Disable Seatbelt Alert - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Brand Specific Tech > Toyota - FJ Cruiser
Old 04-09-2007, 12:38 PM   #1 (permalink)
Member # 89258
I am so sick of having to put on and take off my seatbelt while four wheeling, due to the seatbelt beeping alert.
Does anyone have an idea on how to disable this? I know there has to be a way to do this.
Let me know....
FJBruiser is offline   Reply With Quote
Old 04-09-2007, 06:31 PM   #2 (permalink)
Member # 10889
Send a message via AIM to offroadbarn Send a message via Yahoo to offroadbarn
i grabed one from the junk yard. click it in beeping stops!!!!!
offroadbarn is offline   Reply With Quote
Old 04-11-2007, 11:38 AM   #3 (permalink)
Member # 2619
Send a message via ICQ to DCruiser138 Send a message via AIM to DCruiser138
when you first start the bruiser, hold the odometer reset button for like 5 seconds and while holding click your seatbelt in and it should give you the option to turn it off with the reset button. try that out youll be so used to slamming your belt on to shut it up so at least a good habit has been implemented
Dustin Crawford ---
OPEN DIFF DEUSH'
DCruiser138 is offline   Reply With Quote
Old 05-29-2007, 08:31 AM   #4 (permalink)
Member # 81092
Most seatbelt warning systems are triggered off a two wire lead coming from the seatbelt latch. You could theoretically either permanently connect those two wires to avoid ever having the alarm, or install a switch in the location of your choice to kill the alarm by connecting the necessary wires. That having been said, I agree with the other dude that suggested that the alarm itself probably fosters a positive habit. Tampering with such a safety system should be given careful consideration...
txapacheguy is offline   Reply With Quote
Old 06-05-2007, 12:11 PM   #5 (permalink)
mda
Member # 11212
The following worked on my 06 Avalon and seems to work on most other Toyota cars in the 06 - 07 range.
1. Turn the ignition ON but don't start engine (Ignition ON by pressing ENGINE START STOP button twice with foot OFF the gas)
2. Make sure speedometer is in odometer (ODO) display
3. Turn ignition OFF
4. Turn ignition ON again without starting it
5. Press and hold odometer button. After 10 seconds and while still holding the button, buckle your seat belt.
6. ODO display will change to b-on or b-off depending on the pressing of the odometer button.
7. When odometer is set to b-0ff you are done!
mda is offline   Reply With Quote
Old 06-05-2007, 02:58 PM   #6 (permalink)
Member # 30064
Get in start FJ and TURN VOLUME UP ON CD PALYER Thank god for the sub..lol
#421 TEAM DIGGER
2009 Driver- Giles Verheecke
2009 Spotter and driver- Chris Endres
Team Digger web site now up www.teamdigger.com
RROCK and WE-ROCK competitor
Sponsored by : Digger Customs, Cooper tires, CTR Automotive, Napa , and Branik Motorsports
unimog12chicks is offline   Reply With Quote
Old 06-05-2007, 05:28 PM   #7 (permalink)
pkhart's Avatar
Member # 5199
Send a message via AIM to pkhart
Read the manual.
pkhart is offline   Reply With Quote
Old 10-02-2007, 09:21 AM   #8 (permalink)
Member # 40176
Beeping Seat belt alarm
Does this really work?
chevota87 is offline   Reply With Quote
Old 10-05-2007, 10:05 PM   #9 (permalink)
Member # 46332
I just unpluged it under the seat...works great
Axlesnap is offline   Reply With Quote
Old 11-29-2007, 09:34 AM   #10 (permalink)
Member # 25737
Answer is in the manual. At the end of the seatbelt information section.
Townsend
Boise
'94 D90
Townsend is offline   Reply With Quote
Old 07-18-2008, 08:04 PM   #11 (permalink)
Member # 116264
buckle.... then sit in the seat, and i agree with the saftey concerns
vblextek801 is offline   Reply With Quote
