CO- Formula4 Build - Page 3 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-05-2012, 12:39 AM   #51 (permalink)
Member # 108480
Started working on mounting the chassis
Formula 4 build in progress:D
ColoradoToy91 is offline   Reply With Quote
Old 03-05-2012, 07:54 AM   #52 (permalink)
Member # 29970
Look good, can't wait to see the finished rig! I'm seriously thinking of going the same route
Addicted Off Road
VolcomCO is offline   Reply With Quote
Old 03-18-2012, 07:39 PM   #53 (permalink)
Member # 108480
Looking for some advice on my drive shafts-
The Front from flange to flange is 40"
The Rear from flange to flange is 52.5"
I am thinking about doing a 12.5" rear shaft to a carrier bearing and then a 40" shaft to the rear third. This will allow me to run the same length shaft front and rear. It sounds good to me, but I am unsure about the length of these shafts since this is the first long wheel base rig I have built/worked on.
Constructive feedback? Will a 40" shaft on either end be a rock anchor?
Wheel base came in at 119" btw
Old 03-18-2012, 08:40 PM   #54 (permalink)
Member # 9771
I have a 119" wheel base on my Formula Four and I run two single drive shafts. The front shaft is square tube and can be used in the rear. I never worry about them on the rocks. You just have to pick the best line for your rig.
I like to stack rocks on the trail.
chvyhs is offline   Reply With Quote
Old 03-18-2012, 08:44 PM   #55 (permalink)
window licker
artj123's Avatar
Member # 207564
lots of the ftoys run a carrier bearing on the front shaft for that reason. the only thing i can think of being a down fall is the tube in the rear holding the bearing. you might want to run a little longer shaft to take the angles alittle better. if you do it right 10'' of travel is possable with leafs so think about full droop. also longer shafts dont change lenth as drasticly so you could save on the slipshaft if you can recycle oem stuff. i bought an 18" slip from extream enginering and had them do it for me because didnt have a lath at that time and it was like $250. just a thought.
artj123 is offline   Reply With Quote
Old 03-18-2012, 10:41 PM   #56 (permalink)
Member # 123429
i did the same thing in my four seater two 39'' just have to buy two long slip yokes
seriousscout is offline   Reply With Quote
Old 04-01-2012, 10:35 AM   #57 (permalink)
noob
Member # 66544
I ran full length square drivelines in mine, they did occasionally make contact with a rock or two. The beauty of the square drivelines is that they are as tough as the rocks. Some may recall an incident where I repeatedly tried to make a climb in Tucson bringing the full weight of the rig down on the driveshaft over and over. Driveshaft had a slight bend. From time to time it was also nice to put the driveline on a rock intentionally and walk the rig over. Obviously the speed limitations are the downfall of the squares. If you decide to go that route I still have three of them I am tripping over on the garage floor, one has a slight bend.
El Destructo! I void warranty's!!!
Team Rock Limo
F-Toy #F002
Yukon gear/Randy's Ring & Pinion, Trail Gear, BFGoodrich Tires, RuffStuff, 12 Volt Guy
noahfecks is offline   Reply With Quote
Old 04-01-2012, 05:07 PM   #58 (permalink)
Member # 108480
What are the lengths?
Old 04-01-2012, 06:09 PM   #59 (permalink)
Member # 108480
Got a lot more done over the past few weeks. I need to take the chassis over to Blast Tech to get the rust removed before I mount it permanently. I made the decision to skip the carrier bearing for the rear shaft. This will be street legal so I am going to have to try and balance a heavy wall rear drive line. Some Pictures:
Overall shot as a roller
Front Shackle Angle
T-case is ~1/2" below the frame. Not a flat belly for two reasons- 1. I don't have a 10* rotated adapter due to the single case 2. And as a result to get the passenger seat to fit decent the t-case had to be lowered from flat belly height.
Drive Train Shots
Started Working on the Taurus fan for my radiator
Old 04-01-2012, 07:57 PM   #60 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
How about that rust convertor primer? I don't think the rust was that deep.
You're not planning to powder coat it, are you?
MT4Runner is offline   Reply With Quote
Old 04-01-2012, 08:08 PM   #61 (permalink)
Member # 108480
I hit a large part of it with one of these
and it took the rust off. IT was super time consuming though. I have never heard of rust converter primer
Edit: Not powder coating- spray paint and maybe some roll on hammered paint
Old 04-01-2012, 08:35 PM   #62 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
When I first finished my buggy, I wished I had powdercoated it.
