Methods of Painting Trailer? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-12-2011, 09:38 PM   #1 (permalink)
SixSped5's Avatar
Member # 126806
Send a message via AIM to SixSped5
Hey Guys,
I am giving my gooseneck a new lease on life. I have it all ready to prime and paint but I am stuck on painting methods.
The trailer is a 32ft Gooseneck Equipment trailer, with a steel deck. So there is a LOT of surface to cover.
I have used brush/roller (zzzzz) on trailers before, as well as automotive type sprayers (takes forever to lay down enough paint). I was trying to figure out how to speed up the process. Would a good quality house-type sprayer work? I know they put out a lot of paint, any comments/suggestions?
Edit: Maybe spray frame/underside/neck and roll deck?
Jack Miles :: Tampa, Florida ::
2003 Dodge Ram 3500 - QC/DRW - 4x4/SixSpeed - Tow Rig
1978 Mercedes L1116 4x4 - 6CTA Cummins - Hiab 550 Knuckle Boom
1963 Unimog 404 / Doka Hardcab / TurboDiesel / Exocaged / NotMuchStock - Play Rig
1961 Unimog 404 / Soft Top / Flat Bed
SixSped5 is offline   Reply With Quote
Old 04-12-2011, 09:45 PM   #2 (permalink)
Member # 78329
My buddy painted his gooseneck trailer with just an air sprayer. He doesn't have a steel deck though.
It did take a while though. He just bought a gallon of Rustoleum paint.
Stretched TJ HP60, Shaved 14 bolt, Coilovers
For Sale:
2 13" BBCS shocks 150 pair
3 11" BBCS shocks 75 a piece
TJ 44 with truss, detroit, and shaft
JeepRocks86 is offline   Reply With Quote
Old 04-13-2011, 05:36 AM   #3 (permalink)
Ken Carter / BRUISER's Avatar
Member # 3321
Send a message via AIM to Ken Carter / BRUISER
paint gun and oil based rustoleum by the gallon thinned with acetone(only)
before:
after
www.iMPAKS.com, www.LoneRiderBeer
Tread Lightly Master Trainer
My Builds:
Bus / RV, New Jeep, Camper / ToyHauler, CTD Tow Rig, Jeep XJ, Shop
Ken Carter / BRUISER is offline   Reply With Quote
Old 04-13-2011, 05:45 AM   #4 (permalink)
Certified E-Thug
montecarlo31's Avatar
Member # 117771
Originally Posted by Ken Carter / BRUISER View Post
after
We use Cat Black (made by Valspar I believe), oil based and they come out great. 80 to 90% of paint work is in the prep to be truthful. If you don't have it prepped right and clean and ready to work there's no sense in doing anything good with paint.
On a side note why only 1/2 the deck?
montecarlo31 is online now   Reply With Quote
Old 04-13-2011, 07:44 AM   #5 (permalink)
Member # 44856
Send a message via AIM to DownNDirty
couple of brushes and rollers + neighborhood kids that need money. I sprayed mine with an HVLP. Just put a primer needle in and let it dump paint. Still need to go back and touch it up where I didn't put enough down.
DownNDirty is offline   Reply With Quote
Old 04-13-2011, 02:13 PM   #6 (permalink)
Member # 171191
case of beer...or two and some buddies....should knock that out in no time
bweezy is offline   Reply With Quote
Old 04-13-2011, 03:58 PM   #7 (permalink)
Member # 78077
I sprayed mine in the back yard, Took about a hour and one gallon of rustoleum cut with tolulene.
Don't blame me, I voted against him.
#rawkon is offline   Reply With Quote
Old 04-13-2011, 06:17 PM   #8 (permalink)
Certified E-Thug
Member # 117771
I'd avoid rolling on paint if at all possible. I'll see if we have some pics of how we paint them.
Old 04-13-2011, 06:49 PM   #9 (permalink)
Member # 3321
It is my back deck
My Builds:
Old 04-14-2011, 07:54 AM   #10 (permalink)
Kaiser5's Avatar
Member # 26472
I painted my flat bed in my shop with an HLVP gun. I had to paint it indoors because it was still winter. I ended up making a "spray booth" out of plastic sheeting over a 2x4" studded frame. Worked really well but was a PITA to spray indoors.
I used this tractor paint with a hardener to get the final black. The finish stiil looks great.
'84 Bobbed -8, LT-1, TH400, STaK 3 speed, front 60 with Detroit/35 spline shafts, rear 14 bolt with detroit, garage built rear four link, front radius arm, 42" TSLs on locked Racelines, PSC assist, WARN 8274, lots of plating.
'82 -'8 As stock as it gets...
Kaiser5 is offline   Reply With Quote
Old 04-14-2011, 05:27 PM   #11 (permalink)
Member # 54978
Send a message via AIM to Mud Slayer 2.0
Damn that looks good.. is that orange a primer ?? and how did you strip it before paint ?
It's not yours unless YOU built it !
89 s10 4.3 700R4 Dana 300 Dana 44 5.13s locked on 38's
Mud Slayer 2.0 is offline   Reply With Quote
Old 04-14-2011, 05:31 PM   #12 (permalink)
SixSped5's Avatar
Member # 126806
I ended up rolling the deck, and spraying the rest with a HVLP automotive gun. Took a gallon to do the deck, and a gallon and some change to do the rest of it. Took quite a while, but it looks great.
Sorry, no photos. No red star for me!
Old 04-14-2011, 07:42 PM   #13 (permalink)
Kaiser5's Avatar
Member # 26472
Yep, the orange is a Valstar primer. I used a large, cupped wire wheel in my angle grinder. It worked pretty good, but I was beat by the time I was down to metal on the entire trailer.
