Rear Spring question. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-01-2007, 09:14 AM   #1 (permalink)
Member # 74816
What is the desirable rear spring to run on the F-toy, I thought i read somthing about chevy springs. I found some chevy springs from a 90' 1/2 ton 2wd for $50 obo. (3 leafs + overloads).
Just wanted to confirm that this was the right spring. & I'll keep sifting throught the build ups to look for what i thought i had read.
Thanks guys.
DeeK.
Deek01 is offline   Reply With Quote
Old 02-01-2007, 10:23 AM   #2 (permalink)
a2b
a2b's Avatar
Member # 22547
no chevys suck suck suck. they are not good options for ftoys. if you need cheap rears, get some used 56" rears from somebody on this board. or you can try to some s-10 mazda springs, i have never done it though. just make sure they are 56" or shorter springs.
-Hobie
GOTPROPANE.COM
HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER!
a2b is offline   Reply With Quote
Old 02-01-2007, 11:28 AM   #3 (permalink)
RE:Todd's Avatar
Member # 422
I started with Ranger/Bronco II leaves. I now have Deavers
Todd Steele
TINBENDERS
Formula Toy #006; Thanks to Deaver Spring, High Angle Driveline, Longfields, Rock Buggy Supply, PRP Seats, Marlin Crawler, Coast Motor Supply and RockStomper.
[url=http://www.tinbenders.org]TinBenders.org[/url]
RE:Todd is offline   Reply With Quote
Old 02-01-2007, 01:56 PM   #4 (permalink)
Member # 74816
allrighty then, thats a no go.
Thanks for the input guys!
Old 02-01-2007, 03:05 PM   #5 (permalink)
wishes he was racing
Pook's Avatar
Member # 3370
I'm using the 51" stock rear springs built up into a 6 leaf pack and ran backwards, thats what Heywood was running too not sure if he changed it before he sold. I get decent flex, could use a bit more droop, but its good enough for me. Its real stable feeling.
Pook is offline   Reply With Quote
Old 02-01-2007, 04:50 PM   #6 (permalink)
Member # 76617
We started with beat to hell all pros in the rear and it worked so so. Now we have Trail gear 5in. at all 4 corners and they are awesome! We pulled the very bottom leaf out and may take one more to get the height down, But they flex good
Wright racing
F-TOY #22
Hi desert driveline
losi
rcp crawlers
A Samauri is not an f-toy
A samauri is not an f-toy
benttoy is offline   Reply With Quote
Old 02-01-2007, 05:41 PM   #7 (permalink)
mtbrjon's Avatar
Member # 36007
I got allpoop 3" buggies front and rear. Haven't really wheeled it much yet but looking like i'll want more up travel on the front so am thinking i'll be changing out to a set of AP 5" fronts (that I already have) and removing leafs as needed. Then i'll do whatever I need to the rears to even it out.
RuffStuffRaceline wheels
FSR fab & radiators
BFG tiresBattlement Fab
FT#48 build2008 East Coast Ftoy champ
"I wanna get me a truck and soop it up with some metal!" -Wingo
mtbrjon is offline   Reply With Quote
Old 02-02-2007, 10:41 AM   #8 (permalink)
Member # 74816
Maybe this is what i was reading!
/forum/toyota-truck-4runner/20665-63-chevy-1-2-ton-spring-swap-faq.html
