Member # 81153
Electric fans
What fans are you guys running I'm running the flex-a-lite fan and I've had problems from the begining. It is really nice though it bolts to the radiator, no zip tyes needed. Any suggestions?
Nathan Unruh Unruh Racing Ultra 4 Car #4477 Formula Toy #063 Last edited by Napolian; 08-11-2009 at 10:50 AM. |
Member # 103621
Srock Ford Taurus electric fans.
--Alex-- 1982 Toyota 4x4 - The Dirt Squirrel: Phase II underway: 4.3L CPI, TH350, Marlin 4.7s/D300 doubler, D60/14B/5.13s, f150 leafs up front, artec 4-linked rear, Coilovers, blah, blah blah. |
noob
Member # 66544
Taurus 2 stage but never use the high.
El Destructo! I void warranty's!!! Team Rock Limo F-Toy #F002 Yukon gear/Randy's Ring & Pinion, Trail Gear, BFGoodrich Tires, RuffStuff, 12 Volt Guy |
Member # 36007
Spal. There are no others in my opinion. I use a cool temp sensor we get from Summit and a beefy 70amp relay I get from a buddy at Comp Cams (Fast fuel inj). No failures to date.
Here is the 12" Spal with custom shroud from my buddies at FSR on a FSR heavy duty radiator. This fan pulls 1800 CFM, with this shroud will be more than adequate for this radiator. Normally I use a 14" or 16" but this is for a buddy's truck with limited space so the fan needed to be offset.
RuffstuffRaceline wheels FSR fab & radiators BFG tiresBattlement Fab FT#48 build "I wanna get me a truck and soop it up with some metal!" -Wingo Last edited by mtbrjon; 08-12-2009 at 08:28 AM. |
Member # 81153
I've had problems with the t-stat switch from the begining it will intermitintly work. I'll have to hop out of the buggy and jiggle the switch to get it to turn on if the buggy starts to get hot. I can't remember where I got it, but do you think there is any sort of warranty on them.
Nathan Unruh Unruh Racing Ultra 4 Car #4477 Formula Toy #063 |
Member # 6631
I run a 12" SPAL fan and thermo switch. Came with Griffin Radiator/Shroud/fan combo.
F-Toy #94 2010 W.E. Rock East Coast Ftoy champion F-Toy Sponsors Wabfab Off-Road TOYTEC Lifts Ruff Stuff Specialties |
#12 (permalink) |
Member # 25927
vovlo fan - at high speed it will easily suck a rag to the radiator.
Dana 60 or 14 bolt disk brake kits $315 shipped --> click here Dana 70 kits $300 --> click here . . Sterling 10.25 kits $390 --> click here Dana 60 front 3/4 ton kits $350--> click here |
