Member # 6380
carnage list from pro rocks
There was more breakage at this comp than Ive seen at the previous comps.
I thought a list might help those still building 1-front out put 1-rear out put 2-HP front gear seats, 1 4.10 & 1 5.29? 1 or 2 MTRS 2 Profields 1 hub (tooken out by profield) 1 rear driveshaft (stock) 1 radiator smashed from lack of protection, but still useable Thats all I can remember. Last edited by Heywood; 03-14-2006 at 10:38 AM. |
Member # 1088
HIJACK!
Lets see pics of all the ftoys that ran this event! Im seeing minimal coverage across the board. And Sean, did you get your rear end fixed?
Thank you to our loyal customers! Diamond Axle http://www.diamondaxle.com Diamond axled buggies take 2 1st's, at Worlds WEROCK!! Front Range Off-Road Fab with NEW forum! http://www.frontrangeoffroadfab.com NEW BUILD FTOY #44 /forum/toyota-formula-toy-forum/562295-front-range-builds-new-toy-old-toy-44-a.html |
#3 (permalink) | |
Member # 6380
That diamond axle freaking rocks! Chris got some close up pics of it over there. I think crawl mag got some good pics too. I got it in friday, no time to even paint it! It looks BAD ASS!!! I have to say I had a little more confidence doing full throttle launches Thanks for the great service and comunication. Hobie was saying your thinking about stepping up to support the class. Right on
#4 (permalink) | |
Matt Messer
Member # 39978
Check it out at www.Trail-Gear.com |
#6 (permalink) | |
Member # 292
John James Team Marlin Crawler X-Chassis #12 6 time KOH finisher 2008/2009 W.E. Rock West Coast Series Champion 2008 Pro Rock Champion Just "HAMMER" it!! My Buildup /forum/general-4x4-discussion/298203-desertoy-mustard-dog-build-pair-x-chassis.html |
Member # 292
Team Tin Benders carnage list.
1. Transfer case front output (???) 2. 3 MT/R tires (2 sidewall puncture, 1 big gash) I'm not quite sure what was going on this weekend but this is the first time ever in 6 years of extreeme rock crawling that I have blown a tire (sorry Todd ).As for the transfer case, Who knows. Hopefully this kind of breakage is over though.
John James Team Marlin Crawler X-Chassis #12 6 time KOH finisher 2008/2009 W.E. Rock West Coast Series Champion 2008 Pro Rock Champion Just "HAMMER" it!! My Buildup http://www.pirate4x4.com/forum/showthread.php?t=298203 Last edited by desertoy; 03-15-2006 at 11:21 AM. |
Member # 22547
last year we had 1 birfield and 1 ring and pinion out of 3 complete comps. what is up with this year??? wow, we are really tearing out stuff up
-Hobie GOTPROPANE.COM HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER! |
#10 (permalink) | |
waterboy
Member # 9086
looks like you're all having fun though
buy my jerky!!! |
#11 (permalink) | |
Member # 22547
i dont know what you are talking about...i baby my rig
#12 (permalink) | |
waterboy
Member # 9086
buy my jerky!!! |
#14 (permalink) | |
Member # 292
John James Team Marlin Crawler X-Chassis #12 6 time KOH finisher 2008/2009 W.E. Rock West Coast Series Champion 2008 Pro Rock Champion Just "HAMMER" it!! My Buildup http://www.pirate4x4.com/forum/showthread.php?t=298203 |
#15 (permalink) |
Tech Editor
Member # 1656
The ones I've seen were in reverse.
HENDRIX MOTORSPORTS.COM Threaded Panel Tab Sale tinbenders.org camo is my hero, even if he is gay DirtChoppers.net |
#16 (permalink) | |
wishes he was racing
Member # 3370
me too... I wonder why they are blowing so easy in reverse, when the lowpinions are always ran in reverse when in the front going forward. Pretty sure Heywood has put some hard mileage on his since he ran them last year as well. I dunno, no I am rethinking this whole thing...
