#26 (permalink) |
Member # 129263
We did not get the weight before the race build but I know we will be lighter when we are done. We will be weighing it once the cage is complete. There is still alot of work to do caging the engine and tieing it back into the main cage also adding some more cross members to weld the new seats into. It will also have tube doors.After all of this work is done we will be weighing and re working the triangulation on the rear links.
#27 (permalink) |
Member # 177190
Cool. Sorry I had assumed the build was just getting wrapped up now since you had your "press release" and that you were just staging your posts in here over a few weeks. Look forward to hearing what the weight is when you get around to it.
#29 (permalink) |
Member # 129263
Advance Adapters/ JE Reel/ TRD Parts4U
Here is the Atlas installed and let me tell you something about Advanced Adaptors. They have to be one of the best places to deal with in the industry. I have never had such good customer service on such a superior product. What can I say THEY ROCK!
![]() The same goes for JE REEL Drivelines.They have been so good to me and done such a great job that I would recomend them to anyone.They built drivelines for my FJ 40 as well and everything has been perfect! ![]() Not to be out done is TRD Parts4U.The supercharger and all related components were easily installed and all I can say is that Mad Dog is alot faster.I know that there is alot of discussion about the different kind of Super chargers and which ones are the best for the 4.0 engine and I really do believe that this is the best one for us. I am not going to go into all of the Dyno #'s because they would be scewed from all of the other mods which drive the #'s up substantially and I wouldnt want anyone else to have unrealistic expectations. I can tell you that this thing is fast! ![]() ![]() New batery location behind the passenger seat ![]() New shifter set up,no reverse lock out.also clears the Atlas shifters better, I still want to offset the T case shifters away from each other so that my hands dont hit when shifting.
#31 (permalink) |
Member # 188478
Damn, did you get a brand new Atlas (I know you already had one)? Mine is less than a year old and looks WAY older than yours.
I like the look of the REEL. I think FJLED was looking at that same CV style driveline on his beast. Finally, the TRDParts4U guys are great. Jacque, Barb and Steve are good people. I have bought plenty from them and I will probably be buying my supercharger from them as well. |
#32 (permalink) |
I break shit
Member # 142241
I'd loose that forward cup holder and move the 2wd/4wd over there and put some space between the 2 range shifters.
Looking real good Jeff!
07 FJC 3 linked up front and stuff |
#33 (permalink) | |
Member # 129263
Works best for maximum droop. JE Reel will help you with the measurements and make what ever you need. As I said the SC install was realativly easy compared to some of the others out there especially when it comes to the cooler. |
#35 (permalink) | |
I break shit
Member # 142241
07 FJC 3 linked up front and stuff Last edited by plnfixr320; 12-05-2011 at 09:37 AM. Reason: "sphelling" |
#38 (permalink) |
"ehh...you got that"
Member # 126355
I would ASSume that it was because lefty's suck and make too much gear chatter as it is, and the Atlas brings much more beef to the table, not to mention more gearing options.
Im gunna bow up on that like a show dog! DD: 91 Xcab--4D's, chromo 60's, duals, locked...just the necessities |
#39 (permalink) |
Member # 177190
Depends on what gears are being run in the lefty. I do agree that Trail Gears or Marlin's XD series are not going to be the most suited for the FJC. 4320's should hold up much better along with 30 spline outputs. I had the prior which didn't last long with my heavy right foot. Later held up well and is now being run by another supercharged FJ. Gear chatter was never a major issue on any of the lefty cases I had. Now moved onto a blackbox + atlas...Don't have to modify the OEM gas tank with an atlas + crawlbox like you do with an OEM + crawlbox or dual lefty cases.
