Flatty's Murphy's Law build - Page 6 - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 03-20-2017, 07:31 PM   #126 (permalink)
OnTheSpot's Avatar
Member # 34900
You can do it! The last stretch is always the hardest but it will be worth it!
Applying the Beef Treatment
OnTheSpot is offline   Reply With Quote Quick reply to this message
Old 03-21-2017, 10:08 AM   #127 (permalink)
Member # 29
Yup... after I moved, I spent soo much time remodeling and building the house that I never got around my getting my shop setup. The shop is HUGE with 2 2 car bays, and a seperate machining room and another storage room. I finally got the electrical panel wired and a few plugs setup so now I can start welding and doing other work.
hopefully I will have pics of the cruiser doing work up pretty soon.
Dima
FJ40 crawler, 2006 F250 for tow duties
Flatty is offline   Reply With Quote Quick reply to this message
Old 03-21-2017, 01:45 PM   #128 (permalink)
Rock Toy's Avatar
Member # 28
Send a message via AIM to Rock Toy
You wouldn't believe the small things that kept this thing from running. Luckily, we were able to trouble shoot and cure them and now the end is in sight.
This list is short. I'm guessing that we can have it driving around the yard in a week or two. Motor just needs to be tuned a little (timing mainly), steering bled and some gauges hooked up. Then probably a few cans of paint and off to shake-down city. Assuming that the Transmission works, that is
'97 Grocery Getter overflowing with bolt-on goodness
Rock Toy is offline   Reply With Quote Quick reply to this message
Old 03-21-2017, 02:51 PM   #129 (permalink)
Member # 29
Not worried about the trans (I have a great trans builder). I am worried about the t-case though hahahahahaha
Dima
Old 03-22-2017, 11:58 AM   #130 (permalink)
Member # 103518
That wiring was some thing else!! Not sure how the last guy made it run with it.
You should have seen the trans when I checked it out!! Case was blown out, sprags and clutches were gone. its should be good to go now but it's Dima so who knows what could happen.
69 FJ40,fi350,400,STAK,tons,42s.
Sierra rock crawlers
lildave is offline   Reply With Quote Quick reply to this message
Old 03-22-2017, 02:51 PM   #131 (permalink)
Rock Toy's Avatar
Member # 28
Well, it's all buttoned up now and runs well. Probably better than any crawler Dima has had in the past ten years I'll do some more cleanup on the wiring and it will be good forever.
Good to hear about the Transmission. And the plumbing on the truck looks factory!!! So bit by bit, little by little it's getting done.
Old 03-22-2017, 06:18 PM   #132 (permalink)
Member # 103518
Great, was a pain to do some things knowing he's going to be adding an changing it sooner then later.
Old 03-23-2017, 09:36 AM   #133 (permalink)
Member # 29
oh come on now... hahahahahahah I won't be changing about 90% of the stuff you did... Frame stretch and new panels at some point... But otherwise, its all gdd.
And I have to say the exhaust looks and sounds amazing.
Dima
Old 03-23-2017, 10:09 AM   #134 (permalink)
Member # 103518
I know your going to add tube and link the front so I tryed to set it up for that, It was the hardest one I've ever had to do hands down.
Old 03-23-2017, 10:19 AM   #135 (permalink)
Member # 29
That idea was floatinga round my head last night at about 1am when I couldn't sleep... thanks 9 month old...
I aim to make everything at hard on everyone as I can hahahaha
