Axle strength - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 12-10-2002, 08:00 PM   #1 (permalink)
freds40's Avatar
Member # 14437
Axle strength
I am new to cruisers and I am trying to figure out how strong my stock axles are so I know if it's worth putting the money into them. I have a '70 FJ-40 and I plan on running Longfield's with an ARB. My small block puts out just over 400 ft/lbs @2000 and I am running an sm-465 with the 3 speed case. Eventually I'll add a case or crawl box for lower gears. With say 2" wheel spacers or offset wheels, how big of a tire can I run before it starts to stress the king pins and bearings. I'd eventually like to run 38.5 SX's but not if I'm replacing bearings and races every month. Flame on if you'd like, but I searched and didn't see anything directly related to my question.
Marlin Crawler Sales
www.marlincrawler.com
559-252-7295
brendan@marlincrawler.com
freds40 is offline   Reply With Quote
Old 12-10-2002, 08:23 PM   #2 (permalink)
Member # 1357
I am no expert on the subject ,but from what I have been hearing, as long as you keep your foot light on the go pedal, you should have no problems running 35s. I know there are some running 38s and are doing fine also. I think it depends more on your driving style than anything.
77 FJ40, 5.7L vortec, soa, shaved 14 bolt rear, stock front housing loaded with some good stuff, and a lot of f***ing dents and rust.
rustyb is offline   Reply With Quote
Old 12-10-2002, 08:47 PM   #3 (permalink)
Member # 6588
yeah, i think that 38.5s wont be that much of a drama,
i could break birfs on 33s with a 4cylinder, but have only broken one front axle with the longs in, and it was with 38" boggers aired right down, and wedged tight in a hole!
and my brass button clutch didnt help!!
also, im now running 42s and despite having ran it only twice they've held up, but i want to step up, cause i know its gunna go
the thing is, depends on your style, some people have never broken a birf, and some people are breaking D60s and mog axles!
its a relative thing, by the sounds of your gearing, you wont be stressing too much with stock axles...jason mace on the board here has run 38s since ive been posting on here and hasnt reported many issues
ive had pinions, arbs, axles, and tailshafts, fail on me, among other things.......but i like to give it some!!
my opinion go easy, on 38s, your cruiser axles with longfields will be super reliable
[COLOR=yellow]Bj on Roids 1970FJ45, Quad Cam V8, Auto, Broken T-case, H-TEC (traction control and cutting brakes) 42 TSLs.[/COLOR]
[COLOR=green][URL=http://www.outerlimits4x4.com]Aussie Wheelers Bulletin Board[/URL] [/COLOR]
BJ On Roids is offline   Reply With Quote
Old 12-10-2002, 09:21 PM   #4 (permalink)
freds40's Avatar
Member # 14437
Are there any upgrades I can doto my axle other than what I've listed. I have read that my shafts are already the fine spline but are there any other areas to look at?
559-252-7295
Old 12-11-2002, 05:35 AM   #5 (permalink)
Member # 260
Send a message via Yahoo to woody
knuckle bearing/steering arm torque is critical. Check that prior to every ride and the Toyota axle with Longfields will hold up excellent. I've had no problems in 2 years other than axle breakage...and my new Longfields will help with that a ton.
Brian 'woody' Swearingen - IH8MUD Inc.
'74 FJ40, '95 HZJ75, '96 FZJ80, '03 2500 DMax, '09 RZR
woody is offline   Reply With Quote
Old 12-11-2002, 09:09 AM   #6 (permalink)
cruiseroutfit's Avatar
Member # 1858
With a 70' FJ40 you will need to upgrade to a disc brake front end...then you can run the Longs... Your axle will actually be course spline at the hub but fine spline at the differential IMHO...
Find a complete hub-hub front end off of a 76+ cruiser and go from there. Be advised that 79+ FJ40 axles will have a higher gear ratio (3.73) in them and it won't be compatible to your stock 4.10's
Welcome to the cruiser world!
Kurt Williams
Cruiser Outfitters - YOUR CRUISER PARTS SOURCE! - ARB - OME - Engel - Helton - AdvAdapt
ExpeditionUtah.com
U4WDA - Member
TLCA #10662
Wasatch Cruisers #028
Mountain Yoats
Red Rock 4 Wheelers #789
Mojave Underground
kurt@cruiseroutfitters.com
cruiseroutfit is offline   Reply With Quote
Old 12-11-2002, 10:28 AM   #7 (permalink)
LC Hamma's Avatar
Member # 137
This is advice I would NOT give someone who's looking to upgrade since I've done it twice. Now I have small LC knuckle syndrome. I would go for the mini truck conversion! You get bigger birfields & knuckle arms, which have a wider pattern & larger knuckle arm stud size, IIRC. Plus they're plentiful in the yards compared to finding an LC disk frontend, which are scarce. Go to Woody's favorite site (where newbies check in) to see this conversion. I have not done the mini conversion due to the info wasn't availble at the time I did my swap. Good luck!
