Member # 15773
is there any benefit that would come from using a powersteering tranny style or frame cooler.
does the cooler fluid do better then the hot fluid??? thanks
Member # 16085
I'm curious as well, gonna get to installing a OEM PS on my fj40 someday soon. Noticed that the 40s(and 60s) with OME PS use a "cooler" that is nothing more than 2 pipes that run across the front end(on frame) Is this even needed or is it better to use a deal PS cooler?
John
2000UZJ100/92FJ80/90FJ62/86FJ60/82FJ40mustard/82FJ40green/78FJ55/67FJ45LBP/65FJ40LV/65FJ45LV/64FJ45LV/87 Chevy 3/4 ton beater |
Member # 10429
Cooler fluid is better. I added a Derale cooler to mine, just for insurance, like the filter.
The cooler was under $20 from Summit. You'll want one if you've ever touched the pressure line on your P/S by mistake.
Rich Q. FJ-40 Cruggy - tuned 5.3/4WS rockwells/linked/ORI's/42's |
Member # 474
PS fluid coolers are a great idea - it's amazing how hot the steering system gets on the trail pushing big tires around in rocks, etc. I think that most steering box/pump failure is caused by overheating. The extra fluid capacity of the cooler can only help. I am adding a high-efficiency cooler (getting it from Georg - Orangefj45) to help out my system. Adding a small, 12v computer fan to the cooler is real easy and cheap ($5 from the local supply house). Just my 2 cents
![]() Andy
Rock on with the RockDogs! |
Member # 19837
For any type of trail riding a cooler is essential. Any tranny cooler can work. A good 4 row will set you up right. For a DD not a big deal.
If it does not go easy just force it David Dearborn Atlanta GA www.urbanlandcruisers.com TLCA Associate member Got a question, need an opinion, do you love puppies, just want to talk or stage a cage match? For all of these issues and more PM Mark, 65SWB45. |
Member # 9851
I'm useing a ps cooler from a chevy s10 blaser, its a two tube cooler lots of copper fins 14" long and 2.5" tall and about 1.25" deep, works great and mounts infront of the grill (outside of rig) just fine and you can hardly see it.
"CRUZILA" 75 FJ40.....with some stuff done to it. Last edited by Cruzilla; 06-11-2003 at 08:55 AM. |
#7 (permalink) | |
Member # 15773
how much would i cst roughly......just so i can get an idea. thanks again -m
Member # 9851
Its out of a late model 88-90 Chev S-10 Blaser, it cost me around 10 bucks or so, it mounts between the grill and body on the doner rig on the drivers side.
-Scott
"CRUZILA" 75 FJ40.....with some stuff done to it. Last edited by Cruzilla; 06-11-2003 at 09:51 AM. |
Member # 12349
Late 80's to mid 90's Ford Taurus/Merc Sable ton's of them in boneyards.
Got about 20 of them in service
Conflict is inevitable..... Combat is optional.... Tires are like boobs, they always look big until you have played with them for a while, then you just want a bigger set. [URL=http://www.lslc.org/]Lone Star Land Cruisers[/URL] [URL=http://www.khyi.com/]Support Texas Music[/URL] |
Member # 13912
Yessir, that's the same part as the tempo...going the taurus route, find one with the front bumper already off or you'll be there for a while
Visit [url]www.tlca.org[/url]; TLCA Member 6235 TLCA Prez Emeritus |
#13 (permalink) |
Member # 15773
so i think i'll go with the trany cooler out of the tempo ar the cooler out of the blazer depending on which one is easier to extract from the car.
do i have to adapt any of the hose fittings to match w/ the trany cooler. thanks -m |
#14 (permalink) |
Member # 8565
I understand that cooler oil is better but have any of you guys that are running coolers realy noticed a difference from before and after the cooler was installed?
I just wonder wether its realy going to make my steering noticably better if i install one. I am pushing for space allready in front of my radiator and dont want to make room if im not going to get a noticable benifit.
www.outerlimits4x4.com www.werockaustralia.com SAVE THE HAMMERS Post #749 Do illiterate people get the full effect of Alphabet Soup? If electricity comes from electrons, does morality come from morons? |
#15 (permalink) | |
Moderating Midget
![]() I would say that was better. Hell, they are too cheap not to use them, but if you are not having problems now, I don't think a cooler will make your steering any better.