#17 (permalink) | |
The problem isn't just using reverse, it is when the buggy is pointed downhill and your trying to back up. All the weight is on the front end and then your using the week side of the gear to back up. When the low pinion third is in the front going forward, yes it's running on the week side of the gear, but for the most part the majority of the weight load in a stressed situation (like the comp courses) is on the rear axle. I found a really good balance running cryoed 4:88s. I don't know how cryoed 5:29's work because when I was breaking 5:29's I didn't know about the amazing benifits of cryo yet. So I switched to 4:10's only to start breaking t-case's. After like 3 output shaft failures I decided I needed to relieve some of the torque from the t-case. Going to Cryoed 4:88's did just that. Good luck, breaking sucks especially in comps.
Skinny Pedal Motorsports #2175. Please support those that support us. Trail-Gear Sway Away PSC Trans Action (Sun Valley CA) Kick Ass Offroad / Performance Cryogenics Spidertrax BFG Last edited by Tim Florian; 03-16-2006 at 09:45 AM. |
#18 (permalink) |
Member # 51921
Ahhh.....(lightbulb) Well, that makes sense...Well, gonna run what I got till it breaks I guess. Will have to do my homework on the cryo stuff and start learning to set up my own gears.
Traded my ARB for a HP Elocker for the front end in 4.10s Isn't it fun Pook? Learnin' something all the time. Building these things is not an easy task by anymeans..
Mark Van Meter Secretary, TLCA [url]http://www.tlca.org[/url] |
#19 (permalink) |
Member # 6380
Ill be continuing to run HP Elock 4.10s
I havent broke enough yet to change. Ive had stock 4.10s in the rear for years, and have even broken two rearshafts with them. Im pretty sure my HP broke going foward. Also changing ratios would mean not only changing the two in the rig, but the two spares also. As long as Tim is there to pull out the stuck birfs, changing 3rds isint too bad Even when its snowing Deffinatly gonna look into cryoing. |
#20 (permalink) | |
Member # 51921
#21 (permalink) | |
Watching (and kinda helping) you and Brandon swap the third while it was snowing was very entertaning by the way
Skinny Pedal Motorsports #2175. Please support those that support us. Trail-Gear Sway Away PSC Trans Action (Sun Valley CA) Kick Ass Offroad / Performance Cryogenics Spidertrax BFG Last edited by Tim Florian; 03-17-2006 at 09:36 PM. |
#22 (permalink) | |
Member # 422
Todd Steele TINBENDERS Formula Toy #006; Thanks to Deaver Spring, High Angle Driveline, Longfields, Rock Buggy Supply, PRP Seats, Marlin Crawler, Coast Motor Supply and RockStomper. [url=http://www.tinbenders.org]TinBenders.org[/url] |
#23 (permalink) | |
Matt Messer
Member # 39978
I have the buggy on the lift now. I will be replacing the suspesion all the around (new springs, bushings and shackle assemblies). I will be switching from the 4.10 gears to 5.29's. I am going to stick with the hi-pinion for now, but my confidence is very low right now with the hi-pinion due to breaking it twice. I have rebuilt the t-case and also another one for backup. The following replacement parts will be available for the next comp. 1. Drivelines. 2. 2 complete 5.29 diffs with detroits. 3. Extra T-case 4. Shackle assemblies. 5. 1.5" ram. 6. 1 complete hi-steer kit. 7. 2 rear outputs. 8. 2 front outputs. 9. Multiple Power Tanks. 10. Rear axles short and long. 11. Front axles inner/outers. I want TG to be the central repair point for all F-Toys. Please let me know what else you would like us to have on hand. Thanks, Matt |
#24 (permalink) | |
H M F
Member # 8758
You going to have a press to do the bearings, or have bearings already installed on all the spares? Don't forget spindles and hubs. Maybe knuckles, or an extractor set and steering arm studs. Maybe some break lines and all fluids...man, this could get out of control trying to bring spare everything. I know, just bring a couple spare turn key f-toys
#25 (permalink) |
H M F
Member # 8758
Oh, and Sean did break the HP 4.10's going forward. But it was climbing an undercut ledge with the buggy downhill at the front a bit. Both tires in the undercut at the same time. Tried crawling a bunch. Then a few 2nd or 3rd gear bumps searching for traction. Right before it blew up, I was pretty sure something was gonna go, but we couldn't get into a better position. Before I had time to find a new line - BANGklangklangklangklangklangklangklangklangklang
