Member # 129263
All Pro/ Mad Dog Ultra FJ Race Build
I have been anticipating doing this build thread for some time now and as the time draws near for our press release and KOH is on the horizon I believe that the moment is right. I will begin with some of the current specs and then go back to when we started the actual race build and go from there.
We can enter into more technical discussion as we go and I will do my best to answer any questions.This is going to be a long process so here we go! Specifications Vehicle: 2008 FJ Cruiser Engine: 4.0 V-6 TRD Super Charged, AEM Intake,Custom Dual Exhaust. Tranny: T400, Hayden Cooler T Case: Atlas 4 speed 3.8:1 Front Axle: Currie Rock Jock 2 Dana60, Currie Chromoly Shafts, ARB Locker,4.88 Motive Gears,Warn Hubs Rear Axle:Currie Rock Jock2,Currie Chromolly Shafts,ARB Locker,4.88 Motive Gears Steering:All Pro Pitman Arm, Howe Ram Assist. Brakes: WilwoodDiscs, Dynalite 2 Callipers Front Suspension: All Pro 3 Link,Fox 2.5 14" Travel Reservoir Coilovers, Fox Triple Bypass Rear Suspension: All Pro 4 Link, fox 2.5 16" Travel Reservoir Coilovers, Fox Triple Bypass. Wheels: 17x8.5 Walker Evans Beadlocks Tires: 40x14.50R20 BFG Krawler t/A KX's Here a couple of pictures so you will know what we started with. ![]()
Member # 129263
Someone asked if my goal was to be really serious or just finish the race.You know that you have to be serious to just finish the race,in our case we have to be serious to qualify in the LCQ which also aswers the question about us buying our way in. Let me just say that we are going to drive like hell and this thing better hold together.
Even though we already had the rear cage complete it wasnt suitable for the new suspension that we had in mind and the frame was in the way so out with the not so old. ![]() ![]() ![]() This picture is of some of the preliminary cage and suspension work, we needed to get the shocks farther out on the axle and make room for the bypass. THis set up also allowed for alot more options with the configuration of the links.
Member # 177190
So the plan is to run the unilimited then and not the mod class? Looking forward to seeing the build, rear byapss look nice. You keeping the stock dash or is that going as well?
plasma dust huffer
def keeping an eye on this build. good luck
Duramax and LS based motor tuning Offering in House Custom CNC Plasma cutting services, we can take your idea from design to your doorstep. have a sketch you want to become parts for your project? pm me, i can help. parts are shipping out daily "it makes the mach5 look like a vagina" - ARCHER |
#8 (permalink) | |
Member # 129263
I was able to fit the temp guages into the factory set up just needed to carve out the holes about 1/8" ![]() Here you can see the guages installed and the GPS ![]() This shows some of the rocker switches the lower left is the inside winch control
King of the Ropes
Member # 146603
Wow this is quite the undertaking. Good luck!
-Alex
Master Pull Recovery Gear - The World Leader In Synthetic Rope 10% PBB discount http://www.MasterPull.com Official Winch Line of W.E.Rock -- Recovery Gear of the ‘10 and ‘11 Griffin KOH -- Official Recovery Gear of Cal-Neva Extreme and Area BFE in Moab |
Member # 129263
Pictures of the link connections to the frame.
![]() This is the adjustable upper ![]() Since we are planning on running different sized tires depending on the style of race the triangulation was difficult. The KOH is a tough one because you would want your #'s to be different for the rocks than in the desert but you have to accomodate both. As far as tire size we will be running 40's for KOH and as small as 35's for Reno to Vegas. So you pretty much need to come up with something that is not the best for either but is still good for both. Last edited by Mad Dog 1; 11-16-2011 at 01:28 PM. |
#14 (permalink) |
Member # 129263
Getting the fuel cell back in.This is a 12Gal.Cell which even for KOH is probably a little small but would work because of the pit locations but for something like the Reno to Vegas race we will need more but I wont be sure how much more until we see what kind of millage we are getting in the desert at speed. I think for KOH we can plan on about 5 MPG.
![]() Upper and lower shock mounts welded up ![]()
#15 (permalink) | |
Poor Little Fella
Member # 118580
Subscribed. Cool to see there will be a full-body (mostly?) Toyota in the race. Good luck!
Jake August 85 4Runner Click here for Oregon Wheelin' Videos! Quote:
#19 (permalink) |
Member # 129263
update
Here are afew shots after she got back on her feet and headed for Tucson.
![]() ![]() ![]() ![]() ![]() Before we start the front end we needed to get all of the engine mods done and relocate all of the electrical from the engine compartment.This will all be done at performance Toyota in tucson. Tim there is known for building some of the best toyota racing engines in the industry and has alraedy installed a T400 on an FJ Cruiser so he was my choice to do our work. He will be installing the T400 Tranny and TRD Super Charger, fuel rails injectors ect. He will also be moving all of the elctrical and installing a pigggy back programing unit. Last edited by Mad Dog 1; 12-16-2011 at 04:15 PM. |
#20 (permalink) |
"Racing for Access"
Member # 86691
Wow, interesting. I hope you do the lcq and get in legitimately unlike that giant trail plug the poison spyder jk I had to drag that thing outta the way just to keep traffic flowing. Thank god we are qualifying for start position this year. Oh and BTW its Vegas to Reno, not reno to Vegas. Good luck.
KOH and BITD Competitor #4405 FISHMOUTH FABWORKS ![]() MASTER-PULL Recovery gear Pacific Fab, Ruffstuff Specialties, Reid Racing, Team Tube, Raceline Wheels, Goodyear Tires, Yukon Gear, 4130 Clothing, Blue Torch Fab, Artec, Bulldog, PRP, Concept Wraps |
#21 (permalink) |
Member # 123101
Stoked to see this thing run..
85 Yota shortbed, 5.29's,detroit, 6 shooters,,30splines, spool, duals w/ 4.7's, beadlocks,37 Pitbulls... still not done ------------------------------ 2003 F250 Crewcab sb v10 |
#22 (permalink) | |
Member # 129263
We are in LCQ , I wanted to pre qualify in one of last years races but just couldnt get this thing done in time. I wouldnt get into the race any other way, and I guarantee nobody will be draging us out of the way. |
#23 (permalink) |
Member # 98667
Something else to think about...I don't think V2R was an Ultra4 race this year. I could be wrong but it deffinately was not a qualifier. 2012 may be different.
Degenerate |
#24 (permalink) |
Member # 129263
Mad Dog in Tucson
Mad Dog finds a new home in Tucson for 3 long months.
![]() Woody gets tossed aside. Kind of sad isnt it? ![]() The T 400 gets checked for clearances. ![]() New converter and input
