rule clarification - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-22-2006, 09:02 AM   #1 (permalink)
Member # 30134
rule clarification
This may be a better question for Big Rich, but I wanted to run it by you guys first.
In the Formula Toyota rules concerning the transmission tunnel, the rules state:
Transmission tunnels are not required but a driveshaft loop and cover to protect the driver from the rear u-joint is necessary.
In an event such as PUSU, I think (guessing) we fall under the unlimited class rules. Is this true?
From the Werock site the rules concerning the tranny tunnel for the unlimited class state:
3.5.4: Exposed transmission components must be covered with a safty shield to protect occupants from possible exposure to transmission fluids in the event of transmission case fractures or unforseen fluid spills.
At PUSU will we be required to have a covered tranny tunnel?
azyota is offline   Reply With Quote
Old 12-22-2006, 10:23 AM   #2 (permalink)
desertoy's Avatar
Member # 292
You;ll be ok for PUSU. You will need to put in a driveshaft loop and cover just the u-joint area to compete this season though.
John James
Team Marlin Crawler
X-Chassis #12
6 time KOH finisher
2008/2009 W.E. Rock West Coast Series Champion
2008 Pro Rock Champion
Just "HAMMER" it!!
My Buildup /forum/general-4x4-discussion/298203-desertoy-mustard-dog-build-pair-x-chassis.html
desertoy is offline   Reply With Quote
Old 12-22-2006, 10:48 AM   #3 (permalink)
Member # 30134
Right now that area looks like this.
That should be good to go, right?
Old 12-22-2006, 11:37 AM   #4 (permalink)
a2b
a2b's Avatar
Member # 22547
and cover you bell housing so that the slave cylinder is covered
-Hobie
GOTPROPANE.COM
HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER!
a2b is offline   Reply With Quote
Old 12-22-2006, 02:57 PM   #5 (permalink)
Member # 51921
Pat,
You'll want to make sure fluids can't enter the cab but your tube/sheet work over the flange looks tight.
Mark Van Meter
Secretary, TLCA
[url]http://www.tlca.org[/url]
Nissan Recovery Team is offline   Reply With Quote
