Member # 6863
Finished building the front axle...
I just finished building the front axle for my truck, and I was talking with a friend who helped me and I ran the numbers through my head interms of cost... Wow. I should have built a dana 60.
I spent more on this axle build than on my first truck. Longs Mark Williams inner axles-300m material E-locker diff new rotors knuckle rebuild kit Hi-steer arms HD tierods FJ80 TRE's T100 calipers new hoses E-locker wiring harness Cut and turn(did it myself) Mopar spring perches CCOT u-bolts I would not do it again, I would build a narrowed 35 spline outer Dana 60 with an arb, and be around the same cost with ALOT more strength. Just a word of advice...
I have enough projects for the next decade. Need two? Last edited by cruiserbrett; 06-08-2003 at 12:14 PM. |
did you say e-locker? That's a cruiser axle? I didn't know they made dem dere e-lockers for a cruiser axle! If you don't mind, where'd you get it and for how many clams?
Looks pretty damn excellent, BTW- nice job. Your last truck was probably neglected
#3 (permalink) | |
Member # 1858
They can be ordered at the dealership
Kurt Williams Cruiser Outfitters - YOUR CRUISER PARTS SOURCE! - ARB - OME - Engel - Helton - AdvAdapt ExpeditionUtah.com U4WDA - Member TLCA #10662 Wasatch Cruisers #028 Mountain Yoats Red Rock 4 Wheelers #789 Mojave Underground kurt@cruiseroutfitters.com |
Member # 4329
Thanks Bret for working with MW to get those axles built
I ordered an inner from them a couple weeks ago we used your print just changed the lenght a little. They were good guys to deal with. |
#5 (permalink) | |
Member # 6863
P.S. dont handle the axles without spraying them down with some wd40 or something, the grease in the finger prints will rust the axles pretty quick. -brett
I have enough projects for the next decade. Need two? |
Member # 4329
They told me it would be a 2-2 1/2 week lead time to get it built.
This Tuesday will be 2 weeks, so I will probably see it the week of the 16th. Then the work starts switching everything together. |
Member # 6863
I got a bunch of pics, so I can write an article for Ih8mud.com on installing FJ80 electric lockers.
I'll post up some more later this afternoon. It was pricey, but it is as strong as a Toyota axle can get, so I guess I am happy.
