Member # 51921
#036 Interior-Finishing it Up Thread
If you were wondering what happened to my original build thread, I had my website HACKED to shit in February and the douchebag hit the delete button on the entire site. Lost everthing cause I was a dumbass and didn't back it up.
Anyways, here's where it was last Friday. I'll keep this thread updated till she's done. Here's the final inboard spring mount. Under neath the box is the original hanger with a triangle of plate up against the frame like this |> and then the plate around it to box it in. Poison Spyder Gussets to keep it from seperating like Hobies did. ![]() From the back corner ![]() Wilwood Master Assembly: ![]() Still fussin' with the placement of the assembly a little and the steering wheel. But should have it set now. ![]() Encapsulating the motor for the firewall. Subfloor is down. Just have to finish up the rear CV cage. The inside is going to be all Aluminum. One more ![]() Front axle is missing cause it's being made at FROR. Diamond with custom shaft and Elocker Mod. 60.6 for the width up front. More in the morning. Working non stop till it's done...
Mark Van Meter Secretary, TLCA [url]http://www.tlca.org[/url] |
Member # 22547
you prolly know this but.....make sure your clutch and bell housing is covered as best you can. and are you sure you have 3" above your helmet to the chassis?
and btw, you wont have problems with the hanger. the reason that one hanger came apart, was because it wasnt welded on all 3 sides, just 2
-Hobie GOTPROPANE.COM HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER! |
#3 (permalink) | |
Member # 51921
Yeah, I was playing around with that piece of AL and trying to get as much clearance for the slave as possible. Might have to recut it though. I do have 3" above and when I set the chassis in February it was higher than that and Heywood said it was "too tall" so I dropped it down to 2.25 inches above the frame rail and with my bucket, should be ample clearance for the 3" I'll slouch if I have to By the size of the boulder you were moving with your axle, thought the extra gussets were called for...learned a ton from you guys in 2 days
Member # 292
Looking good. Did you move your motor back any?
John James Team Marlin Crawler X-Chassis #12 6 time KOH finisher 2008/2009 W.E. Rock West Coast Series Champion 2008 Pro Rock Champion Just "HAMMER" it!! My Buildup /forum/general-4x4-discussion/298203-desertoy-mustard-dog-build-pair-x-chassis.html |
#5 (permalink) | |
Member # 51921
Thanks John, yes, it's moved back 8 inches and used Mike's engine mounts.
Member # 14048
Can you tell me what engine / trans you're running in that?
Thanks
Life is too short for a full time job. www.keystonekrawlers.com Last edited by willbeis; 04-24-2006 at 06:30 PM. |
#7 (permalink) | |
Member # 51921
Installed the WABFAB (http://www.wabfab.org) battery tray last night under the dash..Did a bunch of flap disk sanding the metal in the sub floor. Want it smooooth for the aluminum sheet metal. Plan to mount the 12voltguy buggy panel tonight. Sub-Floor for the trunck where the fuel cell, powertank, toolbox, sit. ![]() More in the morning.
Tech Editor
Member # 1656
Copycat
HENDRIX MOTORSPORTS.COM Threaded Panel Tab Sale tinbenders.org camo is my hero, even if he is gay DirtChoppers.net |
#9 (permalink) | |
Chubby Chaser
Eric Anderson TIN BENDERS Hendrix XR Chassis #001 Ultra4 #66 4Wheel Parts, Raceline, PSC, Bilstein, Marlin Crawler, Smittybilt, HendriX, PacificFab, G2 Axle, PAC Spring, G&J, MAXXIS Roxy's in the industry and I'm a sponsored professional driver. The two of us together make a powerhouse. Accepting the things I cannot change. |
#12 (permalink) | |
Member # 51921
Love it! A timeless classic. Everytime I see these wheels it reminds me of growin up in Walnut Creek and going to Ygnacio Valley watching the low riders gettin stuck on the speed bumps at the high school..
#13 (permalink) |
Member # 51921
Update:
Switch panel is in...this was a chore. Made 2 brackets/mounting systems last night and sent both to the scrap pile after 3 hours of work and started from scratch again and came up with this. I like it. Sturdy as hell, clean and effective. Most important, no need to bend the trans shifter to clear it now. My tolerance is about 1/2 inch when in first gear to the fuse box. Next 2 nights will be paint and will have an update on Friday morning as the plumbing and wiring will be the weekends chore
Mark Van Meter Secretary, TLCA [url]http://www.tlca.org[/url] Last edited by Nissan Recovery Team; 04-26-2006 at 05:26 AM. |
#15 (permalink) |
Member # 292
What happened to all of the pictures??
John James Team Marlin Crawler X-Chassis #12 6 time KOH finisher 2008/2009 W.E. Rock West Coast Series Champion 2008 Pro Rock Champion Just "HAMMER" it!! My Buildup http://www.pirate4x4.com/forum/showthread.php?t=298203 |
#16 (permalink) | |
Member # 51921
Sorry guys, switching servers tonight..back online in the AM and the pics will work again.
#17 (permalink) |
Member # 51921
Update...
1.75 .120 wall Dom to match the chassis. Wanted some overhead protection and strength to the rear spreaders should I ever put the rear seat in. All tacked in place. Have one spreader just a hair off and will fix that tonight. Lowered a bar on the engine cage and re-ran the spreaders. Clean it all up and plan to start painting everything then reassemble it. Should be a good weekend. More Monday
#18 (permalink) |
Member # 51921
Pretty much done with paint. Other than the panels and some misc. shit once all the hardware is back in.
Gray primer Here you can see the gussets under the floor and the bellypan
#20 (permalink) |
Member # 292
Looking good!
#22 (permalink) | |
Member # 1101
I had one of those on my 84 Fiero Lowrider with white walls! (I was confused in high school)
"Religion is but myth and superstition that hardens hearts and enslaves minds!" Prove me WRONG! |
#24 (permalink) | |
Member # 48323
If you don't have firsthand experience, then I'm not really interested in what you think you know. ========================== 1985 xcab-dual cases-33"Truxus-ARBs-Longfield's-Wagoneer springs-Rancho 9000- ========================== Last edited by KI5KA; 05-01-2006 at 06:45 PM. |
