Metal-tech'in
Member # 10420
Tube fenders are finished.
Tube fenders are finished, it took some time but they are done.
It was a flog session but I got them done one day before leaving for Moab. It took some time but made them exactly like I wanted too, no compromises. They are constructed out of 1.5” .065 and .120 tubing.
Metal Tech Made in the USA! ALL Active duty US Military get 10% off Metal-tech brand – thank you for your service! |
Metal-tech'in
Member # 10420
I did not what them to be tanks so I made them as light as possible. (Yet all 225 lbs of me can stand on them) If I should stuff one on a tree or rock, eh I will just make another. (Ok I THEN might make the whole thing out of .120”) I did move up the fender by 2.5” to allow for my future tire size and mog axels. I refuse to put a body lift on if I can help it. (RustyB Notice the hood latches? I took a leaf from what you did and pulled one of the bolts for the upper part of the latch and kicked it forward. The hook on the fender is a .5” SS washer bent up and bolted in place with a 5mm SS button head bolt. Works great.)
Metal-tech'in
Member # 10420
A shot of the Fab.
With out running wheal wells the motor ran nice and cool in Moab all week long. I never went above 200 the whole week. (Ok it was a cooler week than last year) For the local winter runs I will put in soft wheel wells to keep the splash off the motor. I did build an aluminum shield for the K&N cold air intake on the drivers side. (I don’t think my MAS wants ANY H20 going through it!)
I REALLY like!!!
Wanna make me a set? No inner fenderwells?
DEAR MADAM: THANK YOU FOR YOUR RECENT ORDER FROM OUR SEX TOYS WEBSITE. YOU'VE REQUESTED THE LARGE RED VIBRATOR AS FEATURED ON OUR WALL DISPLAY. PLEASE SELECT ANOTHER ITEM. THAT'S OUR FIRE EXTINGUISHER |
Metal-tech'in
Member # 10420
After talking with the guys at Moab Off Road at last years CM02’ I knew I would have my nose guard on before Moab this year. I chose to move the lights down below the bezel. The lights are LED simi-truck trailer marker lights, single wire units. However I have them running as both run and turn signals! By using a solid state converter used for trailers I have the stock running lights going in on the stop lead of the converter. The R and L turn leads out the other side of the converter go to each light. Turn on the running lights and they light up, hit the turn signal and the converter interrupts the signal and they each flash as they should.
Mark
Moderating Midget
I really like them! Great work!
Nolen Grogan 1997 FZJ-80 Land Cruiser, 37's 2010 RZR-4 www.cottonlandcruisers.com www.rockmidgetphotography.com USAF Veteran 1988-1998 GOD Bless America |
Member # 39
Looks good.
Do you run your rear lights on the same converter box as your front lamps? Any problems with flash rates?
Eric Parts for Sale --> D44 shafts, 6 lug rims, air tank |
#12 (permalink) |
Member # 12758
They also look great in person, very nice and smooth, retain the OEM style, but are nice and tucked up under there, and are definetely beefy! I also like the marker lights idea. Sort of like an old Ford or Chevy that doesn't have the yellow turn signal bulb. It uses the same filament for braking and signaling. And another filament in the same bulb for the running lights...!
#14 (permalink) |
Member # 12349
Trash truck fenders!!!
Long story, ask Charles Kim...... I like em. Butch
Conflict is inevitable..... Combat is optional.... Tires are like boobs, they always look big until you have played with them for a while, then you just want a bigger set. [URL=http://www.lslc.org/]Lone Star Land Cruisers[/URL] [URL=http://www.khyi.com/]Support Texas Music[/URL] |
#15 (permalink) |
Metal-tech'in
Member # 10420
Thanks for the comments guys. I will beet them up for awhile and see how the hold up! (I am sure a tree will get one eventually, they seem to get in my way every now and then)
Jason, No need for inner wells during the summer. The soft wells (conveyer belt material) will do splash duties during the winter. I have thought about alum. But no need for all that, the soft stuff will R&R easier. No wheel wells were one of my biggest drives to build these. Last Summer was the first test of my 383 in real heat and the same cooling syst. that worked great for my 305 was taxed with the 383. (Little Sluice won due to how hot my motor got. Round 2 in Aug!) Air flow! It works. (W’ Harold was trying to convince me to pull the upper panels off each fender… a ya sure it would work but I don’t dig the look. But then again W’ has always been more focused on performance and not esthetics!) Mark
Metal Tech Made in the USA! ALL Active duty US Military get 10% off Metal-tech brand – thank you for your service! Last edited by helocat; 05-12-2003 at 01:57 PM. |
#16 (permalink) | |
Metal-tech'in
Member # 10420
Mark
#17 (permalink) |
THATS SWEET MARK
YOU DONT HAVE ANY MORE INFO FOR ELECTRICAL DUMBASSES ON HOW YOU DID THE LIGHT SETUP, DO YOU? I'M very INTERESTED AS THIS IS WHAT I WANT TO DO BUT DONT UNDERSTAND HOW TO DO IT....SO THE FLAT SPOT ON THE BOTTOM OF THE FEDNERS... IS THERE A JOINT THERE, OR A BEND? EITHER WAY I LIKE IT... MATT
[SIZE=1] "ANYONE WILLING TO TRADE FREEDOM FOR SECURITY DESERVES NEITHER." TUBING AND BUGGIES ARE OVERRATED METRIC ROCKS. [/SIZE] |
#18 (permalink) |
Member # 6588
looks pretty cool, and another wheeling square bezel cruiser
[COLOR=yellow]Bj on Roids 1970FJ45, Quad Cam V8, Auto, Broken T-case, H-TEC (traction control and cutting brakes) 42 TSLs.[/COLOR] [COLOR=green][URL=http://www.outerlimits4x4.com]Aussie Wheelers Bulletin Board[/URL] [/COLOR] |
#21 (permalink) |
Member # 11458
I need to find more land cruiser parts to trade you for those tube fenders
Propane Powered 2f Metal Tech Production Manager [url=www.metaltechcage.com]Metal Tech Cage[/url] |
#22 (permalink) |
Chubby Chaser
That is EXACTLY what fatkid and I will be doing to my rig next week
How are they crossbraced? Is there a tube running between the radiator and grill that connects them
Eric Anderson TIN BENDERS Hendrix XR Chassis #001 Ultra4 #66 4Wheel Parts, Raceline, PSC, Bilstein, Marlin Crawler, Smittybilt, HendriX, PacificFab, G2 Axle, PAC Spring, G&J, MAXXIS Roxy's in the industry and I'm a sponsored professional driver. The two of us together make a powerhouse. Accepting the things I cannot change. |
#25 (permalink) |
Member # 1357
Outstanding job. Did you solid weld the sheetmetal all the way down the fenders or do a bit of bondo type filler and sand down?
77 FJ40, 5.7L vortec, soa, shaved 14 bolt rear, stock front housing loaded with some good stuff, and a lot of f***ing dents and rust. |
