Booty fab or not? - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 04-25-2003, 06:28 AM   #1 (permalink)
Member # 9390
Send a message via ICQ to Diesel_Cruiser
Booty fab or not?
Finally finishing my FJ 60 power steering swap into my BJ40.
I'm almost sure this will be plenty strong but wanted to get your guys opinions on this.
To mate the different TRE sizes from the FJ60 box to the stock BJ40 tie rod arm,I used a Nissan patrol tie rod wich has a TRE that fit's into the FJ60 pitman arm, cut it at the right length and then slid the stock BJ40 tie rod inside, plan is to weld it at the end and then drill a couple of holes in the Nissan tie rod and then weld there too.
Anyone had any negative experiences with this?
This is the steering box, with an unknown pitman arm, it came off of a manual steering toyota box but has the bigger holes than a 40.
Christof M. from Flanders, Belgium
1980 Bj40, home built shackle reversal, rollcage, Lj70 front discs, Bj60 Power steering,...
1978 blonde, no need for any upgrades :-)
Al Bundy: " This is what being a man is all about, making mistakes and not caring!!"
Diesel_Cruiser is offline   Reply With Quote
Old 04-25-2003, 06:32 AM   #2 (permalink)
Member # 260
Send a message via Yahoo to woody
That exact process is similar on Scout steering setups for the drag link....Scout pitman, use Scout tie rod to the pitman, cut in half, use the Cruiser other half and it slip fits in exactly....weld the junction and plug weld a couple additional spots to be sure.
I ran mine like that for 3-4 years with no problems.
Only concern might be your country's "DOT" regulations...welded steering items in the USA doesn't sit well...heh
Brian 'woody' Swearingen - IH8MUD Inc.
'74 FJ40, '95 HZJ75, '96 FZJ80, '03 2500 DMax, '09 RZR
woody is offline   Reply With Quote
Old 04-25-2003, 07:28 AM   #3 (permalink)
Old Rock Doc
Medusa's Avatar
Member # 915
Hey Woody, why don't you sell Christof that aluminum tiie rod that you once used
Medusa is offline   Reply With Quote
Old 04-25-2003, 08:00 AM   #4 (permalink)
Member # 9390
Only want it if it's chromed
Old 04-25-2003, 08:31 AM   #5 (permalink)
Member # 260
hey, I've still got that laying around....what a POS....believe me, I don't listen to that race shop anymore
it works great so long as you don't need to turn....
