Project Homewrecker - Page 2 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-09-2012, 07:51 PM   #26 (permalink)
Member # 63299
not yet. were to the tedious part of wrapping up the little stuff. I am down to tweaking a few things but it is running and drive-able. i will update pics this weekend, it is flooding outside and my fab guy is out of town so I wont get a lot done this weekend. We are heading to Hot Springs on the 23rd of this month so I have a deadline to meet now. Maybe this will help spur me along to get it done.
74 FJ40- one tons, 42's
Spacecwboy is offline   Reply With Quote
Old 03-11-2012, 08:09 PM   #27 (permalink)
Member # 63299
having some problems, moved the pictures in my photobucket account and messed up the links. will fix this afternoon
Old 03-11-2012, 11:10 PM   #28 (permalink)
ROCK HUGGER's Avatar
Member # 4329
Pics not working for me.
ROCK HUGGER is offline   Reply With Quote
Old 03-12-2012, 08:57 PM   #29 (permalink)
Member # 63299
Old 05-31-2012, 08:44 PM   #30 (permalink)
Member # 63299
a few updates (will also round up pics)..
trailered it up to Hot Springs to the Superlift part for the shakedown run. Ran fine on the carb until I hit the first trail. spent half the day trying to get it to crank back up every time it would die out from flooding. Put it back on the trailer and rode with a buddy the rest of the weekend. Trail Gods-1, Spacecwboy-0
got home swapped carb out in favor of propane. spent way too much time and money getting it running. loaded it up on the trailer again and took off to the Toyota Jamboree in Gilmer TX. Did awesome on the access roads and short trails when it was getting really good airflow. not so good on the slow trails. spent most of my weekend doing the Tennessee style of rock bouncing out of fear of overheating. Rock Gods- 2, Spacecwboy- 0
got home (pissed again) and pulled out all of the propane and jumped head first into a TBI swap and complete re-wire via a Painless wiring harness and a friend who rewired all the lights on the FJ. knock on wood, as of the moment it is running pretty well. I worked on the timing and idle today. I am not having much luck with the PS pump putting out enough pressure to allow me to steer at idle. while it doesnt seem like a huge deal at first, that means I cant turn at a stop sign or go around a corner unless I get into the gas and get the RPM's upwards of 1400 rpm. I am using a stock pump which i know is part of the problem. I have a PSC pump to upgrade to, just not a reservoir or all the hoses at the moment. it is too damn hot to go ride now, so come October I will hopefully be able to get it on the trails. until then it is my new weekend cruiser once i get it inspected.
Old 05-31-2012, 08:52 PM   #31 (permalink)
Member # 63299
Old 06-01-2012, 02:15 AM   #32 (permalink)
Wait this ain't Tx..
TxCruzr's Avatar
Member # 9380
Send a message via AIM to TxCruzr
You know, everything looks great except those little longhorn cut outs in your wheels
How do you like the ORI's?
"There is no hunting like the hunting of man, and those who have hunted armed men long enough and liked it, never care for anything else thereafter."
-Ernest Hemingway
'69 FJ-40 - under construction
TxCruzr is offline   Reply With Quote
Old 06-01-2012, 02:31 AM   #33 (permalink)
BackNBlackTJ's Avatar
Member # 18157
\m/ \m/
yeah... loving the wheels
AZ UNDERTAKERS
BackNBlackTJ is offline   Reply With Quote
Old 06-01-2012, 04:49 AM   #34 (permalink)
Member # 63299
The ORI's are awesome. zero complaints! I was going to run the sway aways because they were cheaper but after you factor in 4 limit straps, the coilovers, springs, 2 sway bars and all the other things that were involved in setting them up properly, it was actually cheaper to buy the ORI's and be done with it. at speed they ride awesome. there are some open areas at one of the parks where we ride where you can get up some speed, unfortunately there are 6-8" rocks and small washouts all over it, we took off across it at 30-40mph and they absorbed every bit of it. the guys that we ride with all want to switch now. You will be hard pressed to find a better setup unless you have something custom set up for you.
