Member # 216664
Building new F-Toy
I'm 17 years old and want to build an F-toy. My father and I are going to start it as soon as he gets back from Afghanistan. I am looking for any advice or just simple tips as far as what to do for it. It is going to be a basic build, but I do want to be able to run KOH with it. Thanks!
Member # 22547
good idea. before he gets back, get a frame and torch it all off and grind and flap it down. make it look real nice because you will have this frame forever and its not exactly replaceable down the line. that right there is about a 10 hour job.
-Hobie GOTPROPANE.COM HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER! |
IDIot!
Member # 44480
Start watching PBB classifieds for a donor truck with a good parts list.
You don't care if the body is hammered, but you want to find 5.29's, lockers, dual cases, hydro assist, Longs, maybe some decent tires and rims, seats, running engine, etc. If you can find those parts in a truck for ~$4k, it's a lot cheaper than sourcing it all separately. Read all the build threads. Write down the things you like. Post up your goals in your build thread--some of the things we chose do aren't compatible with others' ideas. Many are. We'll give you feedback. People like a2b who built the first FToys literally had to start from scratch--and many of those first FToys have been rebuilt several times. Those of us who built later FToys got to cheat and use only their good ideas without having to rebuild them to get there.
Motive Gear Land Use Team http://www.tenfactory.com http://www.motivegear.com http://www.nationaldrivetrain.com http://www.davezoffroadperformance.com http://www.mastercraftsafety.com FToy 086 - UHaul Toterhome |
Member # 22547
what he said, also our advice isn't suggestions, just do exactly what we tell you to do even if you don't understand yet, and you will appreciate it in the end.
Member # 27969
Thanks guys. This is my son. What he didn't tell you is this, we stripped a 87 4-runner frame about a year ago, moved the engine and trans back and down. we have axles with Longs for the front and a set of diffs, both with 5.29's and spools. A well used, but still useable 38" Swampers on steel rims. Picked up F-toy #68 (we think) last last weekend. I went to see Brett at Western Fab the other day and ordered some stuff for when I get back.
But all your suggestions will be asked for. This will be my first F-toy, however alot of you know of my huge ass truck. But it needs to be rebuilt too!! I am really looking forward to spending time with my son on this build. Thank again guys.
RIP Jason and Noel. Forever missed. Last edited by blazen91; 04-17-2012 at 09:08 AM. |
Member # 27969
Advise on leaf springs: I was planning on running Chevy 63" on the rear, and TG 4" on the front. Will have 2" remote res on each corner. Is this a good spring set up, or do would you do different?
RIP Jason and Noel. Forever missed. |
Member # 84377
leaf springs
I would run a different set of rear springs. 63s are super long and dont give a bunch of lift. With 4'' springs up front, you are going to have to run either huge blocks out back or you are going to be looking at the sky a lot. I would run 5'' lift springs in the rear.
As For building, work from bottom to top (ie set axle in position, then drive train, seats, then chassis.) Also if you can, find a pre IFS frame. 2wd will work. The frame kicks up higher and will allow for more up travel. |
Member # 22547
that's cool. sounds like you got things underway.
do not run 63's. find a 4" or 5" thats the standard 56" i think, from marlin or the like. the 4" front will be great. the shocks are preference thing. run em until you don't like them. look up the toy FAQ, find the post that JCA made about how to set your suspension up with proper bump stop, but dont worry about your springs negative arching, you need all the front travel you can get. and like rick james said, bottom to top. you can do all this without the chassis mounted, but don't worry about the frame. the limiting factor on uptravel is usually the ram colliding with the oil pan or radiator. try to get the ram to squeeze between the radiator and the engine to gain the most uptravel.
-Hobie GOTPROPANE.COM HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER! Last edited by a2b; 04-17-2012 at 03:38 PM. |
Member # 27969
Cool, Thanks for the advise. I did plan on building from the bottom up. I didn't do that on my truck and lifting the 205 t-case into place multiple times untill it was right, sucked!! I was under and out of that truck a million times. Learned alot of what not to do!!
#11 (permalink) | |
Member # 22547
just put it all together and then start playing with leafs.
#12 (permalink) |
Member # 84377
The rear part of the frame kicks up, so to compensate, one could run a taller spring. I have 3'' springs front and rear and wish I went with 4'' in the rear because of how high the front sits. Granted I could change the shackle angle, but at the same time, I would rather try to get the most up travel as possible.
#13 (permalink) | |
Member # 22547
i also mounted my spring hangers up inside the frame. they could be higher too.
#14 (permalink) |
IDIot!
Member # 44480
Try to get your spring eyes level--the rear hanger eye and the rear shackle eye should both be about the same distance off the ground at ride height. This helps for shock packaging.
If your front hanger is really low and your back eye really high, the shock will swing backwards quite a bit when you stuff..and vice versa if your hanger is high and you run a really long shackle. Important considerations when you're making room for your fuel/propane tanks and back seat.
#16 (permalink) | |
Member # 220853
Radiostyrd Bat is extremely popular hobby toy |
#17 (permalink) | |
IDIot!
Member # 44480
![]() Reported!
#18 (permalink) | |
Chubby Chaser
![]() I would usually delete a post like yours but I'd rather have everyone here ridicule you instead.
Eric Anderson TIN BENDERS Hendrix XR Chassis #001 Ultra4 #66 4Wheel Parts, Raceline, PSC, Bilstein, Marlin Crawler, Smittybilt, HendriX, PacificFab, G2 Axle, PAC Spring, G&J, MAXXIS Roxy's in the industry and I'm a sponsored professional driver. The two of us together make a powerhouse. Accepting the things I cannot change. |
#19 (permalink) |
Member # 220853
Mr. Mustard Dog, how do you tell me like that? Who gave you permission to say me anything? Before I was also informed that my information was right. I think you have no information about that.
#20 (permalink) |
Chubby Chaser
Are you a Nigerian scammer? You sure write like one.
#21 (permalink) | |
IDIot!
Member # 44480
![]() You are a dolt. You somehow believe that the OP can buy an FToy ...that he will find it on TTORA. ![]() ...that there is better information there than here. ![]() ...and that somehow Mustard Dog has skewed information. ![]() That would be like me asking here where to find a male prostitute in London with a diverse selection of ballgags, but somehow I think I'd be better off asking you. Can you see your small intestine from where you've got your head, or just your colon?
#23 (permalink) |
Member # 292
Back on Topic, this thread remonds me of Mike and Jake Wright. When Mike first called me, he said his plan was to build a Formula Toy with his snot nosed 16 year old kid (Jake
). He wanted to spend "Dad time" with Jake and thought this was the way to do it.Most everyone knows the rest of the story, IT WAS A GREAT IDEA!! and I'm sure Jake would tell you it was the most fun he ever had with his Dad. blazen91, Where do you guys live? I live in Apple Valley. If I'm close, I would like to stop by one weekend and check out what you got. I might have a couple suggestions also.
John James Team Marlin Crawler X-Chassis #12 6 time KOH finisher 2008/2009 W.E. Rock West Coast Series Champion 2008 Pro Rock Champion Just "HAMMER" it!! My Buildup /forum/general-4x4-discussion/298203-desertoy-mustard-dog-build-pair-x-chassis.html |
#24 (permalink) |
Member # 89000
Blazin take Desertoy up on his offer if your close. He is a weath of info and most of the time a pretty nice guy! If it wasn't for John, smittys Ftoy would not work and look as good as it does.
Sure its Victorville but I can wakeboard in my backyard :flipoff2: |
#25 (permalink) | |
Member # 22547
who said it worked and looked nice?
