fjc axle gusset - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Brand Specific Tech > Toyota - FJ Cruiser
Old 05-31-2009, 08:56 PM   #1 (permalink)
Member # 135146
fjc axle gusset
does any one make a gusset for the rear axle housing fjc ..cause a lot of people are bending them and i dont want to change the rear yet
scrap iron is offline   Reply With Quote
Old 05-31-2009, 09:03 PM   #2 (permalink)
GRMhick's Avatar
Member # 87
Location: I live in hotels tear out the walls I have accountants pay for it all
Send a message via AIM to GRMhick
http://www.diamondaxle.com/index.htm
GRMhick is offline   Reply With Quote
Old 05-31-2009, 09:17 PM   #3 (permalink)
Member # 135146
thats kool if i had the money and all but i like my old axle and just want it to last a little alonger im looking for a truss for it
Old 05-31-2009, 09:21 PM   #4 (permalink)
Member # 135146
never mine i see
Old 06-01-2009, 09:19 AM   #5 (permalink)
GRMhick's Avatar
Member # 87
I've never bent an FJ housing, or seen one bent, so I am assuming its a pre-runner thing.
In my experience with toyota axles, if your going to push them to the point of bending, a truss will not help very much. Do it right the first time and buy a new housing.
Old 06-01-2009, 09:24 AM   #6 (permalink)
Brian Ellinger's Avatar
Member # 1088
I have seen very very few properly built/installed trusses. Almost 100% of what we've seen helped the axle to fail earlier, by concentrating stresses, or warped the housing on install.
Thank you to our loyal customers!
Diamond Axle
Diamond axled buggies take 2 1st's, at Worlds WEROCK!!
Front Range Off-Road Fab with NEW forum!
http://www.frontrangeoffroadfab.com
NEW BUILD FTOY #44
/forum/toyota-formula-toy-forum/562295-front-range-builds-new-toy-old-toy-44-a.html
Brian Ellinger is offline   Reply With Quote
Old 06-01-2009, 02:25 PM   #7 (permalink)
BellyDoc's Avatar
Member # 100273
Sol apparently bent the housing on his rear end and he's not really a pre-runner kind of guy that I know of. He posted up about it after having already solid axle swapped the front end.
The FJC is a HEAVY beast. It doesn't take a lot for people to exceed the gross vehicle weight rating. I know of a LOT of poeple who are at that, or in excess of it, on their original rear end and IFS.
Although Sol is the only one I've heard of reporting this. I don't find it surprising to hear that there may be others.
An axle truss from flange to flange would be a good solution if it were installed properly. That's a lot of heat to lay down, though. I can see why it could lead to immediate shrinkage and bending.
-Jon-
MFS/Pirate4x4 essay contest winner
KOH 2010 survivor
Surgical precision with a BFH
BellyDoc is offline   Reply With Quote
Old 06-01-2009, 03:45 PM   #8 (permalink)
GRMhick's Avatar
Member # 87
Sol also bent the axle after he swapped to leaf springs, thus concentrating the stress in different parts of the housing than originally designed. Also, his springs were WAY too soft for the truck (I know very well... those deavers are on my truck now), which I am sure helped bend the axle.
Old 06-01-2009, 04:04 PM   #9 (permalink)
BellyDoc's Avatar
Member # 100273
So... if the springs were too soft, are you saying he was smacking the bump stops too much?
-Jon-
KOH 2010 survivor
Old 06-01-2009, 05:38 PM   #10 (permalink)
GRMhick's Avatar
Member # 87
It would hit the bumpstops on any bump. When the springs were installed on my 'lighter' truck, the truck was .75" off the bumpstops, and would go to the bumpstops if I sat on the tailgate.
Old 06-01-2009, 07:49 PM   #11 (permalink)
Member # 1088
Sol's also had somewhat of a brace on it, which I believe warped it. (looking that how it was bent) The tubes were also dented significantly from the ubolts. I have gotten several other customers reporting bent housing however. Use/abuse/tires, etc I dont recall though. These housings are only 3/16" thick, so it doesnt take a ton to tweak them. Under stock trucks it is going to take a decent bit of abuse though.
Diamond Axle
NEW BUILD FTOY #44
http://www.pirate4x4.com/forum/showthread.php?t=562295
Old 06-01-2009, 08:48 PM   #12 (permalink)
Member # 135146
well i guess its time to buy a new axle housing so should i have it made with a truss on it or what do u think doc.
Old 06-02-2009, 06:30 AM   #13 (permalink)
Member # 84124
I know of at least 2 people beside me that bent their rear housings. One is runnning a SFA with coils in the rear and the other person was running the stock setup under a heavy caged truck. There have been others that have posted that they think they have a bent housing, but no one has confirmed it.
Do yourself a favor and order a new housing from Brian @ Diamond Axle and fix the problem the right way. The Diamond housings do not need a truss with the thick wall tubes. I have beat my Diamonds and they still looks new.
sbechtold is offline   Reply With Quote
Old 06-02-2009, 06:36 AM   #14 (permalink)
BellyDoc's Avatar
Member # 100273
I don't know that you really NEED to do anything.
If you're not (significantly) exceeding the weight rating, then you probably don't need a ring and pinion upgrade, and if you're not denting the housing, you probably don't need a preventive upgrade to a thicker part.
If you're thinking about an upgrade, All-Pro has a bolt up rear end which I believe is based on the Currie Rock Jock D60. That gets you a thicker housing and a larger ring and pinion set. It's got all the link mounts ready to go. I don't know if it's full float, though. That would be cool.
Toyota rear ends are nothing to sneeze at. The FJ Cruiser axle is capable of meeting a lot of challenges. By the time you're exceeding it's capabilities, you're probably going to be thinking about the front end first.
-Jon-
KOH 2010 survivor
Old 06-24-2009, 11:44 PM   #15 (permalink)
Member # 133570
Here is a diff skid that also supports the axle housings. Available at TRDparts4u.com (Toyota of Dallas)...
The only clearance that is lost is the thickness of the material (1/4"). It is designed to work w/ All pro E-locker guards and with most skid plates (some skid plate trimming may be required) . It can be left on the FJ while servicing (i.e. changing diff fluid).
Give those guys a shout and see what they can do for ya...
Digger
Digger422 is offline   Reply With Quote
Old 06-25-2009, 05:24 AM   #16 (permalink)
BellyDoc's Avatar
Member # 100273
That's a nice skid plate but it adds exactly zero percent increase in strength or stiffness!
A gusset system for axle reinforcement adds vertical material that takes bending deflections of the housing as shear force.
Your skid adds no vertical height, it relates to the pumpkin and not the tubes, and it hangs from clamps. If the housing is going to flex, it'll flex right through that skid plate.
-Jon-
KOH 2010 survivor