Now that it's 4 years old, I like being able to touch up spray paint. Whatever color you pick, buy a half dozen extra cans for touchup (just in case your favorite hammertone paint gets discontinued or something).
Old 04-01-2012, 10:24 PM   #63 (permalink)
Member # 108480
New Idea after some searching
http://www.pirate4x4.com/forum/showt...ght=phosphoric
Old 04-01-2012, 10:26 PM   #64 (permalink)
Member # 108480
$16 at Home Depot
http://www.homedepot.com/Cleaning-Re...&storeId=10051
Old 04-03-2012, 04:17 PM   #65 (permalink)
noob
Member # 66544
They collapse down to 36" and they would still maintain 10" of engagement extended out to 48". Would be alright for your front but it sounds like your needing something balanced for some speed.
Team Rock Limo
F-Toy #F002
Old 04-15-2012, 10:14 AM   #66 (permalink)
Member # 108480
Is 1x1- 0.0747 wall thick enough for the flooring support?
Old 04-15-2012, 04:44 PM   #67 (permalink)
Member # 108480
More...
Made a mount for the fuel cell, completed half the floor, started the master cylinder/ booster mount
Old 04-15-2012, 07:05 PM   #68 (permalink)
Member # 108480
Also, can any one give me the measurements of the red lines on the grill tube shown below
Old 04-24-2012, 09:14 PM   #69 (permalink)
Member # 108480
What gauge steel are people using for the floor, roof, and side panels? 20 gauge, 16 or ???
I am to cheap to shell out the coin for fancy aluminum
Old 04-25-2012, 07:07 AM   #70 (permalink)
Mr Roxy's Avatar
Member # 17537
I used .063 aluminum as that's what everyone said to use. I found it up by Denver for 80.00 dollars for 4 sheets that were 4X10 I believe. When I get a chance I will see if my wife still has the reciept with the name on it. It was a steel place in someones back yard and really cheap.
TinBenders.org
inthePINKracing would like to thank it's sponsors!
Marlin Crawler Griffin Yukon Gear BFGoodrich Artec Industries FOA Hendrix Motorsports Poly Performance RuffStuff Crawlorado Raceline Wheels Savy Offroad
Mr Roxy is offline   Reply With Quote
Old 04-25-2012, 07:26 AM   #71 (permalink)
Chubby Chaser
Mustard Dog's Avatar
Member # 7889
Send a message via AIM to Mustard Dog
Did he sell spools of copper and 'used' car parts too
Eric Anderson
TIN BENDERS
Hendrix XR Chassis #001
Ultra4 #66 4Wheel Parts, Raceline, PSC, Bilstein, Marlin Crawler, Smittybilt, HendriX, PacificFab, G2 Axle, PAC Spring, G&J, MAXXIS
Roxy's in the industry and I'm a sponsored professional driver. The two of us together make a powerhouse.
Accepting the things I cannot change.
Mustard Dog is offline   Reply With Quote
Old 04-25-2012, 09:29 AM   #72 (permalink)
dwishart505's Avatar
Member # 138690
looking great, you are catching up with our build.
what fuel pump are you going to run?
"rock crawling is life, and life rocks"
dwishart505 is offline   Reply With Quote
Old 04-25-2012, 10:10 AM   #73 (permalink)
Member # 108480
The name of the place would be great. I was going to price sheets from
Alreco, 11299 Brighton Road, Henderson, CO 80640 (303) 287-7210. I was thinking of using steel because I can weld it, unlike aluminum.
Some external fuel pump from napa that I ran on my truck it is black and noisy
Old 04-25-2012, 08:51 PM   #74 (permalink)
Mr Roxy's Avatar
Member # 17537
As a matter of fact he might have But the price was right.
TinBenders.org
Old 06-26-2012, 04:57 PM   #75 (permalink)
Member # 108480
Figure two months was a good wait for an update . I have bee trudging away and make as much progress as I can working on it one day a week. I am leaving on vacation this weekend and won't touch it for a few weeks.
Anyways, almost done with the floor, not bad for my first sheet metal work:
Front End:
Booster mount:
