Super Moderator
DRM's #515 Not-so-F-Toy
I picked this up in late 2008, and it has sat in my shop for almost a year used for little more than an indoor jungle gym for my kids
![]() This past weekend, I finally started working on it. Basically - the previous owner rolled his trail truck and picked up an F-toy chassis to drop on top. He got burnt out, and I picked it up as it sits. What it has right now: -Fresh rebuilt 22re that needs finished buttoning up and started for the first time -5 speed & dual cases -BudBuilt crossmember -Complete propane kit ready to install w/ 2 al tanks -5.71 geared axles, rear spool, front lockright, Longfields, hydro assist, -Practically brand new 39" TSL's on black wagon wheels -New Corbeau front seats -Floor and trans tunnel built and in place. The pics sent to me by the PO: I posted a few times that I wasn't sure what I wanted to do with it - link it, cut it up, sell it, etc. I finally decided I just need to get it finished since basically everything was there to at least get the thing out on the trails.
>David > 4x4Spot.com >It only hurts the first time you agree with me... >"A little nonsense now and then is cherished by the wisest men." Last edited by DRM; 10-20-2009 at 06:34 AM. |
Super Moderator
So in Saturday I dug out all of the boxes the PO included with the deal and started trying to figure out what needs to happen.
The motor had been rebuild, but needed to be finished buttoning it up. Luckily the PO had included all of the necessary gaskets and seals for us to wrap that part up. I had also picked up an 82 donor truck with the Ftoy, but the 20r in it has made stealing some parts just not work out. About as far as we got this weekend was temporarily wiring up battery, coil/igniter and just trying to get it to turn over. We got as far as getting it to turn over and crank before the OEM 82 igniter decided it wanted to stop working. Here are a few pics from Saturday, and hopefully - I am setting a tentative trail test by New Years Day.
>David > 4x4Spot.com >It only hurts the first time you agree with me... >"A little nonsense now and then is cherished by the wisest men." |
Member # 9771
I have a flat firewall like you have in the pictures. If was to do it all over again I would push the firewall out into the engine bay to add a little more leg room. I'm only 5'7", so if your tall you'll really appreaciate that change.
I like to stack rocks on the trail. |
Tech Editor
Member # 1656
Definitely ditch the fire wall and I also would move the motor back 8".
HENDRIX MOTORSPORTS.COM Threaded Panel Tab Sale tinbenders.org camo is my hero, even if he is gay DirtChoppers.net |
#5 (permalink) | ||
Super Moderator
As for the motor - I wanted to get it running, then it will get moved the full 8" allowed. I really want that flat front with the winched tucked in behind the crossmember.
#6 (permalink) | ||
IDIot!
Member # 44480
The only things you really have up there are your steering box, steering pump, brakes/clutch, and alternator. The box, pump, and alt are all on the very front of the motor and your brake booster doesn't get into that space. Go for 8" if not 10" forward. Check out Air Ride's 'Ultimate Formula Four Build' to see how to fit the forward footwell and firewall around the engine moved back 8". Do this soon!!--as you're buttoning up the motor, you're probably already looking for places to hang the igniter and p/s reservoir.
Motive Gear Land Use Team http://www.tenfactory.com http://www.motivegear.com http://www.nationaldrivetrain.com http://www.davezoffroadperformance.com http://www.mastercraftsafety.com FToy 086 - UHaul Toterhome |
Member # 30839
Bummer if they told you that it was my kit when they sold it to you. Looks like the ebay kit you have there.
Bulletproof, complete propane kits for carbureted offroad and street vehicles. Please visit our website for details. www.gotpropane.com
#8 (permalink) | |
Super Moderator
![]() Stop raining on my parade
Super Moderator
No pics until tommorrow, but we worked a good part of the day piddling with it and it now runs on propane
![]() I used the GM ignitor and coil since it seemed easier - went together ok. I also started cutting the floor out, and should have it completely out tomorrow night along with the firewall. With that done, everything will be out of the way to move the engine back the full 8" so I can figure out the new firewall location as well as the seats. It's slow... but at least it's progress ![]() ![]()
Super Moderator
Just some quick cell phone pics for now - motor as it sits in running condition, and hacking out the floor that was in it when I got it.
#12 (permalink) |
Super Moderator
Just a little update to this.
