F-Toy #38 - Page 8 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-31-2006, 05:30 PM   #176 (permalink)
Member # 76617
The car is looking good as for the panel damage slap a decal over the bad spot. Thats what we did every time we punched a hole in one We dont really have that many sponsors
Wright racing
F-TOY #22
Hi desert driveline
losi
rcp crawlers
A Samauri is not an f-toy
A samauri is not an f-toy
benttoy is offline   Reply With Quote
Old 12-31-2006, 05:47 PM   #177 (permalink)
Hammer Hog's Avatar
Member # 24269
Location: Way closer to the Hammers than you!!! Was Montrose, CO
Nice looking rig! The front end looks very cool...nice lines!
Official OG13-2013 KOH Recovery Team.
Formula Toy #11 is For Sale... PM me.
Hammer Hog is offline   Reply With Quote
Old 12-31-2006, 08:11 PM   #178 (permalink)
Member # 30134
Ahh, I already fixed it. It's painted and everything, except a new sticker
azyota is offline   Reply With Quote
Old 12-31-2006, 08:16 PM   #179 (permalink)
Member # 30134
Thanks man! Coming from you that's a great compliment. Your pretty much F-toy OG!
Old 03-08-2007, 08:53 PM   #180 (permalink)
Member # 30134
Now that I have the wider 86+ rear axle, I decided it was time to ditch the 2"BS wheels. I got some Black Rock Crawler wheels from Crossed Up and started designing my own outer rings. I already have the inner rings so I'm going to go ahead and use those. The outer rings will be made at Crossed Up.
Here are some models of the rings I'm planning to use.
The inners,
Outers,
And the complete assy including hardware,
Old 03-08-2007, 08:55 PM   #181 (permalink)
Member # 30134
Got the outer's cut out, and the inners welded on.
Finished and mounted
Old 03-08-2007, 09:39 PM   #182 (permalink)
Matt Messer
ACE-CAGE-#29's Avatar
Member # 39978
Nice Job! They look great.
Matt Messer
http://www.trail-gear.com
ACE-CAGE-#29 is offline   Reply With Quote
Old 03-09-2007, 08:43 PM   #183 (permalink)
Member # 76617
Sweet!
Wright racing
F-TOY #22
Hi desert driveline
losi
rcp crawlers
Old 10-02-2007, 09:28 PM   #184 (permalink)
Member # 30134
I havent done anything in a while worth posting, but this one is pretty cool. I posted this on the toy board but it goes down the page pretty quick, and I dont know haw many F-Toy guy's look there.
Anyway, At the last comp I did at Donner I bent my rear axle housing pretty bad. Mike and Jerrod over at Crossed Up built me a new one. This thing is beefy to say the least. The center section was fabricated from 1/4" plate and the axle tubes are 3" diameter x 3/8" walll DOM. The axle flanges are designed by Crossed Up and machined from billet by Tim Brown of Metal Works. And yes, they are for sale. Check out their site in my sig. Here are a few pics.
Flange and DOM axle tube.
Flange after welding.
This is the center section and billet aluminum oil fill plug. These things are pretty sweet. It's a machined steel piece threaded to fit the X-up cap, and is sealed with an O ring.
Mike also set up this diff. V6 housing, 5.29,s and an ARB.
I still need to finish cleaning up the brake lines. As it sits right now, I have
13" between the bottom of the housing and the floor. The tires are 37"s with 10psi in them. They measure just under 35" tall.
Old 10-21-2007, 07:44 PM   #185 (permalink)
FYRDUDE's Avatar
Member # 16686
That rear end is a thing of beauty!!!
What the clearance of that thing compared with the Diamond?
GETTING FLAMED FOR A LIVING AND LOVING EVERY MINUTE!!!
[COLOR=Red]FDNY 343[/COLOR]
F-toy #23 buildup
[url]http://www.pirate4x4.com/forum/showthread.php?t=330266&highlight=formula+toy[/url]
Project Double Wide : F-Toy #23
[url]http://www.pirate4x4.com/forum/showthread.php?p=6542368#post6542368[/url]
FYRDUDE is offline   Reply With Quote
Old 10-21-2007, 08:51 PM   #186 (permalink)
a2b
a2b's Avatar
Member # 22547
that thing is not class legal. only diamonds are class legal.
j/k
good work pat!!!! is kris going to spot for you next year?
