How to calculate what size trailer I need
I've spent the last 3 days looking at more trailers than I care to think about. The things I have noticed are the inconsistencies from manufacturer to manufacturer on what frame sizes they use on car/equipment trailers. So far I have seen:
3x5 Angle (with 4" channel tongue) 4" Channel 5" Channel 6" Channel 2x4" Tubing These are on 16' and 18' 7k & 10k car trailers. How do I calculate the frame strength, and is there a rule of thumb as to calculating this? Are there industry standards for frame size vs. length vs. capacity? My goal is to maximize the load capacity of the trailer, while keeping under a 10k loaded trailer weight. Last edited by GRMhick; 06-30-2011 at 12:34 PM. |
Evil Twin
IMHO for most people 5" channel perfect for 10k trailer, 4" good for 7k. I would also find a mfg with the double stacked tongue. This is where the tongue is a 2nd layer under main frame and extends back roughly to the first spring hanger.
Many manufactures have a standard frame and simple toss different axles under it. It's ok if its where you need to be, if not you end up with a heavy ass trailer for no reason.
Mike Yager - Jeep TJ Build Up - Ecotec, Toy axles etc.. Ecotec - Technical Info E450 Ambulance VRAY (YAger RV) VRAY 2006 E450 - Ambulance Cummins Diesel Swap |
Member # 153116
stick with channel.. angle frames twist and need the side rail to stiffen them up. and i've made the mistake of buying a box tube frame car trailer. the frames rot horribly! all the screw holes for the decking leak water into the box tube and the water sits and rusts the frame rails and crossmembers out
IDIot!
Member # 44480
Unless you go stupid thin, depth of your frame members is stronger for weight than additional thickness.
C5x6.7 has a ~3/16" thick web. C5x9 has a ~5/16" thick web and not a lot more stiffness.
Motive Gear Land Use Team http://www.tenfactory.com http://www.motivegear.com http://www.nationaldrivetrain.com http://www.davezoffroadperformance.com http://www.mastercraftsafety.com FToy 086 - UHaul Toterhome |
108" Smurfmobile
Member # 1494
I think any 7-10K trailer will work for what you're talking about. I have a 7K Carson car hauler that I put 10K (dual 5200's) running gear on, and a new coupler and have had it at 9K a bunch of times, and over 10K for 3 trips from CA to CO. On the smaller trailers as long as you have the "stacked frame" as mentioned above, you should be fine. mine is channel also.
Only way I'd go boxed frame is if it was aluminum.
Peter S. Di Primo PSD Enterprises, LLC - Waterjet, laser, metal forming, CNC work, Fiberglass and Carbon work, patterns and molds. No job too small. Prototyping and small production is our specialty, but we have the network to handle large jobs as well. Email me if you need something cut, bent, formed, milled, machined, etc. Founding Member - VCAS4WDC www.axlesnappers.org Help Fight Global Warming- turn your A/C on high and open all your windows. Alcohol, Tobacco, and Firearms should be a convenience store - NOT a government agency!!!! Last edited by YellowSub1962; 07-01-2011 at 08:02 AM. |
#6 (permalink) | |
Member # 106806
Replaced the frame on mine once already.
my build: [url]http://ovo.ca/forums/showthread.php?t=867[/url] |
