Member # 57425
sm465/dana 300 combo
Im going to be swapping a 32 spline sm465 thats bolted to a dana 300 and stainless twin stick setup. This is going to be replacing my h41 and stock 4 speed combo. Does anybody else on here run this setup? What crossmember design are you guys using?
78 fj40 with some junk and mud tires 00 runner with less junk and mall terrain tires |
Member # 19510
I run a 465 to a 4:1 300 great combo. I modified an advance adapters wrangler tcase mount to my crossmember. On my phone right now so no pic access
77fj40, 1 TON www.wfoconcepts.com 530-268-9494 tlca# 12281 semi_budget 1ton build /forum/toyota-land-cruiser/530636-semi-budget-1-ton-buildup-thread.html linking the rear http://www.pirate4x4.com/forum/toyot...king-rear.html |
Member # 57425
im back and forth now on what to do for a rear end
I have a mini truck rear with no diff and no brakes. I imagine i could do a centered cruiser rear with it.
Member # 57425
it has 1310 ujoints yolks on it now. What have you guys done to mate that to the cruiser driveshafts?
Member # 24859
upgrade that 1310 yoke and use a 60 or 14 bolt rear axle. If you are set on using cruiser d-lines and axle then you could get a flange from Randy's that will go on the 300 and bolt to cruiser d-line. The rear axle is up to you, use a mini/taco or center a cruiser diff, whatever works for you. Personally I would not use a cruiser diff if I had a centered rear axle but that is just because there are so many options when you are talking centered diff. I think rockthedog had his 300 before going to tons, he may have a centered rear axle left over, or contact Trevor at WFO , check out the used axle section on his site.
Mellonhead |
Member # 21749
Here is his build. Good reading for you. He actually went with a 14 bolt at the time he installed the Dana 300.
Funny. I ended up with his old cruiser housing and now I am just about to order my adapter to put a dana 300/ dana 60 rear in my 40. I guess,Glenn, in few more years, I will be running 42's! ![]() http://www.pirate4x4.com/forum/showthread.php?t=530636
73 FJ40 -Under the knife --http://www.pirate4x4.com/forum/showthread.php?t=607442 65 FJ45 -Patiently waiting |
Member # 57425
i swear ive seen someone run a 60 rear with 8 lug adapters on the front now i cannot find it
78 fj40 with some junk and mud tires 00 runner with less junk and mall terrain tires Last edited by jimbo92; 11-09-2011 at 04:04 PM. |
#12 (permalink) | |
Member # 19510
i guarentee you will have 42's someday!by the way umless you have huge horspower 1310 cv is plenty strong. the rear output shaft is where i would upgrade, however i did run the stock one with 38.5's for years. the new 300 i just put in w/4:1 has the hd output in it but i stayed with the 1310 cv.... also lots has changed since the oneton build rear links and the tcase crossmember.... i have a pic of it somewhere....the one in the build was too soft and allowed the tranny and tcase to roll-tourque too much
77fj40, 1 TON www.wfoconcepts.com 530-268-9494 tlca# 12281 semi_budget 1ton build http://www.pirate4x4.com/forum/showthread.php?t=530636 linking the rear http://www.pirate4x4.com/forum/toyot...king-rear.html Last edited by rockthedog; 11-10-2011 at 01:44 PM. |
#13 (permalink) |
Member # 57425
Nice glad to hear a 1310 will hold up. I guess the best way to mate my driveshaft is to just put 1310 yokes in it when i lengthen/shorten it. Everything should hold up pretty well as I am only running 35 inch km2's. The biggest tire I plan for is a 37 after an upgrade to longs.
#15 (permalink) |
Member # 57425
bringing back an old thread, so my procrastinating ass finally went and picked up my trans case. It ended up using the stock 32 spline 205 adapter thats 10.5 inches long making the setup waaaay long for an fj40. Im trying to decide what to do now. Do i sell that adapter, 32 spline 300, and sm465 and get a 10 spline unit and run an adapter and my cruiser case or hold off and get an ORD or novak unit to run what i have just shorten it up. The cost of adapters either way is about the same,but with the cruiser case i can sell the other crap to offset cost and wont have to build a centered diff. With the 300 I get lower gears, twin stick, and a stronger case. Decisions Decisions
