sssooooo close...yet so far. - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-08-2003, 08:16 AM   #1 (permalink)
GloNDark's Avatar
Member # 2482
Well I made the first attempt to back the cruiser out of the garage last night.
Exhaust is done (thanks again tex for the crossover idea, worked beautifully) I used chevy ram horns to a walker cross pipe to 3" exhaust tubing to the flowmaster at the rear.
Steering is done with one minor exception. It has a 5/8 heim joint on the pitman arm and I am going to ream out my other pitman arm to accept a chevy TRE.
Front end is done, gears, locker, new axle shafts, u-joints, bears, hubs and brakes.
Rear axle is done with the exception of the gears. Those will be done this weekend.
Motor is done, tranny/t-case and cross member are done.
Front suspension, outboarding springs is done. I have to box the bumper and some minor things.
Rear suspension is done. Mounting shocks, limit straps (yeah I said limit straps) and mounting my track bar will be done between now and this weekend.
I was stoked, ready to pull her out and see what she looks like outside.........but nooooooooooo the clutch slave had to take a shit on me. 6 months worth of time, way to much money to even add up, nearly causing a divorce (ok not that bad, but she still hates the garage time ) and a freaking $30 parts stops it from moving. DAMMIT!!!
GET IT Dave!!
save me a spot bro......i'll miss you...
GloNDark is offline   Reply With Quote
Old 01-08-2003, 08:25 AM   #2 (permalink)
texican's Avatar
Member # 12349
That is a sweet exhaust set up isn't it
You're very welcome.
Butch
Conflict is inevitable.....
Combat is optional....
Tires are like boobs, they always look big until you have played with them for a while, then you just want a bigger set.
[URL=http://www.lslc.org/]Lone Star Land Cruisers[/URL]
[URL=http://www.khyi.com/]Support Texas Music[/URL]
texican is offline   Reply With Quote
Old 01-08-2003, 08:32 AM   #3 (permalink)
GloNDark's Avatar
Member # 2482
Butch
Sweet doesn't even begin to describe it. Way freaking easy too. I got less than $100 into my exhaust and maybe about an hour or so in time. WAAAAAAAAAAAAAY SWEET!
GET IT Dave!!
Old 01-08-2003, 08:40 AM   #4 (permalink)
GloNDark's Avatar
Member # 2482
Oh and has a side note, I ended up using a Wilwood Master Cylinder from Summit. 7/8 bore with 1 and 7/16th throw. Seems to hold pressure great, Can't wait to test it out tonight. It was a VERY easy swap from the 69 Master that was in there before.
GET IT Dave!!
Old 01-08-2003, 08:53 AM   #5 (permalink)
Eskimo's Avatar
Member # 10429
ummm.. PICS! I'd like to see that exhaust setup you've got...
That brake M/C seems kinda small.. I'm running a 1" bore MC with vented cruiser 4-pistons up front, and Monte calipers in the rear, and can almost bottom out the travel on the MC when I'm standing on the brakes...
Although, that throw seems pretty long... maybe that makes up for it?
Rich Q.
FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/ORI's/42's
Eskimo is online now   Reply With Quote
Old 01-08-2003, 09:01 AM   #6 (permalink)
Member # 260
Send a message via Yahoo to woody
been there, had that exact problem....spent a few weeks this summer working on the rig, pull it out of the drive, and the slave craps....pull out my spare and find out that the later small-bore slave and earlier large-bore slave do not run the same hose-size fitting....:o
Fortunately, I found a rebuild kit in my tool box, so I honed out the slave with 800grit and tossed that in....
Brian 'woody' Swearingen - IH8MUD Inc.
'74 FJ40, '95 HZJ75, '96 FZJ80, '03 2500 DMax, '09 RZR
woody is offline   Reply With Quote
Old 01-08-2003, 09:12 AM   #7 (permalink)
GloNDark's Avatar
Member # 2482
I'll get a few pics tonight if it's not to dark when I get home.
Other wise, many many many detail pics will be coming this weekend.
as for the exhaust....it's the same as seen here in tex's post.
http://www.pirate4x4.com/forum/showt...me+of+our+work
GET IT Dave!!
Old 01-08-2003, 09:44 AM   #8 (permalink)
Member # 5286
Send a message via Yahoo to Jason M
Could you make it to TDS???
http://www.tds4x4.com/
DEAR MADAM:
THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE.
YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY.
PLEASE SELECT ANOTHER ITEM.
THAT'S OUR FIRE EXTINGUISHER
Jason M is offline   Reply With Quote
Old 01-08-2003, 09:45 AM   #9 (permalink)
GloNDark's Avatar
Member # 2482
It's a possibility. Gotta get me a trailer first though.
GET IT Dave!!
Old 01-08-2003, 10:02 AM   #10 (permalink)
texican's Avatar
Member # 12349
Borrow Mace's, he ain't gonna need it til 2004.............
Butch
Old 01-08-2003, 10:04 AM   #11 (permalink)
Member # 5286
Tommy is possibly coming down,
see if you can hitch a ride with him..
Think of the rig stack we could have on the bronco
DEAR MADAM:
Old 01-08-2003, 10:12 AM   #12 (permalink)
Member # 5286
Butch
Dam, that was mean...
Heck, I probably won't even need it after 2004!
I never said I wasn't a webwheeler
Sniff, sniff
At least I wheel my rig when it works. Your's is just "too nice" to wheel. (a pretty good cop out for a has been that can't keep up )
DEAR MADAM:
Old 01-08-2003, 10:16 AM   #13 (permalink)
GloNDark's Avatar
Member # 2482
Butch
DOOOOOH!!!!!
Right on, is his bronco gonna be done by then?
GET IT Dave!!
Old 01-08-2003, 10:30 AM   #14 (permalink)
texican's Avatar
Member # 12349
[At least I wheel my rig when it works. Your's is just "too nice" to wheel. (a pretty good cop out for a has been that can't keep up )
[/B][/QUOTE]
So now do we get a debate over the merits of owning one that runs, very well, and turns heads...................or sits in the driveway ????
BTW ask my women how well I can "keep up"
Butch
Old 01-08-2003, 10:51 AM   #15 (permalink)
Member # 5286
Butch [/B][/QUOTE]
Yeah yeah yeah, I know I suck.
I'm just jealous the everyone has a running rig but me...
Just wait, the unicorn shall rise again!!!!!!
DEAR MADAM:
Old 01-08-2003, 10:53 AM   #16 (permalink)
GloNDark's Avatar
Member # 2482
Don't you mean the bird cage shall fly again??
GET IT Dave!!
Old 01-08-2003, 02:24 PM   #17 (permalink)
Member # 6588
Butch
damn you guys are a bit hard on mace
i was gunna lash out at you guys in defence of him
but being the webwheeler that i am, i might just fade away quietly
[COLOR=yellow]Bj on Roids 1970FJ45, Quad Cam V8, Auto, Broken T-case, H-TEC (traction control and cutting brakes) 42 TSLs.[/COLOR]
[COLOR=green][URL=http://www.outerlimits4x4.com]Aussie Wheelers Bulletin Board[/URL] [/COLOR]
BJ On Roids is offline   Reply With Quote
Old 01-08-2003, 02:49 PM   #18 (permalink)
Wait this ain't Tx..
TxCruzr's Avatar
Member # 9380
Send a message via AIM to TxCruzr
"I'm just jealous the everyone has a running rig but me..."
Well, not everyone...had a problem like Glondark's on Sunday.
Loaded up the cruiser to go to San Angelo for some wheeling and when we got up their and unloaded her we couldn't get the trans in gear. Found out that the clutch would pull apart when pedal was pressed. The layers of the clutch would just pull away from each other...quess the small leak from the SM420 finally kick its ass.
Anyone know how to keep an early SM420 from leaking?
Joseph
"There is no hunting like the hunting of man, and those who have hunted armed men long enough and liked it, never care for anything else thereafter."
-Ernest Hemingway
'69 FJ-40 - under construction
TxCruzr is offline   Reply With Quote
Old 01-08-2003, 02:51 PM   #19 (permalink)
texican's Avatar
Member # 12349
Mace can take it, I only pick on the guys I like!
Kinda like pulling the purty girls pigtails in grade school..........Mace likes that too but that's an item for Chit Chat
Butch
Old 01-08-2003, 03:00 PM   #20 (permalink)
GloNDark's Avatar
Member # 2482
Joseph
Where is it leaking from?
GET IT Dave!!
Old 01-08-2003, 04:28 PM   #21 (permalink)
Member # 6588
Butch
HELLO
maybe you guys need to get a room, get out o0f the garage and head upstairs somewhere