#40 (permalink) | ||
Member # 195104
Just curious as I've been contemplating switching in a FJC T-Case (Twin-Sticked) + Marlin Crawlbox into my Tacoma to get a better range of gears (there are a few on the Toyota Forums who have done this) and wondered the advantages of the Atlas vs this setup. Switching in the FJC T-Case eliminates the Electronic actuator that the Tacoma T-Case has, which easily malfunctions. So you (FJLED) are running a Atlas 2-Spd paired with a black-box instead of 4-Spd Atlas? Last edited by theduck911; 12-27-2011 at 05:33 PM. |
#41 (permalink) | ||
Member # 177190
The early lefty's had quite a few issues. Under sized output shafts and quite a few issues with TG's 4lo gear setup lasting (and noisy). Marlin's xd series broke on mine. In order to have a lefty that is suited for the weight and power these late models produce I'd really suggest running 30 spline outputs and 4320 low gear sets (23 splines). For the additional cost (couple hundred) you are getting a significantly stronger gear set. Honestly the lefty is a fairly clever design (packaging). It fairly easy to clock the lefty setup to fit within the drivetrain tunnel and sit above the frame rails. On the other hand you have an Atlas, which while not as elegant makes up for it with a larger gear set (inherent strength). With the additional size and strength comes additional weight...Atlas 2 is nearly 50lbs heavier than a lefty. Folks tend to build a tail shaft support in addition to the basic crossmember for the additional weight. Unless you chop out your drivetrain tunnel it will hang low below the frame rails. Modifying the tunnel you can and clocking the case you can get it above the frame rails. Atlas offers more gearing options and imo they've been more tested in setups that weigh near and run similar (or more) HP than than the newer yotas. See em used in the majority of competition vehicles. Haven't ridden around with mine yet, but from what I've heard the Atlas 2 is supposed to be quite quiet which is defenitely to be appreciated in a daily driver. Summary: Lefty - bolt on option that can be reliable (properly setup) and be raised above the frame rail Atlas - bolt on (FJC at least...I'm sure a taco interface plate is available), strong and reliable, need to brake out the sawzall to get it above the frame rails. Also will probably need to modify your driveshafts. Each has their suited users for these newer yotas. Lefty is more suited for those who just want to bolt on lower gearing and gain some ground clearance. Atlas is going to be more robust (setup properly), but require some sheet metal modifications to buy you ground clearance. Mad Dog's build and mine illustrate what needs to be done on an FJ to do so...guessing a taco's similar. Yes that is correct Atlas 2 + i-blackbox fron NWF. |
#42 (permalink) | |
Member # 195104
I was unaware of the gas tank fitment issues with the FJC and the Crawlbox. The Lefty of what I've read is more suited to my needs, an avid/weekend wheeler, looking for a more bolt-on lower-gearing range and slightly more ground clearance. I have yet to find a newer (05+ Taco) that has had an Atlas installed. Even Wyatt is running the FJC T-Case + Crawlbox. |
#44 (permalink) |
Member # 129263
Update
Happy New Year!
Some one tried to steal my Super Duty over the holliday luckily the anti theft kept them from starting it but they di rip out the door lock and the ignition and they stole my camera so I found this cheap one that some one gave me and so these pictures suck. We recieved our new MasterCraft seats and tied tubing into the frame got the seats welded in. These seats are great and it just feels alot safer when you are sitting in them. ![]() ![]() ![]() ![]() Metal Tech Tube doors are going to give us some much needed visability. ![]() We tied the front shock mounts back into the main cage and the frame and will connect them from side to side in front of the engine. It is a pretty tight fit but the tripple bypass and coil overs cycle nicely. ![]() ![]() ![]()
#46 (permalink) |
King of the Ropes
Member # 146603
I just got a Toyota 4wd Owner Mag with this in it!
![]() -Alex
Master Pull Recovery Gear - The World Leader In Synthetic Rope 10% PBB discount http://www.MasterPull.com -- Recovery Gear of the ‘10 and ‘11 Griffin KOH -- Official Recovery Gear of Cal-Neva Extreme and Area BFE in Moab |
#48 (permalink) | |
Member # 129263
I think we will do good in the woops but there is alot of comp and 3 miles is not really enough to show what you or your car is made of. with all of this in mind I would consider running a smaller tire for the LCQ and if we qualify change back to the 40's for the race. Really wish I knew the coarse but of coarse so does every one else! I'm getting stoked! |
#50 (permalink) | |
Member # 177190
From my thread
