FJ60 SOA vs. SUA with OME - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-03-2003, 08:15 AM   #1 (permalink)
Member # 8805
Send a message via Yahoo to ryankalel
I am looking at doing some kind of suspension mod. I would really like to do the SOA, but have heard that it will drive like a shopping cart after I am done, and that the steering sucks too.
The OME I have heard great things, but I wanted to get a little more lift than they offer. Any suggestions would be great.
thanks
-ryankalel
ryankalel is offline   Reply With Quote
Old 01-03-2003, 08:47 AM   #2 (permalink)
Deep South Cruisers's Avatar
Member # 3514
The OME lift is a actually a little taller than advertised but don't expect anything taller than a 33" tire to fit with SUA. There are several SOA FJ60's here and when done correctly I don't think you'de get the shopping cart feeling
Deep South Cruisers is offline   Reply With Quote
Old 01-03-2003, 09:09 AM   #3 (permalink)
pismojim's Avatar
Member # 11429
Compromise - SOA and OMEs
Rides great on and off road.
[color=skyblue]Jim Brantley, KI6TLC, TLCA #6433
FJ40, FJ60, FZJ80
[size=3][b][url=http://realcruiser.com]realcruiser.com[/url][/b][/size]
Pismo Beach, CA[/color]
pismojim is offline   Reply With Quote
Old 01-03-2003, 09:21 AM   #4 (permalink)
cruiseroutfit's Avatar
Member # 1858
I agree
Unless the SOA is done by a monkey, you can retain a great ride and excellent steering. My SOA FJ40 rides like a cadilac on and off-road... Even better, while doing a SOA do a SR as well for even better ride and handling...plus go with hi-steer and your set...Good Luck
Kurt Williams
Cruiser Outfitters - YOUR CRUISER PARTS SOURCE! - ARB - OME - Engel - Helton - AdvAdapt
ExpeditionUtah.com
U4WDA - Member
TLCA #10662
Wasatch Cruisers #028
Mountain Yoats
Red Rock 4 Wheelers #789
Mojave Underground
kurt@cruiseroutfitters.com
cruiseroutfit is offline   Reply With Quote
Old 01-03-2003, 09:38 AM   #5 (permalink)
Member # 12758
EIther way, you'll spend $1600 for a OME kit not installed, or you can spend around $1800 (on the expensive side usually) to have someone do the SOA, and do it right. I would beef up your springs a little to make them a little stiffer as SOA on a 60 will quickly kill a set of healthy stock springs that were SUA. Use quick disconnects and retain your front sway bar at the minimum, and use a sway bar from the rear of a FJ62 if you can get ahold of one. Then some of the new Rancho RSX 9000s and you'll have a system that will probably drive just as well as an OME system.
dieselcruiserhead is offline   Reply With Quote
Old 01-03-2003, 10:04 AM   #6 (permalink)
Member # 8805
Would beefing them up mean some add a leaves? How big of a tire could I put under it, post SOA?
Kurt, how do I become a member of wasatchcruisers?
thanks
-ryankalel
Old 01-03-2003, 10:34 AM   #7 (permalink)
Member # 1858
thanks
Send me an email...
cruiseroutfitters@hotmail.com
I can show you a couple of different SO FJ60's as well as my SO FJ40 with FJ60 axles... Down in springville eh? We have a couple of members down that direction. Keep in touch
Kurt Williams
ExpeditionUtah.com
U4WDA - Member
TLCA #10662
Mountain Yoats
Mojave Underground
Old 01-03-2003, 11:13 AM   #8 (permalink)
Member # 12758
You can get 35s in there no problem with the stock springs. One long, somewhat soft add-a-leaf is what I imagine but there are all sorts of variations out there. There is actually a pretty good spring shop down there where I did exactly this to my front leaves. I felt like they were kind of trying to rip me off but in the end the product was very good, I think it was AAA spring shop?
Old 01-03-2003, 12:23 PM   #9 (permalink)
Member # 1858
AAA is in SLC, Best Deal Spring is down there in Springville/SF area. They are both very good at what they do
Kurt Williams
ExpeditionUtah.com
U4WDA - Member
TLCA #10662
Mountain Yoats
Mojave Underground
Old 01-04-2003, 08:47 PM   #10 (permalink)
Member # 6801
Send a message via ICQ to DanKunz Send a message via AIM to DanKunz
Alcan can make flat spring packs for SOA that won't sag
I only know since I asked them!
Dan Kunz
1996 FZJ-80 "Avocado"
Toxic waste barrel liner makes good paint.
Lifted and locked and stuff
[URL="http://www.sfwda.org/trails/tellico/donate.html"]SAVE TELLICO![/URL]
DanKunz is offline   Reply With Quote
Old 01-05-2003, 02:16 AM   #11 (permalink)
Member # 1858
Well you don't think they will just come right out and tell you they sag...
No Really, Alcans are really sweet springs...
Kurt Williams
ExpeditionUtah.com
U4WDA - Member
TLCA #10662
Mountain Yoats
Mojave Underground
