85 4runner>> ftoy103>>?? - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-12-2011, 06:10 PM   #26 (permalink)
Member # 134920
Got a little more done this week. Total wheel base 112". 16" fox with 8" uptravel sitting at ride height. The fuel cell is going to sit rear of the shocksand battery sits between. I really tried to keep the ftoy look but its was not possible with the rear seat. Was also able to save the existing floor panels. This will have to do. Air bumps next week. Hope to have it complete for a test run next weekend.
trader is offline   Reply With Quote
Old 03-18-2011, 06:28 AM   #27 (permalink)
Member # 134920
Mostly done.
Finished the fuel cell and air today. Putting the interior back together today for Hammers run.
Old 03-18-2011, 08:08 AM   #28 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
Looks sick, Rod!
MT4Runner is offline   Reply With Quote
Old 03-18-2011, 08:45 AM   #29 (permalink)
Member # 75648
Looks good!
So the back seat is staying?
sellout
TachedOutOffRoad is offline   Reply With Quote
Old 03-27-2011, 09:10 AM   #30 (permalink)
crawled's Avatar
Member # 168917
What do they say around here `more flex than a boneless hooker on muscle relaxers'
crawled is offline   Reply With Quote
Old 03-28-2011, 01:25 PM   #31 (permalink)
desertoy's Avatar
Member # 292
Where are you going to put the bump stops?
John James
Team Marlin Crawler
X-Chassis #12
6 time KOH finisher
2008/2009 W.E. Rock West Coast Series Champion
2008 Pro Rock Champion
Just "HAMMER" it!!
My Buildup /forum/general-4x4-discussion/298203-desertoy-mustard-dog-build-pair-x-chassis.html
desertoy is offline   Reply With Quote
Old 03-30-2011, 05:23 AM   #32 (permalink)
Member # 134920
First trip out with links on all corners. Our plan was to run down outer limits and up spooners but another rig broke, so finished up at backdoor.
Next step is going to install bumps and play with the spring rates. By the way it flys in the woops.
Old 06-12-2011, 10:35 AM   #33 (permalink)
Member # 134920
After about 4 trips to the Hammers I noticed that the drivers front corner is twisted out 1/4". That made the pitman arm move out 1" also the panhard bar twisted the frame out which shifted the front diff to the driver side 2". I could only steer passenger side to 1 oclock.... so lots of plating and bracing had to take place before putting back together.
Old 06-13-2011, 03:51 PM   #34 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
Looks great, Rod!
Nice work on making it up BD!
Old 06-13-2011, 06:55 PM   #35 (permalink)
Member # 128643
wow awesome work!!!!
4 wheel parts
offroadman1973 is offline   Reply With Quote
Old 06-14-2011, 06:20 PM   #36 (permalink)
Member # 134920
I have this crazy idea. I can pick up a 3rz complete with harness and TRD supercharger total cost will be 2200.00. Will changing the bellhousing and everything else be worth the effort?
Old 06-17-2011, 07:47 AM   #37 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
Crazy good idea.
You won't be changing the weight of your engine noticeably, so your suspenson can stay dialed.
You'll get an engine that REALLY snorts.
Keep shopping, unless the TRD's are really rare, I'd guess you could get into one for less than $2k--more like $1,500??
Old 06-17-2011, 08:10 AM   #38 (permalink)
bluzuk80's Avatar
Member # 122462
Awesome rig. youll love the power of thr 3rz with or without the blower compared to the 22r
*UNDER CONSTRUCTION* Wide Open Design Revolution Built L33 alum 5.3/400/Atlas/HP60/14/ORIs/Reds/Trailreadys
2500 CTD 4x4 6spd tow rig
www.hawkpridemountainoffroad.com
www.wideopendesign.com
bluzuk80 is offline   Reply With Quote
Old 02-17-2012, 10:14 AM   #39 (permalink)
Member # 134920
Its been a while but I have been working on it between runs. Here are pics of the new TG front housing its the tacome width no spacers. Need to increase front ride height by 2" for better up travel. Also, need to figure out the full droop. Is there a guy in the LA area that does shock tuning. I would like to go to tech day and see if this can be dialed in a little better
Finally installed front air bumps
Rear Bumps
Oh and this good thing I have window nets. My son was in the passenger rear and wanted to do it again. The wider front housing allowed me turn hard passenger and drive out
Old 02-17-2012, 06:05 PM   #40 (permalink)
Member # 9771
I like where you put the front bump stop pads.
I like to stack rocks on the trail.
chvyhs is offline   Reply With Quote
Old 02-19-2012, 08:00 AM   #41 (permalink)
Member # 107137
Really nice rig! For shock tuning, I would just get online and source the parts and tools to do it yourself. Not terribly difficult especially seeing all the other work you've done.
OldGold3VZE is offline   Reply With Quote
Old 07-09-2012, 06:20 PM   #42 (permalink)
Member # 134920
Well here we go again. After 4 years i guess its time for more power. I have been reading about this kick ass ford 2.3l turbo motor. Should produce about 255 HP in a 4 cylinder. I plan on installing a C4 automatic trans with Advanced Adapter to Toyota tcases 23 sp.
Out with the old
Ford 2.3L Turbo
Also no more broken Mini truck Axels New TG 9"housing and 35 sline shafts
Old 07-10-2012, 08:56 AM   #43 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
Got a home for your old 22re?
Old 07-10-2012, 03:04 PM   #44 (permalink)
Member # 134920
Sorry Shawn its already gone.
I found the bellhousing and flex plate today should have trans done next week.
Old 07-12-2012, 12:32 PM   #45 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
Bummer. Oh welll!
Did you use an adapter or was there a different bellhousing application that would mate the two together?
Old 07-14-2012, 07:50 PM   #46 (permalink)
Member # 134920
Spent the last week mostly looking for parts. Well to my surprise, the bellhousing that connects the 2.3 to the c4 is harder to find than I thought. I contacted Culhan Transmission in Lake Elsinore and they said of course thay had it. Should take another 2 weeks to pick up. IWill be cutting the frame off at the holes for the shackles and run tube around the front. Small stinger for winch and lights. Also going to 4 link the front to get rid of the pan hard bar.
I also picked these up
Old 07-15-2012, 11:57 AM   #47 (permalink)
Member # 143278
Lookin bitchin rod
Socal Independent 4x4 - OCT Offroad
Tow rig 97 f350 7.3 Crawler 85 xtra cab yota
83crawlyota is offline   Reply With Quote
Old 07-15-2012, 10:05 PM   #48 (permalink)
Member # 94186
nice build let me know how you like the tg 9 housing
1988 4.3cpi v6 sased 37mtrs and one proud owner
bigarms23 is offline   Reply With Quote
Old 07-18-2012, 10:25 AM   #49 (permalink)
the freeak's Avatar
Member # 41185
Nice looking build.
Subscribed for Turbo content.
the freeak is offline   Reply With Quote
Old 08-27-2012, 10:37 AM   #50 (permalink)
IDIot!
MT4Runner's Avatar
Member # 44480
Updates? 5 months to go.