-Hobie
GOTPROPANE.COM
HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER!
a2b is offline   Reply With Quote
Old 10-22-2007, 10:15 AM   #187 (permalink)
Member # 30134
I'll have to ask Mike about the clearance, I don't actually know myself.
Old 10-22-2007, 10:24 AM   #188 (permalink)
Member # 30134
Thanks Hobie! The guy's at Crossed Up did a great job. They are also making front housings, but it will probably be a little while before I get one of those.
Yeah, Kris is going to be spotting for me. I think things are going to work out okay, we just need some more practice working together. Do you think you will be out for PUSU in January?
Old 11-28-2007, 07:52 PM   #189 (permalink)
Member # 30134
I started dialing in my suspension so I called Matt at Trail Gear. His F-Toy flexes great so I wanted some advise from him. He suggested his 5" lift springs with a few leafs removed, and going to 6" shackles. He also set me up with all the dimensions between the spring hanger and shackle hangers. Just by luck my front mounts were exactly the same and the rears were within 1/4". It sounded good so I ordered them up. Two days later they were here. Great service!
At first I put them on with the 5" shackles that I had to see where it would end up. The rears were way to far kicked back.
With this much angle just one persons weigh on the back would compress the suspension far enough to invert the shackles up against the rear X-member and they would stick that way. I went ahead and put the 6" shackles in and that made the angle about 42 deg from vertical. They seem to work great there.
I left the front's with 5" shackles and wheeled it once, they would hit the frame on compression so I swapped them out to 6" shackles too. I havn't wheeled that yet, but the angles look good.
Working on a little more bling too I broke down and ordered up some Creeper Locks from Trail Gear too. I still need to work out tires, but the wheels look good in my shop. Same thing, ordered on Monday, at my doorstep Wednesday
Old 11-28-2007, 08:48 PM   #190 (permalink)
Member # 78096
looks great. Why are you switching beadlocks?
Jeep07 is offline   Reply With Quote
Old 11-29-2007, 09:46 AM   #191 (permalink)
Member # 30134
I'm going to get some Krawlers soon. I needed 17" wheels.
Old 11-30-2007, 03:22 PM   #192 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
Iroks/beadlocks for sale?
MT4Runner is offline   Reply With Quote
Old 12-03-2007, 09:49 PM   #193 (permalink)
Member # 30134
Yup! $850 OBO.
Old 12-03-2007, 09:55 PM   #194 (permalink)
Member # 30134
Got new tires today and got them mounted up.
The Trail Gear beadlocks look great! I already feel bad about whats going to happen to them.
Old 12-04-2007, 07:34 AM   #195 (permalink)
Member # 38388
Those look really nice, I am sure you will enjoy them
Kevin
F-Toy #008
Check out the build: [url]http://pirate4x4.com/forum/showthread.php?t=601321[/url]
Skii4x$ is offline   Reply With Quote
Old 12-04-2007, 08:22 AM   #196 (permalink)
desertoy's Avatar
Member # 292
WOW, those tires and wheels make it look like a different rig.
NICE WORK!!
John James
Team Marlin Crawler
X-Chassis #12
6 time KOH finisher
2008/2009 W.E. Rock West Coast Series Champion
2008 Pro Rock Champion
Just "HAMMER" it!!
My Buildup /forum/general-4x4-discussion/298203-desertoy-mustard-dog-build-pair-x-chassis.html
desertoy is offline   Reply With Quote
Old 12-04-2007, 12:32 PM   #197 (permalink)
Member # 87023
Timpat If I didnt know better I would think you were trying to take the trailer-queen title away from me and Bernie. Looks good, we will see how it looks after this weekend.
handlebar is offline   Reply With Quote
Old 12-04-2007, 01:09 PM   #198 (permalink)
Member # 76617
Sam they will never have a fish tank as nice as yours
The rig looks sweet with those wheels
Wright racing
F-TOY #22
Hi desert driveline
losi
rcp crawlers
Old 12-04-2007, 03:19 PM   #199 (permalink)
Member # 87023
Mike and Jake, we cant thank you two enough for your continued support of the tank. Without those weekly checks for fish food and water and replacement fish the dream of having the only Ftoy fish tank would have Floundered. Thanks for the Clams.
Old 12-04-2007, 08:20 PM   #200 (permalink)
Member # 30134
NICE WORK!!
They really do make it look like a different rig!
