Need 1981-1987 FJ60 Carbureted Emissions Information/readings - Pirate4x4.Com : 4x4 and Off-Road Forum
Old 05-27-2003, 09:53 PM   #1 (permalink)
Member # 11709
My 1981 FJ60 has failed the Colorado emissions.
I am looking for the emissions readings from a 1981-1987 Carbureted model
as a comparison that has passed !!!
Also need timing information.
1981 FJ60 that failed -----------------------------------------------------
Altitude 6000 feet
2500 IDLE Limit
HC PPM 245.8 271.8 400
CO% 3.59 0.17 1.50
CO2 % 12.8582 11.0506 ------
RPM 2421 882 1350
Timing 6% @ 1000 rpm
Thank You
George
TIA.........No Flames only the FACTS !!
LoneZuk, Louisville Colorado
LoneZuk is offline   Reply With Quote Quick reply to this message
Old 05-27-2003, 10:05 PM   #2 (permalink)
Member # 12758
Not sure on the timing but the stock setting is 7 degrees before top dead center, or right on the silver BB on the flywheel when timing. If it's running 6% I assume that means 6 degrees before top dead center, hence a hair retarded when they say advance in altitude which may cause excess unburnt fuel aka emissions problems. Also, if your emissions equipment is not functioning, it will also effect your timing as I believe the EGR and vacuum advance are related...
Good luck, on Jeff Zepp's web site there is a good deal of emissions related information. Search the LCML at birfield.com/archives for Jeff Zepp and it's probably in his signature. Good luck...
dieselcruiserhead is offline   Reply With Quote Quick reply to this message
Old 05-29-2003, 12:13 AM   #3 (permalink)
Banned
Member # 17477
Timing setting
Hey Zuk, You need to set you timing at about 9-10 degrees BTDC.
You are way up in altitude. You can go farther advanced just listen for the pinging. When you hear it under hard acceleration or load, then back the timing off a degree at the time until the ping is gone. That is the best way to take advantage of you altitude and try to achieve Stoichiometric(14.7:1, the perfect mixture, aaahhh!!!!) And make sure you get that truck HOT before the test is taken. You want that CAT to be hotter than hellfire, so drive it up the road a few miles, stomp it, let off, repeat a few times then hold throttle steady at about 1800-2000 RPM to keep the CAT from loading up and overheating. But then take it to the test place and let them test it real quickly. tell 'em your wife's havin' a baby or something and you're in a hurry!!
BTW< when you get a chance email me when you're gonna be around to respond right back.
Happy Testing!!!
Richard
Kruzrtek
kruzrtk@xmission.com
kruzrtek is offline   Reply With Quote Quick reply to this message
Old 05-29-2003, 09:27 AM   #4 (permalink)
Member # 1527
Get the 2F emissions manual from Specter or other source. It has a lot of good information on setting up the carb and checking the emissions components, etc.
Specter manual
80, '72 GMC, Odyssey
cruiserman is offline   Reply With Quote Quick reply to this message
Old 05-29-2003, 11:42 AM   #5 (permalink)
fj40guy's Avatar
Member # 9576
Big verbose text follows... bottom line, your CO is reading too high.
Most likely... too rich of a mixture at IDLE!
2500 IDLE Limit
CO% 3.59 0.17 1.50
RPM 2421 882 1350
First... tune up. New plugs, check the ignition, GET THE IDLE UP AS HIGH AS YOU CAN. TRICK. "low idle limit" is usually 1,000 rpm. Adjust for 990 rpm... if too high at test, turn on FAN AND LIGHTS to drop the rpm below 1,000 rpm.
So after you installed the new air filter, confirmed the choke is off when pushed in, and everything else looks good....
Dump in TWO CANS of "dry gas" into the tank. Helps burn a little cleaner. (CO)
CHANGE THE OIL before going in. (HC)
Yep, make sure you are UP TO TEMP before attempting the test. Long que... go back LATER, do not sit there at idle prior to testing (system gets a ton of HC buildup)
Question:What kinds of emissions should I be concerned about?
