Line lock - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 02-27-2008, 06:34 PM   #1 (permalink)
ftoy507's Avatar
Member # 92235
Line lock
I am having a problem finding the fittings to adapt my 1/8npt line lock to toyota metric.
Any suggestions or sources for the adapters???
Does anyone make a metric fitting line lock?
Here is the line lock I have.
http://store.summitracing.com/partde...5&autoview=sku
ftoy507 is offline   Reply With Quote
Old 02-27-2008, 07:04 PM   #2 (permalink)
wishes he was racing
Pook's Avatar
Member # 3370
Are you using steel brake tubing? Just put some standard fittings on it
Only metric brake fittings on my truck are the front calipers steel braided hoses connections.
Pook is offline   Reply With Quote
Old 02-27-2008, 07:07 PM   #3 (permalink)
a2b
a2b's Avatar
Member # 22547
what he said. its so simple people tend to over look this.
out of your master cylinder run a metric or standard fitting (depends on your mc) then to your line lock, put on a standard fitting.
then from line lock put standard to metric
-Hobie
GOTPROPANE.COM
HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER!
a2b is offline   Reply With Quote
Old 02-27-2008, 07:07 PM   #4 (permalink)
ftoy507's Avatar
Member # 92235
Yes the lines are steel. The problem seems to be the 1/8 npt. I am not finding a fitting with 1/8 npt threads that I can flare. Also it is not an inverted flare. Might be a bubble flare.
I am beginning to think i am overthinking this thing
Old 02-27-2008, 07:08 PM   #5 (permalink)
a2b
a2b's Avatar
Member # 22547
the brake fitting doesnt go straight into the line lock (if its like mine from jegs) it goes into an standard adapter that goes into the line lock
-Hobie
GOTPROPANE.COM
Old 02-27-2008, 07:27 PM   #6 (permalink)
Pook's Avatar
Member # 3370
x2
Small little brass NPT to brakeline adapter, can be found in almost any auto parts store.
Old 02-27-2008, 07:30 PM   #7 (permalink)
ftoy507's Avatar
Member # 92235
Originally Posted by Pook View Post
x2
Now I think i understand.
There were no adapters included with the line lock.
I need an adapter to go from 1/8 npt to 3/16 double flare.
put a 3/16 brake nut on my existing line and double flare. Then repeat for the outlet.
Old 02-27-2008, 08:57 PM   #8 (permalink)
Member # 78096
I found some 1/8 NPT fittings with 3/16 compression fittings on the other end for mine.
Looked like these but stainless instead.
Jeep07 is online now   Reply With Quote
Old 02-28-2008, 07:33 AM   #9 (permalink)
Member # 76617
We just used 3/16 line and double flair the ends w/toy fittings where needed
Wright racing
F-TOY #22
Hi desert driveline
losi
rcp crawlers
A Samauri is not an f-toy
A samauri is not an f-toy
benttoy is offline   Reply With Quote
Old 02-28-2008, 01:06 PM   #10 (permalink)
ftoy507's Avatar
Member # 92235
[/QUOTE]
This seems real easy. Is it working?
I am a little concerned about that type fitting on brakes.(now that I am older) I have repaired a broken brake line, with a compression coupling before and it worked fine for years. (when I was young and broke)
