steering shafts and wheels for ftoy & x - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 10-22-2006, 08:16 PM   #1 (permalink)
Member # 62528
Send a message via Yahoo to gm500hprat
Just wondering where you guys by your steering shafts or wheels for your projects. Im considering reusing my tilt column out of my donor truck but that will make it pretty tight with the cnc brake dual master cylinder setup.
X-chassis # 32[URL="http://www.pirate4x4.com/forum/showthread.php?t=511631"][/URL]
gm500hprat is offline   Reply With Quote
Old 10-22-2006, 08:23 PM   #2 (permalink)
Tech Editor
Air Ride's Avatar
Member # 1656
I really like Coleman racing steering parts. I think its colemanracing.com
HENDRIX MOTORSPORTS.COM
Threaded Panel Tab Sale
tinbenders.org
camo is my hero, even if he is gay
DirtChoppers.net
Air Ride is online now   Reply With Quote
Old 10-22-2006, 09:00 PM   #3 (permalink)
H M F
Im4yotas's Avatar
Member # 8758
For the shaft, used parts of a stock Toy steering shaft and U joints (no rag joint), solid 3/4" bar mounted on a couple 3/4" hiems (if you use 3/4" tube, then you will need special oversized "steering shaft" heims as the tube is a cunt hair larger). Steering wheel is a random aftermarket ~13" wheel on a disconnect.
Drive it like Tim!
Im4yotas is offline   Reply With Quote
Old 10-22-2006, 09:29 PM   #4 (permalink)
Matt Messer
ACE-CAGE-#29's Avatar
Member # 39978
X2
Matt Messer
http://www.trail-gear.com
ACE-CAGE-#29 is offline   Reply With Quote
Old 10-24-2006, 06:56 PM   #5 (permalink)
wishes he was racing
Pook's Avatar
Member # 3370
i bought my stuff from speedway motors
http://www.speedwaymotors.com/default.aspx
Pook is offline   Reply With Quote
Old 10-24-2006, 07:43 PM   #6 (permalink)
Member # 76617
I used a bug pack cut to lenght buggy shaft and welded the splined end on one end and the hex for a quick release wheel on the other also used the stock steering u-joint. If it flexes at all I dont notice it
Wright racing
F-TOY #22
Hi desert driveline
losi
rcp crawlers
A Samauri is not an f-toy
A samauri is not an f-toy
benttoy is offline   Reply With Quote
