FToy #94 - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-10-2009, 10:02 PM   #101 (permalink)
zman2day's Avatar
Member # 6631
Its alive!!
Alot of progress this weekend. Got the control panel mounted and wired up. It's a mock up in sheet metal, hopefully if time allows, will be done right in aluminum, but for now its crude but functional. I incorporated the Kill switch and attaches to the (dash)bar down by the hood. For functionality all the wiring is done, Gauges, temp and oil senders, winches, starter, alt, ignitor, and propane solenoid. After a bit of tinkering and few dozen more pirate4x4 searches it finally came alive. So now that its running its time to tackle the brakes. Got some new pads to throw on, lines to make, and some linelocks to install. Then hook up the CO2 tank to the ARB's.
Anyone running a Rear proportioning valve? I have one on my trail truck but wasnt sure if I needed one for in the F-toy? I am running the FJ80 1" bore master cylinder in the F-toy and the Trail truck I have a 4runner V6 1" bore MC?
Here are some pics of the progress.
Front view
Side view
Rear View
Ignition panel
Guages (still need to fab housing on dash)
CO2
Driveline
F-Toy #94
2010 W.E. Rock East Coast Ftoy champion
F-Toy Sponsors
Wabfab Off-Road
TOYTEC Lifts
Ruff Stuff Specialties
zman2day is offline   Reply With Quote
Old 05-11-2009, 07:54 AM   #102 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
Really clean nice work!
MT4Runner is offline   Reply With Quote
Old 05-11-2009, 02:28 PM   #103 (permalink)
Member # 78096
Originally Posted by zman2day View Post
I like that drive shaft cover behind the disco.
Jeep07 is online now   Reply With Quote
Old 05-11-2009, 07:01 PM   #104 (permalink)
Member # 110396
Man that thing looks SICK! I'm still not sure about next comp, it's probably going to be the the week before until I'm 100% sure. It is looking pretty promising though. Just gimme a ring and let me know when yall are going to leave.
hmmwv15 is offline   Reply With Quote
Old 05-12-2009, 04:51 AM   #105 (permalink)
zman2day's Avatar
Member # 6631
Thanks for the compliments..
Funny you say that it actually was just one of those "screw trying to get fancy" moments. Just simple and functional. We kept on thinking of the best ways to mount it to the tcase with an aluminum shroud. But after WAY too much thinkin we just said screw it grab me that angle and pipe and welded it. But we took the time to tap screw holes for the metric bolts. As 99% of the buggy is all threaded. Hardly any nuts used except for springs and tcase x-member.
Got the linelock bracket fabbed last night and lines run from the MC to the linelocks and to the front and back axle. Tonight will make up the brake lines on the axle housings to the discs.
F-Toy #94
F-Toy Sponsors
Wabfab Off-Road
TOYTEC Lifts
Old 05-12-2009, 07:54 PM   #106 (permalink)
Member # 67768
looks good cant wait to see it at the next comp
scrappy1982 is offline   Reply With Quote
Old 05-13-2009, 06:15 AM   #107 (permalink)
zman2day's Avatar
Member # 6631
Spence and I got the brakes installed and bled last night. Except for the knucklehead who lost the pins and springs to the Passenger side caliper ) Should be able to grab some hardware today. Gotta re-bleed the rear calipers by taking them off and tilting the bleeder screw to the top. I had the same issue on my trail truck with the Monte Carlo disc setup. Then hopefully the rear line lock will disengage properly. The front works fine. I will definitely need to do some beefing up on the petal setup. I got way too much movement when I jam on the brake for those O' sh*t moments.
Forgot my camera at the house.. pics soon.
F-Toy #94
F-Toy Sponsors
Wabfab Off-Road
TOYTEC Lifts
Old 05-13-2009, 07:34 AM   #108 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
You do clean work!!
I don't have rear discs (yet). I'm running IFS calipers/FJ rotors up front, and stock IFS drums in the rear. It stops on a dime with a 4runner V6 1" bore MC.
I've got rear discs in my 4Runner, and need to pull off the LSPV and try an adj. prop valve on it--I'm not happy with the rear braking effort on it.
Old 05-13-2009, 07:33 PM   #109 (permalink)
Douche Canoe
netwt12's Avatar
Member # 113684
well atleast spencer got his truck off the trailer. the f-toy looks great, i can't wait to see it moving.
85 Yota nerf bars, truck nuts, leveling kit, floor mats, etc.
netwt12 is offline   Reply With Quote
Old 05-13-2009, 10:20 PM   #110 (permalink)
Supra 4x4's Avatar
Member # 40622
While the f-toy was at the muffler shop I got mine almost ready for SE4RJ. Beefed up the frame behind the BudBuilt cross member and tied the 1/4 plate into the Chevy spring hangers to help scrape over the rocks. Made a new heavy duty drive shaft, & replaced my broken e-brake cable. Maybe find time tomorrow to get it to the muffler shop to replace the busted cat from River rock. Pretty sure we will have the F-toy ready for a test run this weekend.
Supra 4x4 is offline   Reply With Quote
Old 05-15-2009, 05:08 AM   #111 (permalink)
zman2day's Avatar
Member # 6631
I ended up short cutting and using a pre-made gauge pod. Figured it was what I wanted the aluminum one to look like anyhow.. saved a bunch of time too.
Got the exhaust wrapped up last night
The line locks installed... I will be adding a proportioning valve in there too so it may be changed around a bit.
