FToy 522 Build Thread - Page 5 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 06-02-2011, 01:53 PM   #101 (permalink)
Davez Off Road
TOYOTAPARTS's Avatar
Member # 61493
That is cool, one of the nicest F toys I have seen.
Great deals on Toyota Parts: : http://www.davezoffroadperformance.com/
Most Trail-Gear parts FREE shipping.Yukon parts on SALE
3rd Members priced right. 530-622-2148
for all your electrical needs http://www.12voltguy.com/
WIN a fully built Toy p/u http://www.pirate4x4.com/forum/toyot...toyota-pu.html
TOYOTAPARTS is online now   Reply With Quote
Old 06-04-2011, 07:13 PM   #102 (permalink)
Member # 124334
Thanks!
I FINALLY got some 'wheeling time in this weekend at a place near me called The Farm. It's some private land ran by the Big Dixie Boggers. www.bigdixieboggers.com Check out the site for some pics of the place. It's pretty extreme for a southern place... The FToy FAR EXCEEDED my expectations. There were alot of major rigs there with major tires (well into the 50" range with rockwells) and I was able to follow them with ease. Hell, some had a hard time going up the rocks and I'd go behind them and crawl it like it was nothing. I did realise I need to do improvements, like making my steering turn sharper and adding a track bar (I did some hopping on some of the obsticles).
Any ways, I got some pics. I'll post more as they get posted by others on my local forum...
Me on the "Get Skinny" trail
Ronnie
FToy 522
bunchr1 is offline   Reply With Quote
Old 06-05-2011, 05:37 AM   #103 (permalink)
Member # 128643
nice!!!
4 wheel parts
offroadman1973 is offline   Reply With Quote
Old 07-06-2011, 03:01 PM   #104 (permalink)
Member # 124334
Ok, after my last 'wheeling trip I realized I really need to get a grip on axle wrap. I hopped so bad on one of the rock faces that it bent a rear wheel. So, I decided on a trac bar.
For the components, I went to my friend Bud at Budbuilt. He hooked me up with one of his short bars, some heims, a couple of beefy shock mounts that I modified, and some hardware. I opened up the shock mounts to 3/4" and ground on them till they fit near the diff. For the front, I just used a short shackle to allow for axle movement so nothing will bind. I still have to tweak on it a bit because the shackle angle sucks, but it seems to work good and it doesn't limit my travel. I does hang down a bit lower than I'd like, but I may change how high the shackle mount is and lift it up a couple of inches.
PICS!!!
Ronnie
FToy 522
Old 10-30-2011, 04:10 PM   #105 (permalink)
Member # 124334
Well I managed to take it out again for another 'wheeling trip to The Farm in Lincolnton. The Big Dixie Boggers had another event that was open to the public, so I took advantage!
PICS!!
Ronnie
FToy 522
Old 10-30-2011, 05:00 PM   #106 (permalink)
a2b
a2b's Avatar
Member # 22547
that trac bar will break in due time. no biggy. just build another one, but this time put more seperation between the links on the rear housing. and use 1.25" joints and .25" wall tubing.
-Hobie
GOTPROPANE.COM
HI-DESERT DRIVELINE IS THE BEST DRIVELINE EVER!
a2b is offline   Reply With Quote
Old 10-30-2011, 05:17 PM   #107 (permalink)
Member # 124334
I just used what Bud had lying around when I made that. Actually, I have to redo the "crossmember" that the rear of the seats and the trac bar used... First time out i broke the square stock at the track bar shackle mount. I just took it off for the rest of the trip... I have to make a much stronger crossmember.
Ronnie
FToy 522
Old 10-30-2011, 06:56 PM   #108 (permalink)
Member # 9771
Mine never broke and I only had one 5/8" heim on the frame end a, bushing on the frame end and two bushings about 6" apart on the housing. I have .120 wall sleeved with .120 wall. The only reason I think he would break a heim would be because he dragged it across some rocks. It's a wait to put heims on the axle end. They're not doing any twisting anyway.
