Window nets - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-16-2007, 10:51 AM   #1 (permalink)
Member # 30134
Window nets
Anyone have a good recomendation for a window net and mount that fit's the opening of an F-Toy pretty well. I have only found one place here in Tucson that carries that sort of stuff, and they don't have much.
Pics if you got them...
Thanks,
Pat
azyota is offline   Reply With Quote
Old 02-16-2007, 11:54 AM   #2 (permalink)
wishes he was racing
Pook's Avatar
Member # 3370
x2. what dimensions are you guys using? can anyone post pics of mounting and whats working for you.
Pook is offline   Reply With Quote
Old 02-16-2007, 02:10 PM   #3 (permalink)
a2b
a2b's Avatar
Member # 22547
i have seen all different size among the ftoys in window nets. matt runs the spegetti wire window net which is easier to see out of. the one i run is the full size of the window which made it easier to mount. for the bottom mount, i ran a peice of flat bar thru the net and then pop rivoted the ends into the chassis on the inside of the frame. for the top i ran a piece of small round solid, thru the window net and welded one side to a seat belt buckle. then welded the tab for the buckle on the inside of the A pillar on the chassis. i welded a piece of bushing tube that i had laying around to the other side for the peice of round solid to go into before i buckle it. its so solid you can hang on the window net.
-Hobie
GOTPROPANE.COM
HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER!
a2b is offline   Reply With Quote
Old 02-16-2007, 03:38 PM   #4 (permalink)
Member # 30134
Thanks Hobie! Here is a little bit of what I have found. Anyone use these? http://www.stockcarproducts.com/safety8.htm
I'm just out of time right now to get this done. Can I just use ratchet straps and get in from the pass side?
Old 02-16-2007, 05:57 PM   #5 (permalink)
Member # 76617
The net you found is like mine. I mounted mine like Hobies on the top but on the bottom mount I welded bushings at each end that I slide round bar thru and hose clamp on both ends. this way I can take the net off when not needed
Wright racing
F-TOY #22
Hi desert driveline
losi
rcp crawlers
A Samauri is not an f-toy
A samauri is not an f-toy
benttoy is offline   Reply With Quote
Old 02-16-2007, 06:18 PM   #6 (permalink)
Member # 22023
Window Netting
Check with Robbie at Mastercraft. He will make them to size.
http://www.mastercraftseats.com/access-windownets.shtml
04 Dodge 2500
03 Rubicon Heep
85 X Cab
10 Rzr
Bo Neece is offline   Reply With Quote
Old 02-17-2007, 01:20 AM   #7 (permalink)
Pook's Avatar
Member # 3370
were the pics?
Old 02-21-2007, 08:59 PM   #8 (permalink)
Member # 30134
Originally Posted by Pook View Post
were the pics?
No time for pics yet, I'm too busy trying to get my junk ready for this Vegas.
I ended up getting a window net and mount from Summit. It was about as simple as it gets to put in. The part numbers are BOB-1000 for the net http://store.summitracing.com/partde...0&autoview=sku
And BOB-90906 for the mounting kit http://store.summitracing.com/partde...0&autoview=sku
It includes everything you will need to mount to a F-toy chassis. I'll put up a couple pics next week.
Old 02-21-2007, 09:21 PM   #9 (permalink)
FYRDUDE's Avatar
Member # 16686
I got mine from summit with the install kit cheap. I got the mesh one, not to be confused with the string net.
GETTING FLAMED FOR A LIVING AND LOVING EVERY MINUTE!!!
[COLOR=Red]FDNY 343[/COLOR]
F-toy #23 buildup
[url]http://www.pirate4x4.com/forum/showthread.php?t=330266&highlight=formula+toy[/url]
Project Double Wide : F-Toy #23
[url]http://www.pirate4x4.com/forum/showthread.php?p=6542368#post6542368[/url]
FYRDUDE is offline   Reply With Quote
Old 02-22-2007, 11:57 AM   #10 (permalink)
Pook's Avatar
Member # 3370
Thanks, ordered it up
