39's on Comp. F-toy? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 07-04-2006, 12:24 PM   #1 (permalink)
FYRDUDE's Avatar
Member # 16686
Anyone running 39" rubber in comps? Thinking about stepping up to bigger meat with everything being chromo now. Would never have tried it with my 4-runner. But with lighter weight of the F-toy it seems like it might be possible. That's still a whole lot of leverage against the toy drivetrain, especially when your hammering. Let's hear your thoughts. I thought someone out there was running 39's? Anyone?
GETTING FLAMED FOR A LIVING AND LOVING EVERY MINUTE!!!
[COLOR=Red]FDNY 343[/COLOR]
F-toy #23 buildup
[url]http://www.pirate4x4.com/forum/showthread.php?t=330266&highlight=formula+toy[/url]
Project Double Wide : F-Toy #23
[url]http://www.pirate4x4.com/forum/showthread.php?p=6542368#post6542368[/url]
FYRDUDE is offline   Reply With Quote
Old 07-04-2006, 12:32 PM   #2 (permalink)
JeepRecoveryTeam's Avatar
Member # 10203
Send a message via ICQ to JeepRecoveryTeam Send a message via AIM to JeepRecoveryTeam Send a message via Yahoo to JeepRecoveryTeam
Hobie's got 38" TSL's
I thought someone had 40's but not sure.
Get Bobbies output and 30 Spliners and hammer down
d
Ultra4 and King of the Hammers
JeepRecoveryTeam is offline   Reply With Quote
Old 07-04-2006, 12:36 PM   #3 (permalink)
FYRDUDE's Avatar
Member # 16686
The only thing I'm missing is the output shaft. I think it might actually be able to handle a little flogging.
F-toy #23 buildup
Old 07-04-2006, 12:37 PM   #4 (permalink)
FYRDUDE's Avatar
Member # 16686
I think it may have been Chopperman?
F-toy #23 buildup
Old 07-04-2006, 01:14 PM   #5 (permalink)
H M F
Im4yotas's Avatar
Member # 8758
Ghettowheeler has 39" Iroks on his F-Toy, but hasn't competed with them. He had to alter the chassis to fit them. Camo had 39's for a short time, but never competed in them either, I believe.
Seams everyone competing runs 36-38" but I am considering running exhibition with my 42's
You should be able to run 39's with minimal breakage, just fitting them will be a problem. Sean's 38" SX's rub a little, so I bet you'd need a tall rig or wide axles to fit them.
Drive it like Tim!
Im4yotas is offline   Reply With Quote
Old 07-05-2006, 08:02 AM   #6 (permalink)
Tech Editor
Air Ride's Avatar
Member # 1656
Todd C. ran 39's at the Donnor comp.
HENDRIX MOTORSPORTS.COM
Threaded Panel Tab Sale
tinbenders.org
camo is my hero, even if he is gay
DirtChoppers.net
Air Ride is offline   Reply With Quote
Old 07-05-2006, 08:03 AM   #7 (permalink)
Tech Editor
Air Ride's Avatar
Member # 1656
tinbenders.org
DirtChoppers.net
Old 07-05-2006, 09:05 AM   #8 (permalink)
FYRDUDE's Avatar
Member # 16686
Did Todd C. have to alter his chassis to fit the 39's? Maybe just running some bump stops in the back would solve that issue.
F-toy #23 buildup
Old 07-05-2006, 09:11 AM   #9 (permalink)
mtbrjon's Avatar
Member # 36007
I am currently running 39.5 Iroks on the 4runner and plan to use those on the F-toy. I hammer the runner pretty hard http://www.orvpark.com/multimedia/dozer-hill.asp ...this was with the 38 sx's but I don't drive any different with the Iroks. I broke 1 short inner birf elim and that was my fault. I'll be using Bobby's 30 spliners and an auto trans so maybe they'll hold up ok. We'll see.
I'll take a couple pics and start my build up thread later this week.
RuffStuffRaceline wheels
FSR fab & radiators
BFG tiresBattlement Fab
FT#48 build2008 East Coast Ftoy champ
"I wanna get me a truck and soop it up with some metal!" -Wingo
mtbrjon is offline   Reply With Quote
Old 07-05-2006, 08:46 PM   #10 (permalink)
Member # 26
The outer-lower bar really limits tire choices unless you mount the chassis way up high, limit your suspension travel, or strech the wheel base way out.
We would like to put on 39's on Matt's FT but the frame limits us to the 37's we have on now. They allready get way into the lower bars.
Chris Geiger is offline   Reply With Quote
Old 07-05-2006, 10:24 PM   #11 (permalink)
ghettowheeler's Avatar
Member # 32191
i had to modify the rear lower fender bars to fit the 39.5 iroks.
Team Ram Rod!
formula 4 32
THATS HOW I ROLL!!!!!!!
ghettowheeler is offline   Reply With Quote
Old 07-06-2006, 03:24 AM   #12 (permalink)
mtbrjon's Avatar
Member # 36007
Are these mods ok for a comp rig?
