Shock guru's Fj80 shock??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-28-2012, 09:32 AM   #1 (permalink)
wayfastwhitey
slobuild57's Avatar
Member # 94400
Had a question for the shock guru's. What shock valving do I need to need to get for a lifted fj80? Looking on summit for shocks and am ready to pull the trigger but don't want to get something too soft or too stiff.
Specs on the rig is an fj80 with 5" ome springs and metaltech 2" spacer. Has a cummins, 1tons and 37"s. I have 26" between the mounts and was looking at 14" travel shocks but not sure on what valving I need to look for. Any help is appreciated!
92 Fj80 6bt, 1tons wife mobile
70 Fj40 1ton v8 stak 42's
03 CTD toe rig
Originally Posted by Blase View Post
what's it like to own a buggy........i'd say it's like getting a blow job on a roller coaster
slobuild57 is offline   Reply With Quote
Old 01-28-2012, 12:14 PM   #2 (permalink)
Member # 163633
you would be better off calling 4wheel parts.
socal nick is offline   Reply With Quote
Old 01-28-2012, 01:17 PM   #3 (permalink)
wayfastwhitey
slobuild57's Avatar
Member # 94400
Don't really care where the shocks come from as long as they are right.
03 CTD toe rig
Old 01-28-2012, 01:46 PM   #4 (permalink)
Brutpwr's Avatar
Member # 481
I don't think you will be happy with any off the shelf shocks. With your mods I'm thinking your vehicle probably leans a lot in turns--this means you need more low speed dampening than most off the shelf shocks provide. Since you have a lot of wheel travel you want the suspension to free up when you hit speed bumps and larger at higher speeds. These needs are best met with a custom valved shock set up for your vehicle.
Jason
Brutpwr is offline   Reply With Quote
Old 01-28-2012, 02:17 PM   #5 (permalink)
LT
LT's Avatar
Member # 11458
We could get you set up with some Radflo 2.0 shocks custom valved and with your specified shock lengths. They are also a direct bolt in and will be better money spent in the long run for ride quality. They will cost around $228 each but you won't regret the investment.
Radflo FJ80 Shocks
Propane Powered 2f
Metal Tech Production Manager
[url=www.metaltechcage.com]Metal Tech Cage[/url]
LT is online now   Reply With Quote
Old 01-28-2012, 02:28 PM   #6 (permalink)
wayfastwhitey
slobuild57's Avatar
Member # 94400
Radflo FJ80 Shocks
Do you offer them for a 5" lift? Link shows 2 and 3. Also can you get them with an eye on the bottom instead of the stud? I figured I was going to have to spend some coin and am cool with that as long as I get what I pay for.
03 CTD toe rig
Old 01-30-2012, 06:14 PM   #7 (permalink)
LT
LT's Avatar
Member # 11458
We can have a set custom built to your specs. As long as you can provide me your extended and collapsed lengths I can figure our what your best option is.
Propane Powered 2f
Old 01-31-2012, 11:59 AM   #8 (permalink)
wayfastwhitey
slobuild57's Avatar
Member # 94400
Thanks a bunch! Let me save up my lunch money for a few weeks and I'll call you.
03 CTD toe rig
