Removing Cummins turbo boost sensor - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-01-2011, 12:26 PM   #1 (permalink)
Member # 77047
Send a message via AIM to Strider_aa
I've tried to remove the turbo boost sensor and I'm finding that the sockets are not fitting around the sensor because there is not enough room between it and the manifold. Is there a secret to removing it or do I have to have a special tool? I tried to use a tool a friend has that exactly fits it even including the rounded corners and it wouldn't fit.
Thx...
Brandt
Strider_aa is offline   Reply With Quote Quick reply to this message
Old 01-01-2011, 04:49 PM   #2 (permalink)
Robert's Avatar
Member # 1050
Send a message via Yahoo to Robert
Cummins has used a number of different 'boost' sensors since 1997. Can you be more specific about what year of engine you are working on?
My 1999 VP44 engine only requires a deep 1.25" socket.
Others require special sensor sockets.
Newer engines have a combination 4 wire intake manifold temperature/pressure sensor that presses into a hole in the intake and then is secured by a bolt.
Ask me anything about a Cummins, I stayed at a Holiday Inn last night.
Robert is offline   Reply With Quote Quick reply to this message
Old 01-01-2011, 10:21 PM   #3 (permalink)
Member # 77047
[QUOTE=Robert;12323480]Cummins has used a number of different 'boost' sensors since 1997. Can you be more specific about what year of engine you are working on?
Sorry, I wasn't thinking very well. It's a 2001 and the sensor fits a 1 1/16 socket. I believe the connector is 2wires and it sits just under the intake near the back end of the motor. it fits perfectly in a socket that would also fit a dodge oil pressure sending unit on several cars I've had. I can't find the socket I own and I've tried several others that other folks have. The socket that fit the new one perfectly seemingly won't fit between the sensor and the manifold above it. This is irritating to deal with. What ideas are out there to fix this thing?
Thx...
Brandt
Old 01-01-2011, 10:55 PM   #4 (permalink)
Robert's Avatar
Member # 1050
[QUOTE=Strider_aa;12324513]
Thx...
Brandt
If it is only two wires then you are not dealing with the intake manifold pressure sensor. Pressure sensors are three wire. Temperature sensors are two wires.
Old 01-01-2011, 11:29 PM   #5 (permalink)
Newbie
Member # 30414
Send a message via AIM to Fast500
I believe the one on your truck is a either a 32 or 36mm, the newer updated replacement sensors use a 1 1/16" socket.
Brett Lujan: Left Coast Diesel
97 Dodge 2500 4x4 710hp/1405tq
Fast500 is offline   Reply With Quote Quick reply to this message
Old 01-02-2011, 11:33 PM   #6 (permalink)
Member # 77047
Does this mean that I have to find a special socket to remove the old one and I can use the 1 1/16 socket to put the new one one?
Thx....
Brandt
Old 01-02-2011, 11:39 PM   #7 (permalink)
Newbie
Member # 30414
It doesn't take a special socket, just a regular deep to get it out, I can confirm what size it is when I go to the shop tomorrow.
Old 01-03-2011, 10:50 AM   #8 (permalink)
Newbie
Member # 30414
Just checked, a 32mm/1 1/4" deep will work.
Old 01-03-2011, 11:20 AM   #9 (permalink)
Member # 90212
you gotta get a thin wall socket also. no thick impact sockets.
"This truck is probably going to end up like a retarded kid. You wanna get rid of it but in your heart you know you'll have to keep it."
stomp-a-jeep is offline   Reply With Quote Quick reply to this message