FSR fab & radiators
Old 07-06-2006, 06:01 AM   #13 (permalink)
CronusTRD's Avatar
Member # 11141
no
Mike
RcRocs 4.3 Toyota Jeep
www.marylandcreepers.com
www.rightcoast4x4.com
CronusTRD is offline   Reply With Quote
Old 07-06-2006, 02:36 PM   #14 (permalink)
FYRDUDE's Avatar
Member # 16686
Ghettowheeler,
What springs are you using? My chassis sits 2" above the frame rail and I have 4" lift springs. I wonder if I installed some bump stops I would avoid hitting the rear bars. But then it would severly limit upward travel. Also, what WB are you running? I was doing some measurements and it looks like the tires will hit at the front of the tire unless I stretch my WB a little. I think I'm sitting close to 107" Maybe less. Also, what backspacing are you running? I almost rub with my 37's and 1.5" wheel spacers. Thanks for the help.
F-toy #23 buildup
Old 07-06-2006, 05:37 PM   #15 (permalink)
Member # 45196
the marlincrawler ftoy had some 40" iroks at the tinbender jambo but it looked like they rubbed bad in the rear of the front tire
96 taco, lockd, linkd, caged, beat, daily driven 24" frame on 4dz ready to jump
toy86 is offline   Reply With Quote
Old 07-06-2006, 09:10 PM   #16 (permalink)
FYRDUDE's Avatar
Member # 16686
After doing a few measurements, I think I would have to move the rear back quite a bit.
F-toy #23 buildup
Old 07-08-2006, 02:10 PM   #17 (permalink)
Member # 2465
I have had 39.5 X 13.5 X 17 IROKS on my buggy since the very beginning. Never looked back. I have to run front wheel spacers to be able to turn at all! And I built the chassis up high from the start for headroom.
Todd C is offline   Reply With Quote
Old 07-08-2006, 02:23 PM   #18 (permalink)
Member # 2465
Well, I was going to add a picture, but lazy Lance hasn't given my star back. I sent him the money almost 2 months ago, and they cashed the check, but still no star.
If someone else wants to post 'em for me, send me an e-mail: ltcdds@pacbell.net
Old 07-08-2006, 09:18 PM   #19 (permalink)
FYRDUDE's Avatar
Member # 16686
Todd C,
What height is your chassis above your frame? Also, what's your WB? We should hit Hollister some time. Didn't know there was another F-toy in the area.
F-toy #23 buildup
Old 07-08-2006, 10:07 PM   #20 (permalink)
Member # 2465
Originally Posted by FYRDUDE
Todd C,
I'm going in the morning (Sunday)! Come AWN.
I'll have to take some measurements for you.
I'm not just in the area, I'm only about four miles towards town from Hollister Hills! Just off Cienega Road.
Cell phone: 831-801-3924
Old 07-08-2006, 11:07 PM   #21 (permalink)
H M F
Im4yotas's Avatar
Member # 8758
Here's Todd C's rig on 39's
Drive it like Tim!
Old 07-09-2006, 03:31 AM   #22 (permalink)
mtbrjon's Avatar
Member # 36007
2 more of Todd's rig. Are your rear springs in board? Looks like you might not have the flex that i'm anticipating but a little hard to tell from these pics and your chassis looks a little high on the frame compared to others i've seen.
FSR fab & radiators
Old 07-09-2006, 07:41 AM   #23 (permalink)
Member # 2465
Oh, heck no!
Rear springs are AllPro from about 4 years ago. I removed the shortest leaf in order to get a little more flex. I don't feel as though I've been limited too much by not inboarding them.
My rig has been so fun and so dependable that most of the time I have just used and enjoyed it. Don't forget, my Formula Toy has been running and pretty much in the same form for over 2 years. Even though Lisa's and Re:Todd's have been done a little longer, they have taken them back apart and rebuilt and changed them a lot more than I have.
Old 07-09-2006, 11:40 AM   #24 (permalink)
FYRDUDE's Avatar
Member # 16686
Have to work Sunday, but we definately need to wheel sometime soon.
F-toy #23 buildup
Old 07-09-2006, 11:42 AM   #25 (permalink)
Member # 32191
Ghettowheeler,
in the front i am running Trail gears 4" springs with the 2 bottom leafs removed with bump stops.in the rear they are some Ford F150 or Ford explorer stock pickn pull specials with no bump stops.with the 37's i was running allpro 4" rears but with the 4D's i had to find a spring with the center pin way offset.from the allpro's to the ford springs it moved my wheel base from 105.5" to 111.5" in order to clear the rear bar.i don't plan on competing any more so i re positioned the rear fender bar.that was the only thing about the ftoy chassis i don't like.i am running 1.5" spacers all the way around with 2.5" back spaced wheels.works great with no more rubbage.
Team Ram Rod!
formula 4 32
