Permitted Axles List - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-01-2006, 10:34 AM   #1 (permalink)
CronusTRD's Avatar
Member # 11141
I think we should have a list of the permitted axles from particular vehicles to address any further questions.
As I see it:
Allowed
79-85 Front
79-85 Rear
86-95 Rear
Replacement Housings are permitted.
Not Allowed
Any FJ 40, 60 or 80 Axle, front or rear
No Tacoma axles, or 96+ 4runner axles.
No Dually Toyota Axles (U-Haul axle)
No Tundra or T-100 axles.
3rd Members that are allowed:
Fj80 Front 8" Hypinion/E-locker versions
79-95 Toyota 4 cyl and 6 cylinder 8" 3rds
8" E-locker from 96+ Tacoma/4runner
Not allowed:
FJ80 Rear
FJ 60 3rds
FJ 40 3rds
Tundra/Tacoma Non-Elocker 3rds. Easily distinguishable as the 3rd member bolt pattern is a larger than the 8" 3rd. All the studs along the housing would need to be relocated, unlike the two require for the e-locker swap.
My opinion is that custom widths should not be allowed, as it defeats the spec concept. If someone wants to go wider, let them use spacers or different backspacing on their wheels.
Mike
RcRocs 4.3 Toyota Jeep
www.marylandcreepers.com
www.rightcoast4x4.com
CronusTRD is offline   Reply With Quote
Old 03-01-2006, 10:50 AM   #2 (permalink)
desertoy's Avatar
Member # 292
I have a problem with 2 things.
and
The only problem with custom widths is that it opened a hug can of contraversy.
As far as I know the 96+ tacoma 8" will not fit in a stock 79-85 housing.
John James
Team Marlin Crawler
X-Chassis #12
6 time KOH finisher
2008/2009 W.E. Rock West Coast Series Champion
2008 Pro Rock Champion
Just "HAMMER" it!!
My Buildup /forum/general-4x4-discussion/298203-desertoy-mustard-dog-build-pair-x-chassis.html
desertoy is offline   Reply With Quote
Old 03-01-2006, 10:53 AM   #3 (permalink)
CronusTRD's Avatar
Member # 11141
Why? What is your reasoning?
Mike
Old 03-01-2006, 11:17 AM   #4 (permalink)
CronusTRD's Avatar
Member # 11141
Neither does an FJ80. Both have different bolt patterns from the stock housing (two studs) and require the same housing mods.
Hell, the gaskets are the same, just flipped different directions.
Mike
Old 03-01-2006, 03:45 PM   #5 (permalink)
Brian Ellinger's Avatar
Member # 1088
Killing this now. The bolt pattern for hi and low pinion are IDENTICAL.
Thank you to our loyal customers!
Diamond Axle
http://www.diamondaxle.com
Diamond axled buggies take 2 1st's, at Worlds WEROCK!!
Front Range Off-Road Fab with NEW forum!
http://www.frontrangeoffroadfab.com
NEW BUILD FTOY #44
/forum/toyota-formula-toy-forum/562295-front-range-builds-new-toy-old-toy-44-a.html
Brian Ellinger is offline   Reply With Quote
Old 03-01-2006, 03:50 PM   #6 (permalink)
a2b
a2b's Avatar
Member # 22547
ya, the original rules werent meant to allow taco thirds. they need to be expounded on to exclude the taco 8" third.
-Hobie
GOTPROPANE.COM
HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER!
a2b is offline   Reply With Quote
Old 03-01-2006, 03:56 PM   #7 (permalink)
Tech Editor
Air Ride's Avatar
Member # 1656
The rule book is going to end up looking like the LA phone book.
Just put this blanket statement in the rules
"If it didn't come off of an 79 to ?? you cant use it unless the rules specifically state that you can"
HENDRIX MOTORSPORTS.COM
Threaded Panel Tab Sale
tinbenders.org
camo is my hero, even if he is gay
DirtChoppers.net
Air Ride is offline   Reply With Quote
Old 03-01-2006, 04:02 PM   #8 (permalink)
Heywood's Avatar
Member # 6380
Since aftermarket housings are allowed, In my opinion that means ANY housing is allowed. No need to make a list of which is and which isint.
