Yes i did a search - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-05-2007, 04:42 PM   #1 (permalink)
Member # 20571
Send a message via AIM to rickibrat2 Send a message via Yahoo to rickibrat2
Yes i did a search
did not find any clear picture's of how rear shocks are set up.
Basic trying to find out if people are going str8 up and down or at what angle are we setting them in
I have to re do the one's I had made as they are binding and I think angle is to great
I was using the sky rear shock mount
have a extra set flipped of spring plates was thinking about putting them on top over the mounting bolts that hold the rear plates and and building a shock mount to those then going str8 up and foreward at about a 5 degree angle and drillting thought the back support tube and bring a bolt tong that hole
Will mean compressing the shock about 6 inch to get it on the bolt but I have 14 inchs of travel with these shocks so i should stll have about 7 inches
rickibrat2 is offline   Reply With Quote
Old 02-05-2007, 04:59 PM   #2 (permalink)
Member # 30134
Here is how I did mine. So far it's working okay and I havn't had any problems with it.
azyota is offline   Reply With Quote
Old 02-05-2007, 04:59 PM   #3 (permalink)
desertoy's Avatar
Member # 292
Sounds like your plan will work. Instead of drilling through the tube, why not just weld on shock tabs though.
When you are installing them, just tack the tabs on, then flex the suspension out to check shock travel and clearance. Once you get it right, weld it solid.
John James
Team Marlin Crawler
X-Chassis #12
6 time KOH finisher
2008/2009 W.E. Rock West Coast Series Champion
2008 Pro Rock Champion
Just "HAMMER" it!!
My Buildup /forum/general-4x4-discussion/298203-desertoy-mustard-dog-build-pair-x-chassis.html
desertoy is offline   Reply With Quote
Old 02-05-2007, 06:50 PM   #4 (permalink)
Hammer Hog's Avatar
Member # 24269
Location: Way closer to the Hammers than you!!! Was Montrose, CO
Seems that the more your shocks are straight vertical, they either need to be longer travel or set inboard. The more they are in-boarded, the more likely body-roll will play in. I set my lower mounts outward and angled in at the top. I have no issues with my setup. However I've seen a few that have notched their frame to accommodate the shocks due to that the frame rails are in the desired location of where I'd prefer to have them...(IMO)
Here's mine as I was building. The uppers were not mounted yet, but is close to where they are mocked as shown.
Official OG13-2013 KOH Recovery Team.
Formula Toy #11 is For Sale... PM me.
Hammer Hog is offline   Reply With Quote
Old 02-05-2007, 08:08 PM   #5 (permalink)
Vortec_Cruiser's Avatar
Member # 17300
What size tubing is used for shock hoops (diameter & wall)?
Ed Gilbert
1977 FJ40, 5.7L Vortec
F-Toy #F006 build in-progress
[email]vorteccruiser@charter.net[/email]
Vortec_Cruiser is offline   Reply With Quote
Old 02-05-2007, 08:43 PM   #6 (permalink)
Member # 30134
I used 1-1/2" x 11ga (.12) wall for mine.
Old 02-05-2007, 08:52 PM   #7 (permalink)
Member # 17300
That's what I thought, but just wanted confirmation. Thanks -
Ed Gilbert
Old 02-05-2007, 10:47 PM   #8 (permalink)
a2b
a2b's Avatar
Member # 22547
most people just usually just get the shocks where they fit as apposed to the best angle. but if you want the best angle, straight up and down is great for the woops, but for rock crawling, try to put your shock where it will end up being a 90 degree angle when the axle is compressed up and the other side is drooped out. sitting flat, the shocks should be where those yellow lines are. mine arent that way in the picture because the fuel cell was in the way. i just moved them last week and now they are that way. i mounted the shocks to the ubolt plate to the ftoy cross member behind the seats. that way, i didnt have to add any tubing or anything for the shocks. just to keep it simple.
-Hobie
GOTPROPANE.COM
HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER!
a2b is offline   Reply With Quote