I like to stack rocks on the trail.
chvyhs is offline   Reply With Quote
Old 01-17-2012, 04:53 PM   #109 (permalink)
Member # 124334
Well it's been a while since I've posted anything on my build, and I've changed a few things...
I ditched the EFI on the buggy. It ran great, but there was just too much going on under the dash and around the motor with wiring, so I wanted to simplify everything. I took the plunge and went with a GotPropane kit that I traded for. It's installed and runs great! I definitely have to tune on it a bit, but I can tell i'll be really happy with it. I just need to get another tank.
PICS!!
Removed the EFI
All the things I no longer have to worry about
Cleaned up the motor a bit and painted it since I was this far down
GOTPROPANE
All installed...
Tanks behind the seats (need one more...)
Fits perfectly with plenty of room around the tank (hard to see, but there's room...).
Ronnie
FToy 522
Old 01-25-2012, 02:49 PM   #110 (permalink)
TN-D90's Avatar
Member # 85510
do you feel like the hendrixs frame mounts are beef enough to take a hit? Been looking at building an ftoy and it seems like no one runs rock sliders etc
1989 YJ- Vanilla Ice motor,c4,atlas 5.0, 4linked, 60/14b
www.Dixiecrawlers.com
TN-D90 is offline   Reply With Quote
Old 01-25-2012, 05:38 PM   #111 (permalink)
Member # 124334
That's a 2-part answer...
On one hand, I think they'd do just fine against a rock. They aren't all that long, and with their thickness I believe they could take quite a bit before they'd bend.
On the other hand, I have yet to hit the lower tubes on the chassis on rocks. My last rig I STAYED on my sliders and the underneath of my truck, but now I only occasionally hit my frame. The clearance is much better than 'wheeling a full-body rig...
Ronnie
FToy 522
Old 05-06-2012, 06:44 PM   #112 (permalink)
Member # 124334
I have some more East Coast FToy 'wheeling pics and a VID!
http://youtu.be/3O71O5klQDw
Ronnie
FToy 522
Old 05-07-2012, 12:06 AM   #113 (permalink)
a2b
a2b's Avatar
Member # 22547
tell those spotters to get out of your way!
-Hobie
GOTPROPANE.COM
Old 05-07-2012, 08:15 AM   #114 (permalink)
Member # 124334
Got another vid...
http://youtu.be/IXWPuoasVeU
Ronnie
FToy 522
Old 05-13-2012, 05:24 PM   #115 (permalink)
Member # 124334
4x4Cross took a few pics at the event. Here are a couple they took of me...
Ronnie
FToy 522
Old 06-15-2012, 02:30 PM   #116 (permalink)
Member # 124334
Looking to sell if someone wants it... Check the FToy for sale thread...
Ronnie
FToy 522
Old 08-11-2012, 10:10 AM   #117 (permalink)
mtbrjon's Avatar
Member # 36007
I'll take it!!!
RuffStuffRaceline wheels
FSR fab & radiators
BFG tiresBattlement Fab
FT#48 build2008 East Coast Ftoy champ
"I wanna get me a truck and soop it up with some metal!" -Wingo
mtbrjon is offline   Reply With Quote
Old 08-11-2012, 10:12 AM   #118 (permalink)
Member # 124334
:-) It's yours!
Ronnie
FToy 522
Old 08-26-2012, 07:05 PM   #119 (permalink)
mtbrjon's Avatar
Member # 36007
I picked up 522 from Ronnie this past Friday in Cookeville, TN. This rig was so clean I swear he never wheeled it. I'll start a thread for FT522 v2. Thanks Ronnie for a good deal on a clean rig.
FSR fab & radiators
Old 08-26-2012, 07:29 PM   #120 (permalink)
Member # 124334
Couldn't go to a more fitting owner! I hope it's as good to you as it was to me. I had a blast with it!
Ronnie
FToy 522