Front needs to have 79-85 PU/4rnr KNUKLES, birfs and 8"r&p.
If you can get all that on any housing it should meet the requirements.
Rear needs to have 8" R&p and toy drum brakes.
I dont see a need to add any more details.
Everyone knows or should know which 3rds are allowed and which arent.
Hobies allready been over the reasoning behind allowing any width.
As far as changing any rules I dont think any rules should be changed untill the season is over.
Heywood is offline   Reply With Quote
Old 03-01-2006, 04:45 PM   #9 (permalink)
CronusTRD's Avatar
Member # 11141
That's not true. For example, the gaskets are mirror images of each other and two different part numbers. The difference is small however.
http://4-low.com/temp/e-locker-differences.gif
From my understanding, regular V6 gears you would use in a pre-tacoma carrier would fit the e-locker carrier, so where is the difference what would exclude it? What makes the FJ80 locker acceptable, and the Tacoma locker unacceptable. I'm just not seeing the logic here.
Camo had addressed this before the class even began
Originally Posted by Foxfab
I'll put in another vote for YES TO EFI. I'd have a hard time pulling it off of my Legends class truck if I were to someday build it to this class.
Also, I havent had the time to sift through everything but the outline states only aftermarket lockers are allowed. Does this mean no OEM lockers are allowed?
Originally Posted by camo
any locker allowed
Why would this have changed?
http://www.pirate4x4.com/forum/showp...&postcount=364
http://www.pirate4x4.com/forum/showp...&postcount=365
Mike
Old 03-01-2006, 08:25 PM   #10 (permalink)
Tim Florian's Avatar
Member # 19246
Send a message via AIM to Tim Florian
The fj80 third, non-elocker will bolt right up with no issues. The e-locker third needs some modification.
The issue your talking about above and Camo saying any locker is allowed, in my opion refers to the locker itself, not the complete third. FWIW
Why is everyone fighting the rules so much here. They are what they are. Live with it.
Skinny Pedal Motorsports #2175. Please support those that support us.
Trail-Gear
Sway Away
PSC
Trans Action (Sun Valley CA)
Kick Ass Offroad / Performance Cryogenics
Spidertrax
BFG
Tim Florian is offline   Reply With Quote
Old 03-02-2006, 06:17 AM   #11 (permalink)
Member # 43818
Send a message via AIM to ATLRoach
Then why allow the high pinion e-locker FJ80 thirds? It would be no different than running a low pinion Taco E-locker third. Both would require modification to the housing to allow them. Kinda makes no sense to exclude one without the other.
85 4Runner w/ FZJ80 Axles on 4Ds (Parted Out)
V8 Powered Yota Truggy,
ATLRoach is offline   Reply With Quote
Old 03-02-2006, 06:44 AM   #12 (permalink)
CronusTRD's Avatar
Member # 11141
They only want to allow the high pinion 3rd member w/o the locker.
Mike
Old 03-02-2006, 07:51 AM   #13 (permalink)
Member # 1088
Think about it, the motors interchange, this person is incorrect.
Diamond Axle
NEW BUILD FTOY #44
http://www.pirate4x4.com/forum/showthread.php?t=562295
Old 03-02-2006, 08:11 AM   #14 (permalink)
wishes he was racing
Pook's Avatar
Member # 3370
Heywood's running a hipinion elocker i think.
Pook is offline   Reply With Quote
Old 03-02-2006, 09:20 AM   #15 (permalink)
Heywood's Avatar
Member # 6380
Yes I am, It was less than $800 new from Toyota, and has been problem free
I was/am under the impression a rear elocker 3rd is "8" 3rd and legal.
I think the idea of the rules is to keep it affordable, where a guy with a stock welded 4cyl diff is on the same level or close too anyways.
Old 03-02-2006, 10:50 AM   #16 (permalink)
desertoy's Avatar
Member # 292
Did you have to modify your housing (drill holes, change stud size)? If so, it sounds like you are outside of the rules.
John James
Team Marlin Crawler
X-Chassis #12
6 time KOH finisher
Just "HAMMER" it!!
