Do anyone run HID setup on their FJ - Pirate4x4.Com : 4x4 and Off-Road Forum
Go Back   Pirate4x4.Com : 4x4 and Off-Road Forum > Brand Specific Tech > Toyota - FJ Cruiser
Old 06-02-2011, 04:57 PM   #1 (permalink)
MikeyD1's Avatar
Member # 109758
Hi i have a 2007 Fj cruiser and i was interested in going to a xenon headlight setup on mine however has anyone done this and what did you do to make it work.
thanks
1986 toyota 4runner "project"
2007 toyota FJ TRD "DD" 1999 rover "personal vehicle"
MikeyD1 is offline   Reply With Quote
Old 06-06-2011, 08:23 AM   #2 (permalink)
Member # 129263
I have these on mine and they are fairly simple to install just like replacing the bulbs. There is a relay that you install and the wireing is easy they give you good instructions when you buy the kit.
Mad Dog 1 is offline   Reply With Quote
Old 06-10-2011, 09:04 PM   #3 (permalink)
MikeyD1's Avatar
Member # 109758
awesome thanks what kit do you have.
Old 07-16-2011, 07:53 PM   #4 (permalink)
Member # 108898
Send a message via AIM to limetym51
dimensions ?
anybody kno the diameter of the lens?? are they standard 7 inches across?? i want to use the 10000K black halo projectors on my old 50's chevy.. thanks
limetym51 is offline   Reply With Quote
Old 07-17-2011, 09:40 PM   #5 (permalink)
PARANOID56's Avatar
Member # 5114
Send a message via AIM to PARANOID56
so you want to put lights that put out less light then stock? 10k hid is almost purple. the best ones are the 4300-5000.
and also putting HIDs in halogen lights just blinds everybody, please dont do it.
1971 FJ40 w/ rust Build up
2003 Toyota Taco double cab
2008 Subaru Impreza STI
1998 Honda XR650L
TLCA member #12202
PARANOID56 is offline   Reply With Quote
Old 07-17-2011, 11:14 PM   #6 (permalink)
Member # 108898
im either going to run 8000 or 10000 projector lamps not halogen / hid's .. and no matter, any of them will be brighter then the stock 1950's sealed bulbs.. lol but anyone know the diameter of the lens??
Old 07-18-2011, 04:39 PM   #7 (permalink)
Member # 129263
Xennon Light Kit
Old 04-16-2012, 09:47 PM   #8 (permalink)
Member # 216655
Check out classic chevy stores or impala bobs. I've seen a projector headlight made to drop into older cars..they are sweet!
The Fj lights are to big and the baskets will need a lot of modifications to make them fit
Ojedaxx is offline   Reply With Quote
Old 05-10-2012, 07:14 PM   #9 (permalink)
Member # 147492
Send a message via MSN to exist
HIDS in reflector housings are retarded, don't waste your time..
Contact theretrofitsource.com and consider a full on retrofit with proper projectors. The owner has an FJ with Infiniti Q45 multi-lens projectors (formerly Lexus LS430 projectors)
You can do a Mini D2S or Mini H1 projector and bulb/ballast/shroud etc. setup that is essentially drop in. Pop lens off, side projector in, tighten nut, connect hids.. Done..
toexistphoto.com
exist is offline   Reply With Quote