Nolen Grogan 1997 FZJ-80 Land Cruiser, 37's 2010 RZR-4 www.cottonlandcruisers.com www.rockmidgetphotography.com USAF Veteran 1988-1998 GOD Bless America |
#16 (permalink) |
Member # 13912
Running out of room in front of the radiator? I just mounted mine on the inside fender where there was still some air flow. Not optimal, but better than nothing. I notice no difference in steering ability, but as Nolen said, it no longer boils over and smells like fire
#17 (permalink) |
Kool Arrow
Member # 13666
i used the radiator off of an old fridge on my J**P worked great and was FREE from the side of the road just cut out 2 rows of it and flushed it with carb cleaner and ran with it
i killed 3 pumps in a year before that none after you do the math ... redneck bootyfab ... i need one on the 60 , i think it gets harder to steer after you drive a bit i think the pumps going out
#18 (permalink) |
Member # 16884
If you want to stay with Toyota parts, you can use the lines and transfer case cooler from an automatic transmission equipped 85 - 95 truck or 4-Runner. The lines have the same threads and fitting types, various hard and soft, they can make for a nice oem look cooler. BTW, they mount underneather the truck on the frame, by the front drive shaft.
Formerly Bjowett 86 4-Runner Turbo FJ80SAS 1ton FF rear 03 Taco Double Cab (hers) 01 Audi S4 Avant 320 HP 93 VW Corrado Syncro 3.0L |
#19 (permalink) |
Member # 4526
I installed one to try to cure a problem - my PS will quit working after extended use in 4wd. Haven't tested it out yet but I hope that it gives me more time before I need to do pump mods.....
And it is not gonna hurt to add a PS cooler. My car came with one from the factory.
#20 (permalink) |
PS cooler.
Woo-hoo. Good thing I made that call.
I am in process of installing PS, (saginaw) and I put the cooler in as a matter of part of doing the project. I put in the Checker Aluminium cooler. looks neet sitting in front of my radiator. Though, I am a little concerned about airflow for the engine coolant. Well, we will see how things go. My truck gague reads in the DEAD MIDDLE of the gauge. Now, for saginaw PS, do I put in ATF (Like in Toyota PS) or PS fluid?
-James H -76FJ40 HiPo2FSM420OMELockRite35's "You're the guy from the Hamburger train, right?" |
#21 (permalink) |
Member # 16024
I found a nice single tube w/fins model on many full-sized Ford cars... Also Ford has a nice trans cooler that is the plate style - stonger and perhaps more efficient, on many of the areostar vans. Very compact unit that would work great for PS cooler.
I mounted mine on the drivers side radiator support on my 86 Ranger. Right behind the charcoal canister. Used the same bracket for the canister, used a hole-saw to cut an air hole out to the grill area. Works sweet! Also, found that a lot of full-sized Lincolns have the Saginaw PS pump...
Check out UCORA.org VOTE or SHUT UP! Last edited by glfredrick; 07-10-2003 at 09:47 AM. |
#23 (permalink) |
Member # 39
I put mine between the steering box and the pump on the return line (low pressure side). I just used hose clamps to hold the hoses on.
Eric Parts for Sale --> D44 shafts, 6 lug rims, air tank |
#25 (permalink) | |
Member # 6588
If space is your primary issue, I have seen one mounted on an inner guard with its own small electrical fan. Nolen has his auto cooler there I think?!?! The cooler fluid is not so much the advantage, as the additional capacity. The time taken to heat that additional capacity of fluid can greatly affect the steering in that the fluid will stay cooler for longer. I think maybe just use the OEM cooler, like off a 70 series, or 60 series, as they are just a steel pipe which goes along the chassis in front of your radiator around and then back, use one of them (no space taken up) and one of those kubota fuel tanks, for a reservoir ![]() You cna see the OEM cooler running along the front crossmember in this picture. Hell with the 5Litre tank you probably wouldnt need this.
[COLOR=yellow]Bj on Roids 1970FJ45, Quad Cam V8, Auto, Broken T-case, H-TEC (traction control and cutting brakes) 42 TSLs.[/COLOR] [COLOR=green][URL=http://www.outerlimits4x4.com]Aussie Wheelers Bulletin Board[/URL] [/COLOR] |