My Buildup http://www.pirate4x4.com/forum/showthread.php?t=298203
Old 03-02-2006, 12:27 PM   #17 (permalink)
Heywood's Avatar
Member # 6380
Are you telling me you dont know how a Hp elock 3rd goes into an 85 housing?
And you dont know the difference between the so called 8" and 8.4" 3rds?
Or are you just trying to stir more shit up?
And outside the rules?
How so?
Directly from the rules
"Must use Toyota 8" third members (FJ80, V6 or 4cyl)"
Old 03-03-2006, 09:56 AM   #18 (permalink)
Pook's Avatar
Member # 3370
I would want to think that the elocker would be allowed as a cheap alternative to the blingy ARB... helps the junk yard scrounger if they need it
I know around here its harder and harder to get the older toy diffs and parts, the wreckers don't carry anything that old, and you pretty much need to find someone thats partying one out.
What is th ebig deal with the Taco rear end? Its way stronger?
I can understand the bigger knuckles and birfs from a landcruiser steering setup etc... on a front diff being an advantage.
Old 03-05-2006, 05:57 AM   #19 (permalink)
Member # 51921
I'm still baffled why this topic is such a sticking point with some people.
I had some bling ARBs lined up for my build, even was going to pull the trigger on a rear diamond..but you know what...FAWK that.
Found a 4cyl rear and going to run welded front and rears with a twin stick and FROR hydro assist just to be as basic as possible. Retro.
This is a drivers class so my thoughts are to quite worrying about this and that, get the sum bitch built then wheel the shit out of it.
All these minute differences (arguing about rules) is not going to make anyone more competitive or a better driver.
Mark Van Meter
Secretary, TLCA
[url]http://www.tlca.org[/url]
Nissan Recovery Team is offline   Reply With Quote
Old 03-05-2006, 09:15 PM   #20 (permalink)
Pook's Avatar
Member # 3370
I'll be running th elow budget welded 4 cylinder thirds for the tinbender jambo anyways... between building the ftoy and a new shop cash is getting hard to find.
Old 03-05-2006, 11:44 PM   #21 (permalink)
Member # 10010
I'm pretty sure a rear elocker has been offered as a factory option on 1990-1995 "hilux" minitrucks on certain markets.
'71MS75 '73DW15 '75BJ40 '79FJ55 '84BJ45 '88LN65 '90HDJ80 '92LN85 '98CE110
Stupid frnch jackasS is offline   Reply With Quote
Old 03-06-2006, 04:52 AM   #22 (permalink)
Member # 51921
Amen on the cash thing...my wife and I are doing some H.I. projects
Several weeks ago Hobie sent a PM with an invite to call him. We talked Ftoy for a half hour or so. Ever since that call, my thoughts towards how to build this has changed and keeping in the spirit of FToy is important. My enlightenment Less is more.
Mark Van Meter
Secretary, TLCA
Old 03-06-2006, 08:19 AM   #23 (permalink)
desertoy's Avatar
Member # 292
How so?
That is what I am telling you. I don't know anything about Tacoma's because tacoma parts are not legal in formula Toy.
John James
Team Marlin Crawler
X-Chassis #12
6 time KOH finisher
Just "HAMMER" it!!
Old 03-07-2006, 05:01 AM   #24 (permalink)
a2b
a2b's Avatar
Member # 22547
IMO, welded front is cool for backup, but not for comp or wheeling. you will defintely want the howe system just for turning that sucker. at the least, i would put a lockright in the front. i am thankful all the time i have an arb in the front. it keeps me from breaking stuff. when the whole rig is vertical on its nose and you need to take a hard left, you dont want to be locked during that time. ask bobby, welded fronts or spools, just wear the heck out of birfs.
-Hobie
GOTPROPANE.COM
Old 03-07-2006, 10:38 AM   #25 (permalink)
Pook's Avatar
Member # 3370
well I thought about it and just ordered an elocker, makes sense that it'd be hell on the front diff parts having a welded diff in the rocks. Up here I'd run it for a while but with going to the jambo and moab this year in the same trip I'd rather have one less thing to worry about breaking.