Answer:All emissions if you're serious about clean air -- or at least worried you won't pass an emissions test. Most emission testing programs to date only check for only two pollutants: carbon monoxide (CO) and hydrocarbons (HC). In areas that have the new "enhanced" I/M 240 emissions testing program, they also check for oxides of nitrogen (NOX) and the operation of your "evaporative emissions" control system (the system that captures and holds vapors from your fuel tank).
CARBON MONOXIDE (CO)
Of the three main pollutants, carbon monoxide is the deadliest because you can't see it or smell it. A concentration of only half a percent (0.5%) CO in the air can render a person unconscious -- and kill within 10 to 15 minutes! Even concentrations as small as four hundredths of a percent (0.04%) can cause headaches and be life threatening after several hours exposure.
WARNING: Never run an engine inside an enclosed garage, not even for a few minutes. The fumes can build up quickly and overcome you before you realize what's happening. Carbon monoxide is invisible and odorless so you can't really tell when it's around.
Carbon monoxide is formed when the fuel mixture is rich and there is insufficient oxygen to completely burn all the fuel. The richer the fuel mixture, the greater the quantity of CO produced. So high CO emissions indicate incomplete combustion typically caused by carburetor maladjustment, a clogged air filter, sticking choke, defective heated air intake system, plugged PCV valve, faulty oxygen sensor, excessive fuel pressure or a fuel injection metering problem.
Carbon monoxide production is highest when the engine is first started because the fuel mixture is richer than normal during this time and the catalytic converter has not yet reached operating temperature.
Carbon monoxide emissions are minimized by maintaining a balanced to slightly lean fuel mixture. This requires careful adjustment of the carburetor idle mixture screws (which may have "limiter caps" to limit the amount of adjustment or are covered with plugs to prevent tampering). On some fuel injected engines, there is also an adjustment for the idle mixture (but it is usually factory sealed to prevent tampering). The fuel mixture is further balanced by the oxygen sensor and computer system. Most of the carbon monoxide that is produced by the engine is converted into carbon dioxide (CO2) by the catalytic converter.
HYDROCARBONS (HC)
Hydrocarbon emissions are unburned gasoline and oil vapors. Though not directly harmful, they are a major contributor to smog and ozone pollution (which are toxic). Hydrocarbons in the atmosphere react with sunlight and break down to form other chemical compounds that irritate the eyes, nasal passages, throat and lungs.
HC emissions, which are usually measured in parts per million (PPM), can go up as a result of ignition misfiring (a fouled plug or bad plug wire), "lean" misfiring (incorrect carburetor idle adjustment or vacuum leaks that creates a lean mixture that misfires), loss of compression (such as a burned or leaky exhaust valve), or engine wear that causes the engine to burn oil (worn valve guides, rings and/or cylinders).
Hydrocarbon emissions are controlled by maintaining the fuel mixture so it is neither too lean nor too rich to ignite, by keeping the combustion chamber tightly sealed (good rings and valves), and by maintaining the ignition system (changing the plugs periodically). HC that is produced in the engine is reburned in the catalytic converter and changed into water vapor and carbon dioxide.
OXIDES OF NITROGEN (NOX)
Nitrogen makes up about 78% of the air we breathe. Though normally inert and not directly involved in the combustion process, combustion temperatures above 2500 degrees F cause nitrogen and oxygen to combine and form various compounds called "oxides of nitrogen," which is abbreviated NOX. This mostly occurs when the engine is under load and the throttle is open wide.
NOX is a nasty pollutant both directly and indirectly. In concentrations as small as a few parts per million, it can cause eye, nose and lung irritations, headaches and irritability. Higher concentrations can cause bronchitis and aggravate other lung disorders. Once in the atmosphere, it reacts with oxygen to form ozone (which is also toxic to breathe) and smog.
