#28 (permalink) |
Member # 187257
So what do you guys think about mounting batteries like this. I'm trying to find a location that is easily accessible but out of the way as much as possible. I like it but don't know if there are any major reasons I shouldn't do it. They are going to be optima yellows btw.
#31 (permalink) |
noob
Member # 66544
The optimas can be mounted in any orientation so that will work. The only thing you might consider is getting the weight down lower. I moved a bunch of weight down and toward the center in version 1.2 of my rig and it made a remarkable difference. It was noticably more stable and I could drive it off it's side because the weight was down so low. Progress looks good
El Destructo! I void warranty's!!! Team Rock Limo F-Toy #F002 Yukon gear/Randy's Ring & Pinion, Trail Gear, BFGoodrich Tires, RuffStuff, 12 Volt Guy |
#32 (permalink) |
Member # 187257
Here's how I have my floor setup. I used ruff stuff's seat belt tabs to mount my seats and seat belts in double shear.
![]() Had to drill the tabs on the seats to make them fit, and I used some 1/2" bolts with cotter pins holding them in place so the whole thing can come out really easy.
#33 (permalink) | |
IDIot!
Member # 44480
Looking good--keep it up!
Motive Gear Land Use Team http://www.tenfactory.com http://www.motivegear.com http://www.nationaldrivetrain.com http://www.davezoffroadperformance.com http://www.mastercraftsafety.com FToy 086 - UHaul Toterhome |
#36 (permalink) |
Member # 187257
They are KC slimlight series driving lights. It's a tight fit on the driver side because of the whinch lever for free spooling, but it fits perfect. I think Hella also sells some sort of slim light.
