the new formula#10 build (no booty fab!) - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-13-2004, 04:31 PM   #1 (permalink)
a2b
a2b's Avatar
Member # 22547
okay,,,,,, so i started over. here's the old build thread after the jambo i went and got a STRAIGHT frame from jca. thanks for the hook up jc! its an IFS frame with loads of brackets and what not on it still...
so the last 2 weeks (with the help of dave (cragrat)) i have cut off and ground down and welded up all the holes, i am going to sand blast it and then paint it....i also learned that my welder was smitten with problems and thats why i could never get a good weld....now i am a pro
dave came over today and we put the frame and motor on my trailer. i am going to continue to build it there so it will be mobile. saturday i am taking it to his house and we are going to fab up the motor mounts and tcase crossmember....
even though i started over i am glad i did what i did cuz i learned alot and now i can do it right espicially since dave is officially on my team!!! and is pretty much leading the project..thanks Dave!!!
-Hobie
GOTPROPANE.COM
HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER!
a2b is offline   Reply With Quote
Old 05-13-2004, 04:57 PM   #2 (permalink)
Member # 2413
nothing like going backwards
Aaronn is offline   Reply With Quote
Old 05-13-2004, 05:05 PM   #3 (permalink)
Banned
Member # 2540
Location: Meadow Vista, CA and University Place, WA...moving soon
Send a message via Yahoo to Storm Trooper
change your avitar
Storm Trooper is offline   Reply With Quote
Old 05-13-2004, 05:18 PM   #4 (permalink)
Chubby Chaser
Mustard Dog's Avatar
Member # 7889
Send a message via AIM to Mustard Dog
Originally Posted by Snow Trooper
change your avitar
Not till he can proove his non-bootie status
Eric Anderson
TIN BENDERS
Hendrix XR Chassis #001
Ultra4 #66 4Wheel Parts, Raceline, PSC, Bilstein, Marlin Crawler, Smittybilt, HendriX, PacificFab, G2 Axle, PAC Spring, G&J, MAXXIS
Roxy's in the industry and I'm a sponsored professional driver. The two of us together make a powerhouse.
Accepting the things I cannot change.
Mustard Dog is offline   Reply With Quote
Old 05-13-2004, 05:18 PM   #5 (permalink)
Tech Editor
Air Ride's Avatar
Member # 1656
change your avitar
na he's still the king until he is dethroned by a rival.
HENDRIX MOTORSPORTS.COM
Threaded Panel Tab Sale
tinbenders.org
camo is my hero, even if he is gay
DirtChoppers.net
Air Ride is offline   Reply With Quote
Old 05-13-2004, 05:52 PM   #6 (permalink)
Banned
Member # 2540
should i go out side and start taking pics?
Old 05-13-2004, 09:19 PM   #7 (permalink)
Wilson's Avatar
Member # 7233
I think San Diego CJ is in the lead for next years title.
[COLOR=Red][SIZE=4]ECV 7-11[/SIZE][/COLOR] Serving up a Tsunami of Swagger
Wilson is offline   Reply With Quote
Old 05-13-2004, 10:09 PM   #8 (permalink)
Banned
4RnrRick's Avatar
Member # 3933
Your old project wasn't that bad - was it??? Granted you got a little side tracked on that peddle assembly but you took care of that.
You might be careful on how many rigs you try building although you have a long ways to get to BoogerWeldz record......
4RnrRick is offline   Reply With Quote
Old 05-14-2004, 12:57 AM   #9 (permalink)
a2b
a2b's Avatar
Member # 22547
Originally Posted by 4RnrRick
Your old project wasn't that bad - was it??? ......
ya...my frame was jacked and my designs werent too great and all my welds were messed up pretty bad...i have it all under control now
-Hobie
GOTPROPANE.COM
Old 05-14-2004, 06:55 AM   #10 (permalink)
Banned
4RnrRick's Avatar
Member # 3933
I forgot about that bent frame .....
Old 05-14-2004, 10:10 AM   #11 (permalink)
Member # 2413
This picture just needs to be here
Old 05-14-2004, 10:13 AM   #12 (permalink)
a2b
a2b's Avatar
Member # 22547
thanks aaronn
-Hobie
GOTPROPANE.COM
Old 05-14-2004, 10:46 AM   #13 (permalink)
whitebrowithafro's Avatar
Member # 9761
Send a message via Yahoo to whitebrowithafro
BAWAHAHAHAHAHAAHAHHAHAHAHA Thats too funny....I didn't realize it was that bad. Sorry bud, but I was at the Jambo, and was wondering what the hype was about. I don't know how I missed that
Wish ya luck in the future and P.S. don't weld on painted, oily, or contaminated surfaces, not matter how quick you need to finish. Its just going to jeopardize your safety in the long run
DIRTBUILT INDUSTRIES - CNC plasma cutting, chassis plans, metal fabrication
'NO LIMIT CREW'
whitebrowithafro is offline   Reply With Quote
Old 05-14-2004, 04:28 PM   #14 (permalink)
Member # 15071
Man I remember taking off those brakets for the control arms not to long ago.. so you got it home and have been working on it ever since. Cool looks good! Keep up the good work and we well see you on the trail soon!
