? is there a stronger pinion out there 4 fj40 ??? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 01-17-2003, 05:42 PM   #1 (permalink)
Member # 1825
??? anybody out there make any pinion stronger than stock , for the cruisers ? 4:11 thanks 55guy
55 guy is offline   Reply With Quote
Old 01-17-2003, 09:42 PM   #2 (permalink)
Member # 4783
Fine spline pinions are generally regarded as stronger. Toyota made them in '78 and in FJ62s. Aftermarket gears are all fine spline.
Pin Head is offline   Reply With Quote
Old 01-17-2003, 11:27 PM   #3 (permalink)
freds40's Avatar
Member # 14437
So where do you get the pinion flanges that correspond with the pinion if yours is older than '78?
Marlin Crawler Sales
www.marlincrawler.com
559-252-7295
brendan@marlincrawler.com
freds40 is offline   Reply With Quote
Old 01-17-2003, 11:29 PM   #4 (permalink)
cruiseroutfit's Avatar
Member # 1858
Just about any Cruiser shop.... CCOT, Spectre, Man-A-Fre, Cruiser Outfitters...all of them should be able to hook you up...
Kurt Williams
Cruiser Outfitters - YOUR CRUISER PARTS SOURCE! - ARB - OME - Engel - Helton - AdvAdapt
ExpeditionUtah.com
U4WDA - Member
TLCA #10662
Wasatch Cruisers #028
Mountain Yoats
Red Rock 4 Wheelers #789
Mojave Underground
kurt@cruiseroutfitters.com
cruiseroutfit is offline   Reply With Quote
Old 01-17-2003, 11:46 PM   #5 (permalink)
Member # 9669
Or you could get the mini truck flanges an re drill if needed. If I remember, a minitruck pattern is the same as the middle (medium) cruiser pattern. The splines are the same. The minitruck front tcase output has a larger flange and pattern that matches the FJ60 pattern.
84 FJ60 SOA, SR, 35 MTRs, 4:11, 2F
92 FJ80 850J/863, 37's - Getting one tons
trd55 is offline   Reply With Quote