To reduce the formation of NOX, Exhaust Gas Recirculation (EGR) is used. By recirculating a small amount of exhaust gas back into the intake manifold to dilute the air/fuel mixture, EGR has a "cooling" effect on combustion, thus keeping temperatures below the NOX formation threshold.
On 1981 and later engines with computerized engine controls, a special "three-way" catalytic converter is used to reduce NOX in the exhaust. The first chamber of the converter contains a special "reduction" catalyst that breaks NOX down into oxygen and nitrogen. The second chamber contains the "oxidation" catalyst that reburns CO and HC.
High NOX emissions are almost always due to a defective EGR valve (or some component that controls the operation of the EGR valve). A related symptom that usually occurs when EGR is lost is spark knock (detonation) during acceleration.
EVAPORATIVE EMISSIONS
The fuel vapors that evaporate from your fuel tank can be another source of smog and ozone pollution. So fuel systems for the past twenty years have been sealed to prevent the loss of vapors.
Some venting of the tank must be provided so it can "breathe" during temperature changes and when the engine is running, so this is provided by hoses connected to a charcoal filled canister usually located in the engine compartment. The charcoal particles in the canister soak up and store fuel vapors when the engine is not running. Then, when the engine is started, a "purge valve" opens to siphon the vapors into the engine where they are burned.
If the canister or any of its hose connections leak (or the gas cap does not seal tightly), fuel vapors can escape into the atmosphere around the clock. The amount of pollution can really add up, especially during hot weather, so it's important to make sure the system is functioning properly. The new OBD II test program includes a pressure check of the fuel tank system as well as a flow test of the purge valve.
Source
Beautiful young people are accidents of nature, But beautiful old people are works of art. Learn from the mistakes of others. You can't live long enough to make them all yourself.
fj40guy is offline   Reply With Quote Quick reply to this message
Old 05-30-2003, 06:44 AM   #6 (permalink)
Member # 11709
Passes at idle, AI system failure
That is the problem it passes at idle, fails at 2500.
The AI system is diverting the output to the bypass side all the time.
It fails AI test #1 in the red 1981 2F emissions manual.
The VTV has no vacuum and all the lines are in file working order.
Any 2F emissions preople on line ?
Old 06-01-2003, 10:08 PM   #7 (permalink)
Member # 2157
The AI system is diverting the output to the bypass side all the time. It fails AI test #1 in the red 1981 2F emissions manual. The VTV has no vacuum and all the lines are in file working order.
Try this: Disconnect the vacuum line from the port on the rear part of the main body of the ABV assembly (this is the air switching valve part of the ABV). Connect a short piece of vacuum hose and draw a vacuum (with your mouth or with a hand vacuum pump). A 5-in hg vacuum opens the air switching valve and sends air into the air injection rail on the engine. If the air continues to come out of the bypass hose, the innards of the ABV assembly may be crudded up with carbon. This can happen if the check valve is burned through, like it was on my '84 FJ60.
John
4Cruisers is offline   Reply With Quote Quick reply to this message
Old 06-02-2003, 07:30 AM   #8 (permalink)
Member # 11709
Passed Emissions
The problem was traced down to the vacuum source.
This is a three port adapter screwed into the intake manifold (sp)ahead of the carb. This item needed cleaning, and when cleaned up the AI system came on line.
Old 06-02-2003, 11:59 PM   #9 (permalink)
Member # 2157
Glad the problem was solved easily.
John
Old 06-03-2003, 06:02 AM   #10 (permalink)
Member # 11709
In the end, the FJ60 has a rebuilt carb with smaller jets. Just maybe the fuel mileage will increase.
This is an every year event in Colorado with an older vehicle.
Old 06-03-2003, 07:55 PM   #11 (permalink)
Member # 2157
I face that process again in Las Vegas in November. Maybe this time I'll have to adjust the valves??? I've been lazy, valves have never been adjusted, and I'm at almost 180K miles.
John