'72 FJ55
http://forum.ih8mud.com/showthread.php?t=76835
'73 FJ40
http://s132.photobucket.com/albums/q...&addtype=local
'78 FJ40
'91 Ram W250 5 spd. CTD
'93 Ram W350 5 spd. CTD
'99 Ram 3500 4X4 5 spd. CTD
Welding is like sex, it's all about the penetration!
LC Hamma is offline   Reply With Quote
Old 12-11-2002, 10:42 AM   #8 (permalink)
Member # 260
I would revise that to say 79+ Cruiser or minitruck. 76-78 used the smaller knuckles, smaller diameter/longer shaft fine spline birfs, and are "next" to impossible to use with SOA if you want hi-steer.
I'm changing mine soon...got the AllPro arms bookmarked already...heh
Old 12-11-2002, 12:33 PM   #9 (permalink)
freds40's Avatar
Member # 14437
Yeah I actually picked up a complete mini axle last weekend to do the disc swap and to be able to use the Longs. This is my daily so I have to keep it safe on the street too. I plan to switch to later cruiser rotors, etc. to get the vented a little down the road. I plan on using the Rock Buggy Supply cross over setup. Waiting for the weekend the wife is out of town in March to do the spring over and discs.
559-252-7295
Old 12-11-2002, 12:41 PM   #10 (permalink)
Member # 260
smart man...
"absence makes the Cruiser grow stronger"
lol
Old 12-11-2002, 05:01 PM   #11 (permalink)
Member # 4719
Ill be the oddball and say that if you want to stay sorta cheap and cruiser go FJ-62. The front axles have extra gusseting that the 40's didnt have, not sure if the truck axles did. 9 1/2" instead of 8" diffs, and newer 88'-90' than any truck front axles. Plus hy-steer is easier, disc brakes, and the added width. If you want to stay cruiser/toyota about the strongest you could go would be FJ-80 axles. These are rare and prized though, being as they have reverse rotation 8" fronts with big knuckles, the strongest birfs, discs, and 9 1/2" rears most prized with FF and both front and rear selectable electric lockers. These are what I want *cough* venezuela *cough*.
Mitch
Broke? Stuck? Had to swap it all out to play rough? Ya, must be that Jeep Thing!
Spyder is offline   Reply With Quote
Old 12-12-2002, 11:19 AM   #12 (permalink)
Member # 8975
Spyder the 40 dose not have a 8" diff your thinking of the mini's and the people here are not talking about swaping with mini's whole axle their talking about just swaping the brakes and far as I thought all the Toy Birfields from 79 and up were the same. I also believe the that the 40's 55's and 60's share the same third.
But I could be wrong I've never actually swaped one into another.
72 TLC w/ Pontiac 455, SM420, Orion T-case, OBA, ARB's, SOA, PS, P disc B's, 36x14.5 TSL's, Painless wiring, GM column, Autometer gauges, Power and heated bucket seats, CD Stereo 4 speakerw/ sub woofer, Union Pacific Train Horn
pontiota is offline   Reply With Quote
Old 12-12-2002, 02:01 PM   #13 (permalink)
Member # 6588
Originally posted by woody
smart man...
lol
so does boredom, then a lot of late nights go into any cruiser, late nights, take away food, and beer
Old 12-12-2002, 09:57 PM   #14 (permalink)
Member # 1858
I would revise that to say 79+ Cruiser or minitruck. 76-78 used the smaller knuckles, smaller diameter/longer shaft fine spline birfs, and are "next" to impossible to use with SOA if you want hi-steer...
Yeah, I should have said 79+ front axle complete but where as your swapping the mini-stuff you should be in good shape. You will gain far more options and parts availability if you run the later design...come to think of it that is exactly why I went with FJ60 axles...
Kurt Williams
ExpeditionUtah.com
U4WDA - Member
TLCA #10662
Mountain Yoats
Mojave Underground
Old 12-12-2002, 10:14 PM   #15 (permalink)
Member # 3942
Spyder, you don't want Venezuela-spec 80 Series axles, seeing as those don't have rear disk brakes, don't come with locker option, and prior to 2002, were semi-floater only. I guess a front 80 series axle from Venezuela wouldn't be that bad, you do get Aisin hubs on it, but I'd still shoot for a US-spec 80 Series axles with the fatty e-lockers already on, FF rear with disk brakes.
60seriesguy is offline   Reply With Quote