F-Toy #94
F-Toy Sponsors
Wabfab Off-Road
TOYTEC Lifts
Old 05-15-2009, 12:03 PM   #112 (permalink)
Low Budget Baller
TERRYJMATTHEW's Avatar
Member # 37478
Looking good!
-Matthew
Cruiser poor.
TERRYJMATTHEW is offline   Reply With Quote
Old 05-15-2009, 02:06 PM   #113 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
Sorry I missed the most important part of your Sunday post.
It's a fawkin' great feeling to hear your FToy running after all that hard work, isn't it?!?!
When I met Mike Hendricks @ KOH, I thanked him for the project and the nice chassis--and told him I had absolutely no idea how much work it was going to be. He grinned, and said, "you forgot all about that the first 10 seconds you drove it, didn't you?" I laughed: "YES I DID!!"
See you on the trail!!
..and buckle up!
Old 05-25-2009, 08:21 PM   #114 (permalink)
Member # 75648
This FToy is PIMP
Im on the work computer and cant upload the video, but this buggy made my truck look like shit. Take how much better my truck climbs that a Heep on tons, and that is how much better his buggy climbs than my truck
Ive never been impressed with the rockwelled, 454, 47", buggies that are common around here, but I am deffintly impressed with this buggy.
I dont know if it was the stickies, the weight, or what (I know it wasnt the driver ) but it clearly pulled some lines that none of us in the trucks could. I was ready to cut mine up after the 3rd hill
Congrats Mark on a CLEAN and pimp FToy
sellout
TachedOutOffRoad is offline   Reply With Quote
Old 05-25-2009, 08:51 PM   #115 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
You can't tease us like that--we need trail pics!!
Old 05-26-2009, 05:06 PM   #116 (permalink)
HillBilly_Young01's Avatar
Member # 72091
Send a message via AIM to HillBilly_Young01 Send a message via Yahoo to HillBilly_Young01
it was good to see the rig out and wheeling finally!!!! you get any pics or vids of you going up boat ramp?
Matt Young
2002 Toyota Tacoma- semi drivable
1999 Dodge Ram 1500- tow rig/ dd
Facebook
HillBilly_Young01 is offline   Reply With Quote
Old 06-02-2009, 09:46 AM   #117 (permalink)
Member # 30713
Some jackass dosen't know how to work a camera, But I saw what I considered to be two preaty capable yotas get embarassed on boat ramp. On any given day on the trail I feel like my 37ed tired yota will hang with almost anybody (with me at the wheel of coarse), but this thing super crawled boat ramp open front and rear never breaking idol. We both gave it 5 or 6 full throtle 2nd 3rd gear trys with no results.
He also crawled up several other hills with ease. Like Clay said I dont know if its the weight or the tires or what but wow.
I know I yeld up the hill at my wife to ask if I could take out a loan to buy some stickies and I got a very quick Yes . I think she wants my Irocs.
You could tell mark was preaty happy with it after almost a year of work.
Yaker is offline   Reply With Quote
Old 06-02-2009, 10:18 AM   #118 (permalink)
Douche Canoe
netwt12's Avatar
Member # 113684
hannibal pics?
Old 06-02-2009, 12:01 PM   #119 (permalink)
zman2day's Avatar
Member # 6631
I didnt have my camera but here's a few pics I found from SE4RJ -
I believe there is a U-tube video out there too...
Hannibal Pics on my website
F-Toy #94
F-Toy Sponsors
Wabfab Off-Road
TOYTEC Lifts
Old 06-02-2009, 12:14 PM   #120 (permalink)
Always Late
ToolBox Guy's Avatar
Member # 89541
Very nice rig. Good, clean, simple fab work! I dig it.
ToolBox Guy is offline   Reply With Quote
Old 06-02-2009, 05:29 PM   #121 (permalink)
Member # 75648
damint! I guess I have to finish the video tonight
sellout
Old 06-03-2009, 10:23 AM   #122 (permalink)
toyotanuts's Avatar
Member # 27286
Send a message via AIM to toyotanuts
got a pic of all the damage yet? Was it just the back bar? Was glad to hear you was alright, It hurt me just watching. I hope someone got that on video!
Jeremy
87 samurai, 39's, d60, 14b, 6.0, atlas
ready to rock.
toyotanuts is offline   Reply With Quote
Old 06-16-2009, 08:20 PM   #123 (permalink)
Member # 75648
Mark CRAWLED Boatramp TWICE, and all I get is a clip of him backing down it Im ashamed.
If you watch closely, you can see him crawl a quite a few places and our trucks (which I used to think were badass ) either struggle, or not go up at all.
YouTube - SE4RJ6 SouthEast 4Runner Jam 2009 Chocolooco Mountian
sellout
Old 06-16-2009, 08:23 PM   #124 (permalink)
Member # 75648
I am an awesome spotter:
"hit it!"
"second gear!"
"go mothtfuka!"
"no! your other left!"
I consider myself more of an offroad motovation speaker than a real spotter
sellout
Old 03-29-2012, 01:20 PM   #125 (permalink)
Poser wheeling
dragr1's Avatar
Member # 26296
Wonder what ever happened to this pile?
1985 4Runner lockers exo duals 37's
1985 4runner SR5 stock, clean, and nice
'12 Ram 3500 SRW Crewcab 4x4 Cummins
'07 Tacoma Double Cab 4wd TRD 286k mile work truck
http://www.thegreatamericanpark.com/
dragr1 is offline   Reply With Quote