The Ftoy sat for another year practically untouched, until back about a month ago a buddy begged me to sell him the chassis only so he could build it. With me having gotten so discouraged having to re-work so much of the previous fab work, I stripped the drivetrain out and sold it to him. Then, through an odd twist of fate - I ended up buying it back 2 nights ago when he delivered it back to in front of my shop. ![]() This time, I'm doing it like *I* want it - so tonight I cut the toyota frame and plate floor out of it. The pictures didn't come out - but as it sits right now, the Ftoy chassis is sitting on it's own, ready for me to clean up and set up with my drivetrain in the shop and start building a sub-chassis and the rest of the frame when I get back from Dixie Run next weekend. This time it is planned to keep the Toyota drivetrain, get coilovers and 4 linked front & rear.
#13 (permalink) | |
Chubby Chaser
I'll probably have one for sale in late Feb
Eric Anderson TIN BENDERS Hendrix XR Chassis #001 Ultra4 #66 4Wheel Parts, Raceline, PSC, Bilstein, Marlin Crawler, Smittybilt, HendriX, PacificFab, G2 Axle, PAC Spring, G&J, MAXXIS Roxy's in the industry and I'm a sponsored professional driver. The two of us together make a powerhouse. Accepting the things I cannot change. |
#15 (permalink) |
Chubby Chaser
Hendrix is building us a new chassis, after KOH the running gear get's stripped out and everything else gets sold, either as a package or parted out.
#16 (permalink) |
Super Moderator
The way things have worked out - I've got so little wrapped up in this Ftoy chassis, turning it into a full buggy chassis is not gonna cost me much money or time.
>David > 4x4Spot.com >It only hurts the first time you agree with me... >"A little nonsense now and then is cherished by the wisest men." Last edited by DRM; 01-02-2011 at 07:44 PM. |
#17 (permalink) | |
Non-Lemming
Member # 840
That almost caused me to have a heart attack.
#18 (permalink) | |
www.12voltguy.com
Member # 40
DRM wheels?
12voltguy info@12voltguy.com--davezoffroadperformance.com # 530.532.4529![]() TTC 2010 1989 BRONCO -Awesome web development for your business. www.mudnworks.com mud@mudnworks.comPat's W I D E TOYOTA Front Axle --07 KTM 450XC----with "stuff" |
#20 (permalink) |
www.12voltguy.com
Member # 40
#21 (permalink) |
Member # 11983
x2 was thinking the same thing pros and cons in doing it but just picture trying to see over the engine going down the cliffs on jackhammer. Maybe you already posted but any plans to keep the jungle gym and add a back seat?
My crappy build [url]http://www.pirate4x4.com/forum/showthread.php?t=587635[/url] |
#23 (permalink) |
Super Moderator
The chassis is currently sitting in my shop having been cut off the old frame. One way or another, something is going to get done with it. Depending on which direction I go determines how fast it gets done.
#24 (permalink) |
Super Moderator
Well, I loaded it up on the trailer and dropped it off @ Mo-Fab's Shop. I just don't have the time, and I felt Amos could get it to a rolling chassis for me and let me take it from there.
Already picked up some of the parts, still got some more to buy in the next few weeks. Here's what is going in it: 22r on propane 5speed, dual cases (considering adding 4.7's to the rear case) 60's (yes, from my 4Runner - it's getting dismantled )Also the 39.5" Pitbull Rockers and H1 rims from my 4Runner Full tube chassis built under the F-toy body 2" aluminum links 14" coilovers (Bilstein remote reservoir front, Fox rear) air bumps up front (maybe in the rear too) Full hydro steering w/ double ended ram Seating for 5 (3 kids in the back - if I can)
>David > 4x4Spot.com >It only hurts the first time you agree with me... >"A little nonsense now and then is cherished by the wisest men." Last edited by DRM; 01-05-2011 at 08:16 AM. |
#25 (permalink) |
Member # 122462
I wish I knew you lived so close to John Duvall. I bought a truck from him awhile back and he just now told me you live right around the corner. Loved to stop by and checkout your rigs.
*UNDER CONSTRUCTION* Wide Open Design Revolution Built L33 alum 5.3/400/Atlas/HP60/14/ORIs/Reds/Trailreadys 2500 CTD 4x4 6spd tow rig www.hawkpridemountainoffroad.com www.wideopendesign.com |
