lifting a tow/plow rig - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-25-2011, 06:37 PM   #1 (permalink)
Member # 171191
for most of us we use our trucks as multi-purpose vehicles. i tow my crawler on the weekends and plow with it in the winter. im considering a 4 in lift with some 35s on my 2008 f350. i have an 8'2 boss v plow.
what is your guys experience plowing with a lifted truck. i know i will have to lower my mount accordingly. im more concerned with not being able to see the plow. im just curious to see how you guys like or don't like plowing with a lift kit.
bweezy is offline   Reply With Quote Quick reply to this message
Old 04-25-2011, 06:41 PM   #2 (permalink)
Member # 129381
I have a stock Dodge on 37s and I cant see the plow markers when its angled. Thats about my only bitch. I like that I can drive thru the deep stuff without getn stuck.
NT2HLBLY is offline   Reply With Quote Quick reply to this message
Old 04-25-2011, 06:56 PM   #3 (permalink)
Member # 142381
I'd have the same concern.. Also, it seems that many lift kits these days make the front end higher than the rear. I see it everyday when I get to work. 4 wheel parts installs lift kits on our tundras.. They all sit nose high. <imo
pic_jon is offline   Reply With Quote Quick reply to this message
Old 04-25-2011, 09:01 PM   #4 (permalink)
Member # 171191
my question was more about workability with a lift kit..not if you like lifted trucks or not. not too sure how much snow texas see a year but thanks for your opinion
Old 04-25-2011, 09:08 PM   #5 (permalink)
Member # 70453
Send a message via Yahoo to yellowk20
I've plowed with a Highboy on 36" buckshots , it worked fine,
Just make sure that the plow frame goes low enough to keep the plow parallel to the ground.
[QUOTE=ffdustyw;13449095]I've been pepper sprayed so many times by women it doesn't effect me anymore.
The bear spray idea is retarded. Trip wires with claymores are more effective. Plus it will keep the hippy squatters like Chris McCandless out of your cabin.[/QUOTE]
yellowk20 is offline   Reply With Quote Quick reply to this message
Old 04-26-2011, 08:27 AM   #6 (permalink)
Member # 7753
The BOSS brackets need to got to the lowest set of holes to get the push point down low. If you're wheeling it, this means your lift is wasted as that mount will drag first. Raising the mount means the back edge of the wings won't touch the ground well and all the weigh is on the nose.
The V doesn't have a trip edge and barely trips as it is, if you make the angle steeper is will be even worse.
A lifted truck plows fine when the plow is setup right, but the Boss mount is about the worst for wheeling with.
Slowzuki is offline   Reply With Quote Quick reply to this message
Old 04-26-2011, 11:10 AM   #7 (permalink)
WAD357's Avatar
Member # 170389
as said make sure the fram goes low enough... I plow with a 97 f350 on 35s with no lift and I have zero issues in the deep stuff
1995 XJ 60s 3 link and 36s
1997 F-250 Powerstroke Tow Rig
WAD357 is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 09:11 AM   #8 (permalink)
broncdawg's Avatar
Member # 42245
The benefits of lifting your truck for clearance are lost by lowering the plow frame to make the plow land properly. Now if the "chicks dig it" factor is what you're after, go for it, otherwise why bother?
77' Bronco,5.0 roller,Klune 4:1,37s,Wristed radius arm / 85' Runner-5.29s,Detroits / 79 F350 4x4
broncdawg is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 09:33 AM   #9 (permalink)
Member # 188714
Used to plow with my '87 which was up there. My buddy and I built a custom LOWER plow frame out of square tubing. I still used the upper frame for the plow lights, pump, etc.
Just took a few measurements, some welding and a few bolts.
I could NEVER see my plow. I could see the markers when the plow was angled. A little practice and you'll have no problems!!
Now on the tow side, I had a buddy who used to pull camper with his lifter Suburban. He didn't bother with a drop hitch, he lifted the camper about 6"!!
4x4ord is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 11:46 AM   #10 (permalink)
Member # 181230
not a problem at all just lower the mounting bracket to the correct hieght. and get longer plow markers. Everyone will say your plow mount defeats the purpose of the lift for wheeling. Plow mounts are put on with bolts. that means they come off does it not? take mine off after every season and mud my truck
Thesnowman269 is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 11:55 AM   #11 (permalink)
Member # 127875
if 35s is what you want you dont need to lift it. 08-11 can fit 35x12.5 atleast on the stock 20s and i think the 18s. i have 35s on my harley edition 08 now with no issues
1slosvt is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 06:09 PM   #12 (permalink)
Member # 54978
Send a message via AIM to Mud Slayer 2.0
if it's a towrig / workhorse why do you wanna lift it ?? granted 2" here or there looks good but you're a 4"+ doesnt seem nessacary
It's not yours unless YOU built it !
89 s10 Dana 300 Dana 44's 5.13s locked on 38's
Mud Slayer 2.0 is offline   Reply With Quote Quick reply to this message
Old 04-27-2011, 06:43 PM   #13 (permalink)
DT75FLH's Avatar
Member # 101209
This...my 08 f-350 fit 35"s (stock rims 20")with a 2" level kit.
Difficulty is the excuse history never accepts.
A Nation of sheep will beget a Government of wolves.
Edward Murrow
DT75FLH is offline   Reply With Quote Quick reply to this message
Old 04-28-2011, 02:06 PM   #14 (permalink)
Member # 171191
could i see some more pics....pleeeeeez
Old 05-01-2011, 12:47 PM   #15 (permalink)
DT75FLH's Avatar
Member # 101209
here you go, 1st pic is where I mounted the gauge for the rear bags
Edward Murrow