Boy
Spawn of ReTodd And proud supporter of wheeling and the Tin Benders. By the way.....My Dad GETS IT
What DO YOU NEED!!
"The Boy" is offline   Reply With Quote
Old 05-14-2004, 08:48 PM   #15 (permalink)
***Glitterbomber***
CragRat's Avatar
Member # 6483
For the record ...
Booty Fab and repairs...
1. Bent frame ... passenger rail was 1" higher than the other. (replaced the frame with a IFS frame from JCA, all brackets have now been removed and all the holes have been welded up and ground down for that "clean shaven" look)
2. Welding ... Proper assembly of the welder would have helped. If you can see "O" rings at the connection point, that is not good. (Repaired) I made him practice on some scrap before touching the frame. The welds that were made before the welder repair where basically without gas, no penetration and would have failed.
3. Pedal assembly ... Using the stock pedal assembly could have worked but removing the pedals from the cowl section would have been a good idea. (A Bling-Bling pedal assembly has been purchased and will be installed properly)
4. Transfer case mount welded to the belly pan ... A new transfer case mount and motor mounts will be fabbed up 5-15-04 moving the engine assembly back 8" and down 1".
I will help and guide him in his quest to be a "Formula Toy Player"
but, I will not build the rig for him.
Dave Vaughn
"CragRat"
" Put on your seatbelt .... I want to try something "
AxleSnapper Bulletin Board
AxleSnapper Website
CragRat is offline   Reply With Quote
Old 05-14-2004, 08:56 PM   #16 (permalink)
Member # 15071
I like the pink tube one the back of the frame.
Boy
What DO YOU NEED!!
Old 05-14-2004, 09:13 PM   #17 (permalink)
a2b
a2b's Avatar
Member # 22547
Boy
its actually the front of the frame
-Hobie
GOTPROPANE.COM
Old 05-14-2004, 09:18 PM   #18 (permalink)
Chubby Chaser
Member # 7889
Well it looks like he schooled you Boy
Eric Anderson
TIN BENDERS
Old 05-14-2004, 10:08 PM   #19 (permalink)
Tim Florian's Avatar
Member # 19246
Send a message via AIM to Tim Florian
You guys are gettin it on the build up. Great work
Skinny Pedal Motorsports #2175. Please support those that support us.
Trail-Gear
Sway Away
PSC
Trans Action (Sun Valley CA)
Kick Ass Offroad / Performance Cryogenics
Spidertrax
BFG
Tim Florian is offline   Reply With Quote
Old 05-14-2004, 10:23 PM   #20 (permalink)
JeepRecoveryTeam's Avatar
Member # 10203
Send a message via ICQ to JeepRecoveryTeam Send a message via AIM to JeepRecoveryTeam Send a message via Yahoo to JeepRecoveryTeam
Hey Dave,
You gonna spot for him in August at the next comp?
You guys better get a move on if you're going to be ready.
d
JeepRecoveryTeam is offline   Reply With Quote
Old 05-14-2004, 11:19 PM   #21 (permalink)
***Glitterbomber***
CragRat's Avatar
Member # 6483
Originally Posted by JeepRecoveryTeam
Hey Dave,
d
I will have to ask Camo if it's in the rules for spotters to "add ballast" to thier bodies ... because you have an unfair advantage
AxleSnapper Website
Old 05-15-2004, 06:32 AM   #22 (permalink)
RE:Todd's Avatar
Member # 422
[COLOR=DeepSkyBlue
[/COLOR]
Thanks Dave, he needs the guidance
Todd Steele
TINBENDERS
Formula Toy #006; Thanks to Deaver Spring, High Angle Driveline, Longfields, Rock Buggy Supply, PRP Seats, Marlin Crawler, Coast Motor Supply and RockStomper.
[url=http://www.tinbenders.org]TinBenders.org[/url]
RE:Todd is offline   Reply With Quote
Old 05-18-2004, 09:05 PM   #23 (permalink)
Member # 16333
Send a message via AIM to RedNeckRea Send a message via MSN to RedNeckRea
is this build up going on in or near simi? if ya need a tool fetchin bitch (or someone to drink beer and watch ) I can offer some assistance on weekends starting in june. lemme know
~Chris, retired US Navy Sailor
RedNeckRea is offline   Reply With Quote
Old 05-18-2004, 09:10 PM   #24 (permalink)
jar head's Avatar
Member # 30126
It's in North Hollywood
jar head is offline   Reply With Quote
Old 05-18-2004, 09:40 PM   #25 (permalink)
a2b
a2b's Avatar
Member # 22547
sure...keep in touch...i build everyday at my house in north hollywood and sometimes i go to dave's and take it there in simi valley
-Hobie
GOTPROPANE.COM
