Dodge 3500 with 19.5 steelies and HD tires - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-30-2011, 03:44 PM   #1 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
Well I finally got my P30 bread truck wheels and some 19.5 heavy duty tires on my '02 Dodge 3500. It took a bit of searching to find the wheels.. found a few local and ordered a few off of Ebay.
*TECH* The wheels need the center hole bored out to fit the Dodge hub. The original center bore is approx. 4.5" and needs to be machined to 4.770-4.775. Any larger than that and they will not be centered on the hub. There are guys on other forums that say to bore them to 4.8+". I cant speak for the '04 and up trucks..
Boring
Before w/ stock 16" wheels and 235/85 rubber (approx. 31" tall)
After with 19.5" steels and 245/70R19.5 Hankook DH01 14 ply traction tires (approx. 33.5" tall and 9.5" wide).
The duals have over an inch of clearance between the sidewalls for those who are concerned about the tires rubbing/chaffing.
Azzy2000 is online now   Reply With Quote Quick reply to this message
Old 05-30-2011, 07:09 PM   #2 (permalink)
angryblack's Avatar
Member # 142394
Looks great and the benefits of the tires will be night and day difference.. Slapp on some chrome dodge centercaps and rock out.
Maintenance clerk wanted for fulltime work in Food manufacturing. It's a clean refridgerated enviroment usually at 34-40 degrees.
The plant is located in the nj 07004 area. PM me for details.
angryblack is offline   Reply With Quote Quick reply to this message
Old 05-31-2011, 08:43 AM   #3 (permalink)
Member # 13731
What are those wheels going for now? I 'might' have a line on a set but I'd hate to over pay for them.....
I think they look so much better than some bling aluminum, crazy pattern, huge wide, ricer, wheels.
uglyscout is offline   Reply With Quote Quick reply to this message
Old 05-31-2011, 10:35 AM   #4 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
Thanks.. No chrome though. Gonna keep 'em straight black
I paid $50 each for 3 of them and $80 each for the others off of Ebay. I'm not a fan of the big-ass chrome/ polished alum wheels either.
Old 05-31-2011, 11:17 AM   #5 (permalink)
Member # 142381
I really like that.. Definitely my taste. Truck is clean lookin' too
Were you able to get the tires for less than $275??
pic_jon is offline   Reply With Quote Quick reply to this message
Old 06-01-2011, 12:52 PM   #6 (permalink)
Member # 117771
Nice truck. 19.5s are pimp and should last you a good 100K miles. We see about 45 to 55K out of them on our service trucks at 19,000 lbs running down the highway.
montecarlo31 is offline   Reply With Quote Quick reply to this message
Old 06-02-2011, 01:01 AM   #7 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
Thanks.. I'm really happy with how it turned out. I paid $325 each.. including brass valve stems, mounted/balanced and installed.
I'm hoping to get 100k+ out of them. I plan on regular rotation to try and keep the wear even since I'm running drive tires all around.
Old 06-02-2011, 07:12 AM   #8 (permalink)
Member # 132020
I know you said you had them balanced, but check this out.http://www.centramatic.com/Home.aspx . I got 140,000 miles on a steer tire on a 04 Pete. The other side got cut from road debris, twice. (Second time @ max weight & 80MPH). Might help you out some, especially since you have 'drive' tires all around
spreader is offline   Reply With Quote Quick reply to this message
Old 06-02-2011, 06:22 PM   #9 (permalink)
Member # 146004
Man, that's a swingin' deal! I just got "bling" American Force wheels on mine after searching for months for the cheep steelies. Now you can clear the stoopid easy to install, BAD ASS 2nd gen brakes!
Sami 6.5:1 xcase Alloy axles PS 1.6 block (9.6:1) 1.3 head, triY 2", ratchet lockers.
totalloser is offline   Reply With Quote Quick reply to this message
Old 06-02-2011, 06:46 PM   #10 (permalink)
Member # 4387
Nice, I'm thinking of 19.5's for my next set, I have a 02 3500 CTD that seems to eat load range E tires pretty fast. A lot of the steel van wheels I've seen are rated at 2500LBS, and I'm running close to 5k on my front axle with camper/trailer combo . I found some vision steel wheels rated at 2900 LBS but they use a hub ring to adapt to the 8x6.5 pattern .
