Formula toy's with carbs. help! - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-11-2006, 01:59 AM   #1 (permalink)
wishes he was racing
Pook's Avatar
Member # 3370
Could someone running a stock carb, (hobie?) post some pics of what vacuum
hoses they needed to get their truck to run. I have all the basic smog stuff still on it its out of an 87 pickup (no smog pump), debating if I should strip it all down or just hook up the parts that were on the fender etc it needs to run like stock back on.
What was the computer for? just emmisions?
I'm getting down to crunch time and still have a fair bit to do mostly wiring and getting the damn thing running.
Anything that could save me some time figuring it out on my own would be appreciated...
Pook is offline   Reply With Quote
Old 04-11-2006, 05:37 AM   #2 (permalink)
a2b
a2b's Avatar
Member # 22547
okay,
disconnect all that smog crap. there should be 4 wires coming from the carb. hook 1 of them up to ground and the other 3 up to hot. if you dont, it wont run right. (one of the black ones is a hot wire, the other black is ground)
plug up all other vacuum lines. BUT, the timing advanced. that has to be plugged into the side of the carb.
vent the carb and put a pressure regulator on it and you are good to go.
-Hobie
GOTPROPANE.COM
HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER!
a2b is offline   Reply With Quote
Old 04-11-2006, 10:03 AM   #3 (permalink)
Pook's Avatar
Member # 3370
Originally Posted by a2b
okay,
cool thanks...got the pressure regulater and the carb vent allready.
The rest makes it easy. Thanks.
Old 04-14-2006, 01:28 AM   #4 (permalink)
Pook's Avatar
Member # 3370
okay,
It looks like tow of the wires go to the choke on mine and 2 to the other solenoid thing. Wouldn't that make it 2 hots and 2 grounds? my haynes manual doesn't have the wiring diagram for that carb, just the efi setup.
Old 04-14-2006, 01:40 AM   #5 (permalink)
a2b
a2b's Avatar
Member # 22547
nope. 3 hot. 1 ground. i had it wired up that way for a year. then i had a pro come and wire up my buggy. he wired it up the way you said and it didnt run right, i found that he had done that, when i switched it back. it ran great.
-Hobie
GOTPROPANE.COM
Old 04-14-2006, 01:51 AM   #6 (permalink)
Pook's Avatar
Member # 3370
interesting... I wonder if that solenoid is actaully on or off? does it run any different when those wires are disconnected? IfI can find a wiring diagram...I wouldn't mind seeing what its actually doing.
fawk it...I'll just hook them up all up...is the one ground off the choke?
Old 04-14-2006, 02:08 AM   #7 (permalink)
a2b
a2b's Avatar
Member # 22547
dont know whats it off of
-Hobie
GOTPROPANE.COM
Old 04-15-2006, 01:38 AM   #8 (permalink)
Pook's Avatar
Member # 3370
for anybody who wants to know the third all black wire is for the outer vent on the carb...when the truck is off it opens and lets fumes from the carb down and into the charcoal cannister (or viceversa not sure really which way it goes)
The choke is self grounded and only has a hot wire coming off it, the fuel cut off solenoid has two wires, one ground and one hot.
Old 04-16-2006, 07:30 PM   #9 (permalink)
PARANOID56's Avatar
Member # 5114
Send a message via AIM to PARANOID56
so, could we get rid of that outer vent? i was just today getting rid of all these damn vacuume lines out of the engine. looks much better with out them.
Shane
1971 FJ40 w/ rust Build up
2003 Toyota Taco double cab
2008 Subaru Impreza STI
1998 Honda XR650L
TLCA member #12202
PARANOID56 is offline   Reply With Quote
Old 04-17-2006, 09:01 AM   #10 (permalink)
Pook's Avatar
Member # 3370
i dunno mine won't run without vacuum lines? carb backfires etc...i'm going nuts.., /forum/toyota-truck-4runner/464879-carb-back-firing-help.html got any ideas?
Old 04-18-2006, 10:21 PM   #11 (permalink)
Pook's Avatar
Member # 3370
trucks messed up. won't run backfires etc. I was suppose to be driving down the I5 somewhere in Cali by now.
hoping to leave tomorrow morning....any carb experts want to give me a hand on the lake bed? give me a list of stuff to bring.
Old 04-18-2006, 11:10 PM   #12 (permalink)
Member # 45196
I'll help you out, bring everything from it stock. I have a computer for a carbed 86 you can have. if you don't want to do that ill still help you out for sure
96 taco, lockd, linkd, caged, beat, daily driven 24" frame on 4dz ready to jump
toy86 is offline   Reply With Quote
Old 04-19-2006, 05:33 AM   #13 (permalink)
a2b
a2b's Avatar
Member # 22547
ya pook, just bring it and we'll fix it there. i will be at the Trail Gear camp. just come on over, i will put it up next to mine and we'lll make it the same.
-Hobie
GOTPROPANE.COM
