Quote
Old 12-27-2010, 09:06 PM   #2 (permalink)
Member # 130003
Depends how heavy the front axle on the medium duty weighs, and how much hitch weight the 5th will have on it.
With a 1 ton, no way!
With a medium duty, sometimes OK, with full size semi, not as much of an issue.
Any time the hitch is behind the axle CL it will take weight off the steer axle, and it'll be worse at "take off".
No matter what the hitch is on and pulls the 5th wheel or goose, it is BEST to have the hitch ahead of the axle CL.
As the PBB says, depends on how many orphans and nuns you feel fine killing,,,,
Harold Phipps is offline   Reply With Quote
Old 12-27-2010, 09:29 PM   #3 (permalink)
Soundguy's Avatar
Member # 32677
I wouldn't waste the time to mount a 5th wheel behind the axle on something like a 1 ton truck if you're planning on pulling a decent size trailer, that defeats the purpose of having a 5th wheel trailer because your front/rear weight dist. will be all screwed up.
Soundguy is offline   Reply With Quote
Old 12-28-2010, 07:06 AM   #4 (permalink)
coyote's Avatar
Member # 170
nah it's a light weight trailer, less then 5k...but I understand what your saying...limited weigth will be removed from the front axle....planning first so as to not kill anyone and be safe....
Red Racer I
Toyota FJ62
Old 12-28-2010, 12:13 PM   #5 (permalink)
Member # 17632
I would think it more depends on axle placement in relation to the hitch. If the axle is closer to the rear it will be better.
Travis..
74 Ramcharger, 360, 4spd, 60/70 on 37s
91.5 Dodge 6BT 5 spd tow rig
crashnzuk is offline   Reply With Quote
Old 12-28-2010, 07:51 PM   #6 (permalink)
Member # 40795
A loaded 5th wheel - RV or equipment trailer - that weighs less than 5K?
Brian
brian4wd is offline   Reply With Quote
Old 12-28-2010, 08:45 PM   #7 (permalink)
Member # 33536
the further behind the axle centerline you mount the fifth wheel hitch, the more that trailer will act like a bumper pull when turning and tracking... now dont take this to the extreme and mount it three feet behind your axle (unless you have a semi) but a small amount would be ok.
How far behind the axle do you need it to be in order to load the rig and pull the trailer at the same time? that may be the deciding factor along with truck and axle ratings.
85blue4runner is offline   Reply With Quote
Old 12-29-2010, 07:33 AM   #8 (permalink)
coyote's Avatar
Member # 170
Brian
Yep...it's only 15' long rv....currently towed by a 1/2 ton chevy and you can't even tell it's back there...
Just wanted to do my research first but it looks doable....safely....
Red Racer I
Toyota FJ62
Old 12-29-2010, 11:48 AM   #9 (permalink)
Member # 72000
i dont think youve anything to worry about with a heavy MDT.i know youre gonna be alittle different with a rig on a flatbed,but i think youll have alot less pinweight behind the axle than these guys
scotty
85 grand waggoneer(what's left of it)
77 scout II truggy
84 chevy home made crewcab
Delightfully Tacky,Yet Unrefined
nightcrawlers is offline   Reply With Quote
Old 12-30-2010, 06:58 PM   #10 (permalink)
angryblack's Avatar
Member # 142394
Is there some sorta mathematical equation for this.. Is been on my mind as my camper rebuild went well but there is more rot that we didnt fix.Im thinking of taking out the appliances and building a ox/cabin/sleeper thing on the back of our uhualer.Then put a gooseneck behind the axle about 24" from the axle centerline
Unfortunately there is no end to human stupidity -- making things foolproof only creates more ingenious fools
angryblack is offline   Reply With Quote