Norm is offline   Reply With Quote Quick reply to this message
Old 06-02-2011, 11:50 PM   #11 (permalink)
Member # 145894
i put 22.5's on mine and love em.
Torrance is offline   Reply With Quote Quick reply to this message
Old 06-02-2011, 11:53 PM   #12 (permalink)
Member # 145894
make sure you get your speedometer recalibrated. it makes your tranny shift correctly and your truck thinks its still on the factory wheels. and i even think my overhead mpg guage is working properly
Old 06-03-2011, 12:19 AM   #13 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
Interesting. Thanks for the link
2nd gen or 3rd gen??
Old 06-03-2011, 12:26 AM   #14 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
I cant see your pics. Our net filters dont allow photobucket for some reason. The 22.5's are cool, just not something I think I'd like on my truck
I do need to recalibrate for the speedometer but I have a 6 speed manual so no worries there.
Old 06-03-2011, 09:16 AM   #15 (permalink)
lurchseesu's Avatar
Member # 112455
Now how long before some dumb fuck comes in this thread and says "Those 245's are going to bulge and rub each other as soon as you put a load on it!" With your 14 ply tires.
lurchseesu is offline   Reply With Quote Quick reply to this message
Old 06-03-2011, 11:16 AM   #16 (permalink)
MattyB4x4's Avatar
Member # 32726
:blackflipoff:
Toyota buggy - duals + 4.7, 40's, linked rear/fox airs, shift knob
ΜΟΛΩΝ ΛΑΒΕ
MattyB4x4 is offline   Reply With Quote Quick reply to this message
Old 06-03-2011, 01:13 PM   #17 (permalink)
Member # 117771
:blackflipoff:
X2
Plus with the added rotational mass of the larger wheels and tires and no brake upgrade he's going to kill a school bus full of nuns.
Old 06-03-2011, 02:21 PM   #18 (permalink)
Member # 86724
when you decide that they're dangerous you can ship them to me for proper disposal, free of charge.
Old 06-03-2011, 02:29 PM   #19 (permalink)
Member # 145894
give me your address. there on their way. lol
i love them. and no braking problems.
Old 06-03-2011, 02:36 PM   #20 (permalink)
Member # 145894
[QUOTE=Azzy2000;12965667]I cant see your pics. Our net filters dont allow photobucket for some reason. The 22.5's are cool, just not something I think I'd like on my truck.
weird yo cant see the pics. ive never had a problem before. i got deals on my setup. adapters new-$550, new wheels-$1100, 7 like new tires $250. and mounting and balancing $250, so about $2000 for everything. i even found used 22.5" aluminum rim for free for my 7th tire. so i got a spare.
Old 06-03-2011, 07:06 PM   #21 (permalink)
Member # 17632
To the OP, looks like you have 2 different style of center, do they all have the same offset?
Travis..
'15 Ram 2500 4x4 Big C and a 6 speed
2000 TJ on 35's
crashnzuk is offline   Reply With Quote Quick reply to this message
Old 06-03-2011, 07:20 PM   #22 (permalink)
WHEEEEEEEEEE!
gavan's Avatar
Member # 22597
Send a message via AIM to gavan
Attached pics because:
1. I am stuck in this Houston heat and bored, and Azzy is probably in the same boat
2. One of the few decent 22.5 conversions I have seen.
What is the size/actual height of those?
gavan is offline   Reply With Quote Quick reply to this message
Old 06-03-2011, 08:53 PM   #23 (permalink)
Member # 17632
Those look pretty small, maybe 8.00x22.5?
Travis..
2000 TJ on 35's
Old 06-04-2011, 12:13 AM   #24 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
X2
I side swiped a bus full of orphans on the way to work, forcing them off the road and bursting into flames after hitting an animal shelter... There were flaming kittens, puppies and orphans everywhere
[QUOTE=Torrance;12967722]
It's just our nazi-esque net filters here at work. I cant see my pics either.. I posted them up from home the day before I came offshore.
Travis..
Good eye. Yes, two of the are slightly diffrent even though they all measure the same.
Old 06-04-2011, 12:18 AM   #25 (permalink)
Mr. Personality
Azzy2000's Avatar
Member # 11869
I'm out on a rig in the gulf right now, but I'm feeling the heat too.. Been too busy to be bored though
