brake upgrade - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-24-2012, 05:28 PM   #1 (permalink)
Member # 195269
brake upgrade
alright time to upgrade the brakes have dana 44 front with discs and gm 14 bolt rear with drums. stock master cylinder not cutting it. 36 inch tires. whats a good new master cylinder thats easy to fit and plum. need more fluid bad.
thanks
teguman333 is offline   Reply With Quote
Old 05-24-2012, 05:37 PM   #2 (permalink)
Member # 195269
a guy gave me a rock stomper master but having a hard time finding the fittings to adapt it to old toyota. any other masters that i can put in easier?
Old 05-24-2012, 06:04 PM   #3 (permalink)
Moderator
RustyNailJustin's Avatar
Member # 8568
I had that setup in an old FJ60 I had. I went to a hydraulics shop and they were able to piece together the fittings. Or if you get on earls fittings it should be pretty easy to find an adapter.
2012 KOH Team CrossedUp, ADS, Artec, Mike Klensin and Justin Reece. 9TH Place.
2011 LCQ to KOH Team CrossedUp Mike Klensin and Justin Reece. We finished 40th
2010 KOH Team CrossedUp Mike Klensin and Justin Reece.
2009 KOH Team 435 Finished 35th.First Full Frame/Full Body To Finish KOH.
TLCA# 5305
RustyNailJustin is online now   Reply With Quote
Old 05-24-2012, 07:46 PM   #4 (permalink)
Member # 189370
Try a T100 unit. They have a 1 1/16" bore. I've got a 60 front/fj80 ff rear, works awesome!
Rock40 is offline   Reply With Quote
Old 05-26-2012, 06:55 PM   #5 (permalink)
Member # 195269
got ya ill see what i can get.
Old 05-26-2012, 06:57 PM   #6 (permalink)
Member # 195269
will the t100 bolt to the fj booster? i guess that resivior is bigger then stock fj40 cups right?
Old 05-26-2012, 07:37 PM   #7 (permalink)
Member # 189370
It will bolt right up to a mini truck booster, I used a small diameter unit from an 85' 4WD truck. I'm not sure about the FJ booster. Would you like the dimentions? The fluid cups are different too, try to get a used one from a junkyard that still has the cups on it. I wrote quite a bit on it, check on the Rock40 Build. Let me know if I can help
Old 05-28-2012, 05:23 AM   #8 (permalink)
Member # 195269
ill see what i can find i may use the rock stomper and try to find fittings but if to much a pain ill go with the mini
Old 05-28-2012, 08:04 AM   #9 (permalink)
Toploader's Avatar
Member # 16737
Cant you just cut and re-flare the hardline at the master with a standard fitting? Or are you trying to avoid that?
72 Rockwelled yeah whatever...
All my shits heavy.
Toploader is offline   Reply With Quote
